![]() | | #241 | ![]() |
![]() Join Date: Nov 2013 Location: Atascadero, CA
Groaned at 21 Times in 4 Posts
| Not Ranked : 0 score
Sent from my SCH-I545 using Tapatalk | |
![]() | | #242 | ![]() |
![]() Join Date: Jul 2012 Location: Stillwater, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
Did you oil the filter prior to installation? I've driven in some pretty heavy downpours at 80 mph and never had an issue. Cutting a narrow slot across the hood ducting would completely alleviate the problem, and would evacuate a negligible amount of air. | |
![]() | | #243 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
(Thread Starter) | Not Ranked : 0 score Be careful with over oiling your filter, you can kill the MAF pretty quickly by doing that.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #244 | ![]() |
![]() | | #245 | ![]() |
I've head of that problem but the design of the air filter housing with this kit does a pretty good job of preventing it. The oil hits and gets stuck to the bottom plate of the airbox. Anything that runs off the bottom plate towards the MAF will just run along the outside or the radius in front of the MAF and get harmlessly eaten by the turbo. | |
![]() | | #246 | ![]() |
![]() Join Date: Feb 2018
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score I just got a cobb turbo inlet for my 08 speed 3 and when i took off my cobb intake to install the turbo inlet i noticed a little bit of oil splashed inside one of the pipes so I want to get an oil catch can before any major problems arise. Do you guys know if corksport still has issues with their catch can or has it all been resolved? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/oil-catch-can-fix-135275/ | ||||
| Did OCC can install yesterday. This showed up hour after, cleared it, and it came back again today. My Idle AFR is about 15.75. Is this meaning that I messed up the catch can somehow? : mazda | This thread | Refback | 06-28-2015 11:23 AM | |
| Oil catch can fitting options | This thread | Refback | 05-14-2014 08:56 PM | |
| New turbo project, BNR S3 - Mazda 3 Quebec | This thread | Refback | 01-14-2014 11:39 AM | |
| Oil catch can fitting options ? Mazda MPS Owners Club | This thread | Refback | 05-31-2013 09:53 AM | |
| Oil catch can fitting options ? Mazda MPS Owners Club | This thread | Refback | 05-02-2013 12:57 PM | |
| À tous ceux qui ont des OCC Corksport - Mazda 3 Quebec | This thread | Refback | 01-28-2013 07:27 PM | |
| Oil catch can fitting options ? Mazda MPS Owners Club | This thread | Refback | 01-18-2013 10:22 AM | |
| oil catch can | mroclimbr | Mazdaspeed3/6 General Discussion | 13 | 04-04-2011 03:20 PM |
| Oil Catch Can | jstcruzin | CX-7 > Engine, Transmission & Driveline | 27 | 01-22-2011 10:41 AM |
| DIY Oil Catch Can | drewsifer86 | MazdaSpeed 3 - How-To's | 14 | 07-22-2010 09:02 PM |
| Now this is a catch can! | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 15 | 06-28-2010 03:43 PM |
| Oil Catch Can | dizzin9 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 01-02-2010 05:27 PM |
