Like Tree32Likes
 Old 04-22-2013, 11:10 AM   #201
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
I get about 90% water in my OCC. With the weather around here lately its usually full at or before 3k miles. Glad I switched the the larger can as with the CS can I could only go about 2k miles at the most before it was full.
 Old 04-25-2013, 09:08 AM   #202
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
So I can safely assume there is:
A. something wrong with my hose routing
B. something wrong with a seal somewhere in the system
C. maybe a clog in the system?
Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included!
seshomaru7 is offline   Reply With Quote
 Old 04-30-2013, 04:08 PM   #203
Kfunk's Avatar
Posts: 33   (View Stats)
Kfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to behold
Well I can say I went about a 1000 miles inclusive of a track day. And got this.
Originally Posted by seshomaru7 View Post
I have had this installed the original way for quite a while before having to switch to some stronger hosing after finding tears. At the same time I changed the routing to include the cam breather, and removed the check valve. After a couple more months I finally went to try draining the thing and got a very small amount of brownish oily substance...would have posted a pic of the stuff but there was so little in the bottle that wind knocked it over. Anyone else not getting much in their can? I have checked all the routing of hoses and made sure there weren't any holes.
I have the same routing as you and hot the same small bit of brownish oil but it has started to collect now as you can see.
Last edited by Kfunk; 04-30-2013 at 04:08 PM. Reason: MSF Database - Automerged Doublepost
Kfunk is offline   Reply With Quote
The Following 2 Users Say Thank You to Kfunk For This Useful Post:
Awal (05-26-2015), BloodySpeed3 (05-02-2013)
 Old 05-04-2013, 09:37 PM   #204
seshomaru7's Avatar
I will check it again at my next oil change and post results.
 Old 07-17-2013, 03:58 PM   #205
CamMS3's Avatar
Posts: 17   (View Stats)
CamMS3 has a spectacular aura aboutCamMS3 has a spectacular aura about
Did CS take this product off their website??
CamMS3 is offline   Reply With Quote
The Following User Says Thank You to CamMS3 For This Useful Post:
El_Diablo (07-17-2013)
 Old 07-17-2013, 04:04 PM   #206
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
Sure enough. I can't get to it either.
@CorkSport; @Joel@CorkSport; sup wit dat?
A little tapa tapa taparoo...
 Old 07-17-2013, 04:07 PM   #207
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
I wonder if there's a redesign or something that they're about to release.
On deck: VG Sharkfin Antenna
 Old 07-17-2013, 06:36 PM   #208
El_Diablo's Avatar
Groans: 769
I see you lurking @CorkSport. Whats the deal?
 Old 07-17-2013, 07:21 PM   #209
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
4 part video series is being developed to answer
it's fun to do bad things
The Following 11 Users Say Thank You to jack_hammer For This Useful Post:
Awal (05-26-2015), CorkSport (07-18-2013), Easter Bunny (07-17-2013), El_Diablo (07-17-2013), himurax13 (07-18-2013), Hush (07-17-2013), jk_ms3 (07-17-2013), Kyle Undefined (07-18-2013), NJSPEED3 (07-20-2013), Raider (07-18-2013), Ryguy (07-17-2013)
 Old 07-17-2013, 07:40 PM   #210
Tremmy2's Avatar
Posts: 54   (View Stats)
Tremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant futureTremmy2 has a brilliant future
Was also looking for it yesterday. Guess JBR will get my monies. Meh, was really a coin flip anyways.
2013 Black Mica MazdaSpeed 3
COBB AccessPORT // JBR Power Path Stage II SRI // AutoTech HPFP // CP-E xFlex RMM Stage II // JBR Short Shift Plate RSB// JBR Solid Shifter Bushings // H&R Springs // CorkSport RSB
Tremmy2 is offline   Reply With Quote
 Old 07-17-2013, 07:48 PM   #211
El_Diablo's Avatar
Groans: 769
In two weeks..... oh wait, no... theirs is "soon".
 Old 07-18-2013, 08:36 AM   #212
Two soon???
-Derrick
The Following 8 Users Say Thank You to CorkSport For This Useful Post:
Awal (05-26-2015), Easter Bunny (07-18-2013), El_Diablo (07-18-2013), himurax13 (07-18-2013), jack_hammer (07-18-2013), jk_ms3 (07-18-2013), Kyle Undefined (07-18-2013), NJSPEED3 (07-20-2013)
 Old 07-18-2013, 03:10 PM   #213
CamMS3's Avatar
Two soon???
-Derrick
So....I am still confused...from what i have read you guys got all the kinks out by removing all the glue so they should be good to go?? Adding a new feature you might be keeping secret??
 Old 07-18-2013, 03:16 PM   #214
The problem with the batch with the glue was resolved a while back. We are making some changes based on input from customer and people here on the forums.
