![]() Join Date: Jan 2013 Location: Norman, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
__________________ 2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb ![]() AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna |
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score Did you Email or Call them first? You will get a faster response that way.
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
(Thread Starter) | Not Ranked : 0 score I emailed them and I plan on calling them Monday when they're open. I just posted this thread thinking that maybe they could get to me this weekend if they were on the forum.
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
| Not Ranked : 0 score OP, Kelly will get you take care of the on the service ticket you entered in our system. Thanks Derrick |
(Thread Starter) | Not Ranked : 0 score Thanks so much! I talked to Austin on the phone. I really appreciate it!
| The Following User Says Thank You to bigmike For This Useful Post: | AustinK (06-28-2013) |
| Banned ![]() Join Date: Jan 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score Cheers man, shit happens when you party naked. true story. |
(Thread Starter) | Not Ranked : 0 score They got me all taken care of! Thanks CorkSport
| Passenger Motor Mount Failure #2 | mczimer | MazdaSpeed 6 - Engine, Transmission & Driveline | 59 | 01-06-2015 02:44 PM |
| PMM failure + AWR passenger motor mount install | jamesthebikeguy | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 08-11-2014 12:02 AM |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
| Failure at the Track- Motor Mount? | JNR5005 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 10-26-2009 09:21 AM |
| Pt Performance Driverside Motor Mount Bushings Failure | broncoblitz | Mazdaspeed3/6 General Discussion | 18 | 01-17-2009 02:04 PM |
