 Old 03-19-2014, 09:20 AM   #1
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I didn't test the CS springs, but I did have the stock springs tested. They were 285/185 lb/in front/rear. CS claims the stock springs are 280/195.
CS has said their springs are 5% stiffer than stock, which would put them around 295-300 lb/in for the front, and 195-205 lb/in for the rear, depending on which data points you subscribe to. There is also undoubtedly some variance in the spring rate from the manufacturer, unless they are using one of the big spring companies (swift/eibach/hypercoil).
That gives you, at most 1.30Hz front and 1.35Hz rear frequencies (these will be lower if you have a heavier car - GT's are heavier). A long cry from a performance setup, if that's your goal.
-06 MS6
-Corn fed 07 MS3 - Sold
dale_gribble (03-19-2014), rob ms6gt (03-22-2014), sunshinefc3s (03-19-2014)
Kia Q1 profits surge 26% on demand for new products in U.S., elsewhere Haltech Automotive News 0 04-27-2012 08:20 AM
MAPerformance is proud to offer Torque Solution Products for the Mazdaspeed!!! maperformance Modern Automotive Performance 42 03-21-2012 01:51 PM
The Popular Mechanics Car Know-It-All Quiz Haltech Automotive News 0 03-05-2012 11:50 AM
New Mazdaspeed / Grimmspeed products rfinkle2 Gen2 MS3 General Discussion 12 06-01-2011 10:39 AM
By popular demand, my Tenzo Type Ms..... winniep MazdaSpeed 3/6 - Wheels & Tires 11 05-24-2008 12:34 PM
Page generated in 0.25068 seconds with 22 queries