-Derrick
CamMS3 (07-18-2013), jack_hammer (07-18-2013)
 Old 07-18-2013, 03:17 PM   #215
jk_ms3's Avatar
Groans: 40
-Derrick
Called it!
 Old 07-18-2013, 03:19 PM   #216
Looking at incorporating a small turbo to work off the pressure, forcing more air into intake mani. Probably from an 85 turbo Chevy Sprint.
Awal (05-26-2015), CorkSport (07-18-2013), Easter Bunny (07-18-2013), Kyle Undefined (07-18-2013), Tokay444 (07-18-2013)
 Old 07-18-2013, 03:20 PM   #217
El_Diablo's Avatar
Groans: 769
Mounting style and drain.... what you guys wanna bet?
 Old 07-18-2013, 03:32 PM   #218
CamMS3's Avatar
-Derrick
Sweet good to hear, I will wait to see what comes out! ETA?
2010 Black Mica MS3 W/Tech Package and MazdaSpeed Light Weight Factory Rims
Current Fun Stuff: CS SRI Stage II, CS SSP/Weight, CS Bushings
Soon To Have Fun Stuff: Pump Internals and Exhaust Components
Down the Road Fun Stuff: Cobb AP and FMIC
 Old 07-18-2013, 05:27 PM   #219
evil MS3's Avatar
Groans: 55
God dammit...am I going to have to switch to the new one?
 Old 07-18-2013, 05:49 PM   #220
Voltwings's Avatar
Posts: 3,713   (View Stats)
-Derrick
Excuse me for asking as its probably already been answered else where, but were you guys doing anything for someone who had a glued lid blow? Thanks.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 07-18-2013, 05:50 PM   #221
Go back a few pages in this post, if you have a problem contact Kelly here at CorkSport, she will get you taken care of.
-Derrick
Easter Bunny (07-19-2013), El_Diablo (07-18-2013), Voltwings (07-18-2013)
 Old 07-18-2013, 05:51 PM   #222
Voltwings's Avatar
-Derrick
Thank you for catering to my laziness
Past:
-Sold-
-Sold-
Current:
rfinkle2 (08-01-2013)
 Old 07-20-2013, 10:38 AM   #223
seshomaru7's Avatar
Will be sending you back my OCC once a new one comes to me. Maybe it wasn't a problem with my hose routing after all? We will find out soon. Thank you Corksport!
The Following User Says Thank You to seshomaru7 For This Useful Post:
Tokay444 (07-23-2013)
 Old 07-23-2013, 01:37 AM   #224
Mastermind46's Avatar
Posts: 1,184   (View Stats)
Mastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the worldMastermind46 is the leader of the world
Was paranoid that I just couldn't find it on their site. Now I know.
2010 Mazdaspeed 3
- TR8 - HTP Under Route - Custom Cold Side - CS TP - HTP 3.5" Intake - Cobb AP V3 - DM Full Motor Mount Set - Forge V2 BPV - Autotech Internals - JBR Solid Shifter Bushings - CS DP (terMINATOR style) - Custom CBE - Whiteline RSB - Koni Sports - Eibach Springs - SPC Camber Arms - StopTech SS Lines and Pads - ATE Fluid - 55W DDM Tuning 6000K Lows - JBR OCC - DM SSP - CS LED Fogs - Maisonvi EGR Delete - DM FoST Intake Manifold - BNR S4 IWG -
Winter Beater/Exploration: 1998 Isuzu Rodeo
Autocross: 1992 Miata
Mastermind46 is offline   Reply With Quote
 Old 08-01-2013, 05:37 PM   #225
zMrManz's Avatar
Posts: 12   (View Stats)
zMrManz is an unknown quantity at this point
I'll be getting one of the first ones with the new changes. I ordered one a while back and was told about the new one coming out. I said I'd wait so that I could get the new version. Should get it the 2nd week of August.
2007 Mazda Mazdaspeed3 Manual 274HP 322TQ CP-E RMM, CP-E TMM, Tein springs, COBB AP, COBB BPV, COBB TIP, COBB SRI, CorkSport OCC
1987 Toyota Supra Turbo Manual 232HP 246TQ Stock (Sold)
1994 Volvo 850 Turbo Automatic 222HP 221TQ Stock (Sold)
zMrManz is offline   Reply With Quote
 Old 08-01-2013, 08:32 PM   #226
evil MS3's Avatar
Groans: 55
Any hints as to what's being changed?
I just got mine a couple months ago doo it kinda sucks that they're changing something again.....
 Old 08-01-2013, 11:09 PM   #227
zMrManz's Avatar
I'm honestly not sure. I don't think they told me what the new changes were going to be... If I was told, then it was over a month ago. So, it's very probable that I forgot. lol
 Old 08-02-2013, 04:54 AM   #228
El_Diablo's Avatar
Groans: 769
These are the two things that me and some of the people at CS had talked about & are the two most problematic issues with the can itself. I could also see the tubing being replaced with something better. The old stuff is/was junk.
