  • 1 Post By darthxar
 Old 02-09-2014, 11:23 AM   #1
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
Default OCC issues?
So I've been running the CS OCC and pcv/crank vent routing for about 10k miles and today decided to swap over the CS boost tubes I had.
What I discovered was oil on either side of the intercoolers couplers. Is this due to the OCC not doing it's job of getting rid of this crap from the PCV? Is the dual routing method not enough? I'm half tempted to pick up a check valve and use the tropical OCC routing to see if it alleviates it. All I ever have in my OCC is piss colored water.
A little tapa tapa taparoo...
 Old 02-09-2014, 11:47 AM   #2
Blkpearl's Avatar
Posts: 353   (View Stats)
Blkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond repute
Groaned at 19 Times in 9 Posts
I'm curious to know also. How long have you been running it since new? Or how many miles on the car now? I'm thinking jbr kit myself.
Blkpearl is offline   Reply With Quote
 Old 02-09-2014, 11:54 AM   #3
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Neutral  :  -1 score
@evil MS3; you have not had luck with this..
Best of luck....brownie!!!
Last edited by MazdaBoy2.3; 02-09-2014 at 12:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-09-2014, 11:57 AM   #4
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
I would change the way you have it plumbed and add a check valve.
I have mine (JBR stg2) plumbed:
PCV-->Check Valve-->Bottom port on can-->Top port on can-->Intake manifold
Never had any oil in intake tract.
 Old 03-26-2014, 07:33 PM   #5
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Is using the stock PCV valve along with the check valve from JBR good?
Just wondering because I was under the impression that the stock PCV valve needed to be removed from the equation
Thanks
 Old 02-09-2014, 11:58 AM   #6
m4tic's Avatar
Posts: 4,928   (View Stats)
perm dual routing yo
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Micha (02-09-2014)
 Old 03-13-2014, 10:13 AM   #7
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
I know this is a bit of a thread revival, but i too just found a lot of oil in my TIP with the CorkSport OCC. Does anyone know if there is any kind of baffle in the OCC? The two ports are really close together and maybe oil mist just "short circuits" from one port to the other. I bought this to keep my valves clean, but not sure it is doing the job.
@CorkSport; do you have any suggestions to improve the oil catching? Maybe a routing change, or putting some steel wool in the can?
darthxar is offline   Reply With Quote
 Old 03-14-2014, 03:06 PM   #8
Can you send me a picture of how you have it setup? Derrick (at) Corksport.com
 Old 03-14-2014, 03:30 PM   #9
darthxar's Avatar
I will try to get pics this weekend. I will be putting your airbox in probably tomorrow.
Double tappin' the Moto
CorkSport likes this.
2013 VRM MS3
 Old 03-15-2014, 12:39 PM   #10
darthxar's Avatar
Here a couple pics for you. The white arrow is the hose to the VC vent. The Green arrow is the hose to the PCV and the red arrow is the hose that goes to the TIP. Also note that the screws are very corroded from leakage. No matter what I do there is always a little seepage from the screws. I have tried all kinds of sealants. (I am a former pipe fitter so I know a bit about sealants). Next I plan on just cleaning them up and covering them with silicone caulk. The screw leakage doesn't seem to be enough to impact fuel trims, but does cause some odor when stopped. The real issue I have is the amount of oil in the TIP and intercooler.
 Old 03-20-2014, 07:30 AM   #11
darthxar's Avatar
@CorkSport; Any feedback on this? Just bumping in case you missed the pictures.
 Old 03-13-2014, 10:28 AM   #12
5LOWMS6's Avatar
Posts: 1,088   (View Stats)
5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world
Groans: 46
Groaned at 37 Times in 19 Posts
the oil in the intake/intercooler is from your valve cover breather line that connects to your intake. your OCC works but it would be better if you also connect the VC breather line to the PCV one with a Y or T connector then to OCC.
06 Liquid Platinum GT
COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring
MisterSix Tuned..
vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected
5LOWMS6 is offline   Reply With Quote
 Old 03-13-2014, 10:35 AM   #13
darthxar's Avatar
I have the VC line T'd into the OCC inlet with the PCV. The hose to the TIP is the outlet of the OCC.
2013 VRM MS3
 Old 03-13-2014, 10:41 AM   #14
5LOWMS6's Avatar
Groans: 46
not sure if OP is running the same setup but in your case it's definitely the occ.
MisterSix Tuned..
 Old 03-13-2014, 03:23 PM   #15
darthxar's Avatar
Yeah I might need to change the can out to something with better baffling.
2013 VRM MS3
 Old 03-20-2014, 08:40 AM   #16
littleloogy's Avatar
Posts: 4,005   (View Stats)
That's weird. How long has the can been installed? Mine still looks brand new.
 Old 03-20-2014, 08:53 AM   #17
darthxar's Avatar
About 9 months. It seems no matter what I do there is a little leakage from those screws, and I always have a touch of odor when at a stop, unless HVAC is on recirculate. As I said, now that it is warming up, I may clean them all up and seal them with some silicone.
At this point though I am thinking of going to a different set up, especially since this setup provides almost no vacuum at idle or cruise for the crankcase. I am really leaning toward a two can set-up, one for the PCV and one for the VC.
 Old 03-20-2014, 09:44 AM   #18
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Sounds like the CC isn't doing its job, sending everything back in. Should slap another CC on there to be sure.
bioevolve is offline   Reply With Quote
 Old 03-20-2014, 02:30 PM   #19
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Just to add my .02, I just removed my TMIC to install a FMIC and yep I am in the same boat. Oil is finding its way through the lines and back through my TIP. I ordered a JBR stage 2 to swap out everything. I only get yellow liquid out of my can. Very rarely do I get any thing else. Of course I am glad the OCC is catching that fluid, but I would like for it to also catch the oil residue. I have my can ran the same as the photos.
PS I am running the first version OCC with the welded top, not sure if that makes a difference.
littleloogy (03-23-2014)
 Old 03-24-2014, 10:52 AM   #20
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
i'm going to check my boost tubes before enm since i am also running this catch can. my ic pipes have always been dry since i got the car. one thing to note is that i also have a oil cap breather to vent crank case pressure.
 Old 03-26-2014, 05:26 PM   #21
evil MS3's Avatar
Groans: 55
I bought a check valve and hosing from Matt Damond and did the typical routing. Didn't enjoy seeing that oil in there. Also, f this can in the A for not having a drain valve and having an obtuse size thread so I can't buy a valve.
 Old 03-26-2014, 06:05 PM   #22
darthxar's Avatar
Yeah I am thinking of buying a kit from Matt as well.
2013 VRM MS3
 Old 03-26-2014, 06:07 PM   #23
jdmage_mx5's Avatar
I ended up drilling out the drain line and tapping it with new thread pitch so I could install a drain valve. I'm out of town or I would attach pics, sorry.
jack_hammer (03-27-2014)
 Old 03-26-2014, 06:11 PM   #24
Etipp98's Avatar
Posts: 1,947   (View Stats)
What is the thread size on the CS drain port?
 Old 03-26-2014, 06:16 PM   #25
evil MS3's Avatar
Groans: 55
It's like m8 x 1.25 or something. A size no one makes a valve for
Yeah, I was thinking of that as well.
Last edited by evil MS3; 03-26-2014 at 06:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-26-2014, 06:23 PM   #26
Etipp98's Avatar
They do make m8 x 1.25 male to 1/8 npt female adapters. Then all you need is a 1/8 npt ball valve.
 Old 03-26-2014, 06:31 PM   #27
evil MS3's Avatar
Groans: 55
Yeah, the adapter is like $20 shipped lol
 Old 03-26-2014, 07:51 PM   #28
plak424's Avatar
Posts: 298   (View Stats)
plak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the world
I Junked my CS catch can. I had the same story, all the OCC ever pulled was yellow water and I still had oil getting through into the TIP. Then on top of it the can would pull so much water that the lines would freeze up in the winter and block off my PCV in literally 100-150 miles.
Overall I was very dissatisfied with the quality of this set up (I had a 2nd gen welded can with the shitty lines and stupid plug that rusted immediately) and if I decide to install another OCC down the road I'll go MD or JBR with the correct routing and a CV.
Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon...
plak424 is offline   Reply With Quote
 Old 03-26-2014, 08:12 PM   #29
darthxar's Avatar
Yeah I am really thinking MD new design can he just released. I might use the Corksport between the VC and TIP. then the MD with CV between the PCV and manifold.
2013 VRM MS3
 Old 08-15-2014, 08:49 PM   #30
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Sorry to revive this thread, but what is the drill bit/tap size for the drain valve on the can? I know its m8x1.25 for the old style can but its since been revised on the v2.
Edit: After a bit of trial and error, its an 11/32 bit and m10x1.5 tap.
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
Some MS3 Issues kpkaw1978 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 04-29-2013 12:11 PM
New (to me) MS6 and a few issues Outlaw4shrt MazdaSpeed 6 - Engine, Transmission & Driveline 40 02-02-2013 03:31 PM
Possible DBW Issues helmetface Mazdaspeed3/6 General Discussion 39 01-08-2013 03:09 PM
Help Please Having Issues CruZ_MS6 Mazdaspeed3/6 General Discussion 2 12-09-2011 08:28 PM
issues with maf g/s dooderek MazdaSpeed 3/6 - Turbo Induction 4 11-15-2011 10:34 PM
Page generated in 0.51337 seconds with 36 queries