 Old 08-02-2013, 05:56 AM   #229
evil MS3's Avatar
Groans: 55
yeah....I'd love a drain valve....
I replaced the the allen bolt with a regular hex bolt. The rubber grommet gave out after 2 drains so now I use teflon tape on the bolt...
I tried finding a drain valve but no one makes on in the right thread size and pitch...
 Old 08-02-2013, 06:30 AM   #230
El_Diablo's Avatar
Groans: 769
IIRC its an M8x1.25 thread pitch. I had found one a while back but I can't recall where it was. It was on the order of $30+ unless you ordered a large quantity. I also had the same issues with the o-ring. Your best bet is drilling it out and retapping to NPT & then adding a quarter turn valve.
 Old 08-02-2013, 06:54 AM   #231
evil MS3's Avatar
Groans: 55
Yeah I considered that too since Ace has 1/8" valves. I just didnt feel like pulling the can out lol
Might go ahead and do it regardless.
 Old 08-05-2013, 03:26 AM   #232
Well it looks like I lucked out with the timing on getting a job, should be some new products on the market in the next month or two.
2010 Mazdaspeed 3
 Old 08-05-2013, 01:02 PM   #233
seshomaru7's Avatar
I believe Corksport sent me a new one but I am not at liberty to discuss such things...right Corksport?
 Old 08-31-2013, 07:22 PM   #234
zMrManz's Avatar
Isn't she beautiful.
 Old 08-31-2013, 09:37 PM   #235
seshomaru7's Avatar
Ok maybe it's not the new one I got...nice!
 Old 03-01-2014, 12:51 PM   #236
zillmerm's Avatar
Posts: 53   (View Stats)
zillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud ofzillmerm has much to be proud of
So I cleaned my catch can V2 today and after about a month from when I lasted emptied realized the Allen bolt is corroded way worse than I remember. There were a lot of metal particles in the bottom of the cup I used to get this. Anyone have this issue?
zillmerm is offline   Reply With Quote
 Old 03-01-2014, 12:52 PM   #237
zillmerm's Avatar
Here's another
 Old 03-01-2014, 01:27 PM   #238
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Looks like you over torqued the bolt a few too many times.
 Old 04-11-2014, 10:48 PM   #239
monsterspeed3's Avatar
Posts: 16   (View Stats)
monsterspeed3 is infamous around these partsmonsterspeed3 is infamous around these parts
Groaned at 21 Times in 4 Posts
Had the same problem with my ram air intake plus fmic kit! Water ended up getting into the filter threw the hood scoop and making my car run like crap and shut off. Sent pics and pretty much said it was my falt and wouldn't replace it anything for that matter. Very disappointed in the product and customer service.
Sent from my SCH-I545 using Tapatalk
monsterspeed3 is offline   Reply With Quote
 Old 04-17-2014, 10:18 AM   #240
racingrayson's Avatar
Posts: 190   (View Stats)
racingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the world
When did this happen? I messaged them asking about that specific problem and they said they hadn't ever had an issue with it. My fear of just that is why I always put a healthy amount of oil on my filter.
racingrayson is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/oil-catch-can-fix-135275/
Did OCC can install yesterday. This showed up hour after, cleared it, and it came back again today. My Idle AFR is about 15.75. Is this meaning that I messed up the catch can somehow? : mazda This thread Refback 06-28-2015 11:23 AM
Oil catch can fitting options This thread Refback 05-14-2014 08:56 PM
New turbo project, BNR S3 - Mazda 3 Quebec This thread Refback 01-14-2014 11:39 AM
Oil catch can fitting options ? Mazda MPS Owners Club This thread Refback 05-31-2013 09:53 AM
Oil catch can fitting options ? Mazda MPS Owners Club This thread Refback 05-02-2013 12:57 PM
À tous ceux qui ont des OCC Corksport - Mazda 3 Quebec This thread Refback 01-28-2013 07:27 PM
Oil catch can fitting options ? Mazda MPS Owners Club This thread Refback 01-18-2013 10:22 AM
oil catch can mroclimbr Mazdaspeed3/6 General Discussion 13 04-04-2011 03:20 PM
Oil Catch Can jstcruzin CX-7 > Engine, Transmission & Driveline 27 01-22-2011 10:41 AM
DIY Oil Catch Can drewsifer86 MazdaSpeed 3 - How-To's 14 07-22-2010 09:02 PM
Now this is a catch can! 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 15 06-28-2010 03:43 PM
Oil Catch Can dizzin9 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 01-02-2010 05:27 PM
Page generated in 0.57860 seconds with 37 queries
