Like Tree8Likes
 Old 07-26-2014, 08:31 AM   #81
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Originally Posted by Tweaek View Post
Any word on whether these fit with the 17x9 rpf1 +45?
I'm pretty sure they wont because of the straight face on the 9's. If you got the 8's they are more bubbled.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 07-30-2014, 09:52 PM   #82
Tweaek's Avatar
Posts: 319   (View Stats)
Tweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the world
Hopefully someone can confirm as that's a huge factor for me and my auto-x setup
Tweaek is offline   Reply With Quote
 Old 07-31-2014, 09:32 AM   #83
SpencerC's Avatar
Posts: 2,159   (View Stats)
Wish I knew. I don't have any info from previous customers that I can find confirming that sizing though.
 Old 07-31-2014, 08:31 PM   #84
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
You could use the template and check against the wheel?
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
The Following 2 Users Say Thank You to udntknw For This Useful Post:
Code Monkey (07-31-2014), Easter Bunny (07-31-2014)
 Old 08-09-2014, 10:04 PM   #85
Hal
Hal's Avatar
Posts: 233   (View Stats)
Hal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the world
Spencer/Kim,
I left ya a voice mail. Having an issue.
It appears that either bracket holes for the caliper were not bored enough, or the allen bolt is too long. Either way, there is play of about a few millimeters when fully torqued. The caliper clangs around a bit. It effects 3 of the 4 holes.
For now I put small spacers in to fix, and the brakes certainly work, but with the spacer i am sacrificing the sweep area of the pad on the rotor and am worried about overall integrity....
www.emeraldtuning.com
twittter: @emeraldtuning
YouTube: https://www.youtube.com/user/EmeraldTuning
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Heavy Shift Knob
JBR Flaps
Buddy Club Custom 3" Exhaust
Koni Yellows
Corksport 4-Piston Brake Upgrade
Corksport Springs
Corksport Adjustable End Links
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
Hal is offline   Reply With Quote
 Old 08-11-2014, 06:00 PM   #86
SaveMelMac's Avatar
Posts: 485   (View Stats)
Just installed this kit this weekend. Overall it's a nice kit but I do have to nit picks with the kit.
1. For the cost of the kit I would expect the brake lines to be one piece. Not use one adapter one each end. Even though it should be fine, I always think for the brake system the less adapters the better.
2. In order to run off the shelf brake pads you have to modify the inner pads and cut off the little extra nub. I do believe this was talked about in some other thread. I check dozens of pad manufactures everyone has the extra nub.
 Old 08-11-2014, 06:10 PM   #87
SpencerC's Avatar
@Hal;
I didn't hear about a message, I'll look into it though first thing tomorrow.
@SaveMelMac;
Oddly you are the first to worry about the lines not being one piece. I do get the thought though, not sure why we went with it being the way it is.
I have seen some pads that need the nub ground off, and some that don't. EBC pads I've seen needed it ground off, but I've seen Hawk that were fine. Not sure what's up with that.
Easter Bunny (08-11-2014)
 Old 08-11-2014, 06:20 PM   #88
Hal
Hal's Avatar
Spencer,
I received an email from Kelly stating engineering was looking in to it. If I could get the new hardware by Friday, I can sit down Saturday and swap em out real quick and send the originals back.
They look boss, and overall feels better, but I'm just worried about integrity over the long term with the spacers.
Thanks!
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Flaps
Koni Yellows
Corksport Springs
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
 Old 08-11-2014, 06:57 PM   #89
SaveMelMac's Avatar
The only brand I saw that didn't have the nub was hawk. Basically I was referring to stock off the shelf pads you could pick up at any auto parts store. I don't think I made that clear in my first post. I work at an auto parts store and I looked at every manufacturer I could find, I probably spent too much time. More than my boss would like lol.
Just trying to save some people some time if they decide to go that route and grind off the nubs before you start the job. Just needs to be done on the inner pads.
The Following User Says Thank You to SaveMelMac For This Useful Post:
SpencerC (08-12-2014)
 Old 08-12-2014, 03:48 PM   #90
Hal
Hal's Avatar
I've got a sweet squeal on my passenger side now...i think it has to do with running the spacers....occassional sound, nothing too bad. once the new hardware arrives I will report back.
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Flaps
Koni Yellows
Corksport Springs
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
The Following User Says Thank You to Hal For This Useful Post:
 Old 08-12-2014, 04:15 PM   #91
SpencerC's Avatar
Thanks for keeping us updated!
 Old 08-12-2014, 05:07 PM   #92
Hal
Hal's Avatar
No problem. Is the new hardware on the way?
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Flaps
Koni Yellows
Corksport Springs
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
 Old 11-04-2015, 02:48 AM   #93
drago86's Avatar
Posts: 12   (View Stats)
drago86 is a jewel in the roughdrago86 is a jewel in the roughdrago86 is a jewel in the roughdrago86 is a jewel in the rough
I hate to bump an old thread with this but I have some serious concerns about the fatigue life of the caliper brackets, especially if they are aluminum. Was a fatigue analysis done on this part? How many cycles?
There should not be 90 degree angles between the caliper and it's mounting tabs, even with fillets. There's a reason you don't see this on OEM designs, or any of the major aftermarket brake manufacturers. The tabs are always blended and webbed as much as is possible. The brake caliper brackets are NOT the place to try and save a few ounces by minimizing material.
drago86 is offline   Reply With Quote
 Old 11-06-2015, 10:46 AM   #94
The brackets which hold the aluminum caliper to the knuckle are steel.
-Derrick
Easter Bunny (11-06-2015), MS3Shadow (11-06-2015)
 Old 11-06-2015, 11:07 AM   #95
taf0422's Avatar
Groans: 192
Comes in fighting like he knows the material and is mastermind in brakes....
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 4 Users Say Thank You to taf0422 For This Useful Post:
Easter Bunny (11-06-2015), MS3Shadow (11-06-2015), PhillyCheese (11-06-2015), Raider (11-06-2015)
 Old 11-06-2015, 02:23 PM   #96
-Derrick
Steel fatigues man.
(Puffs joint)
It's a conspiracy.
PhillyCheese (11-06-2015), silvapain (11-06-2015)
 Old 06-26-2017, 09:09 AM   #97
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Ok, old thread is old but as a romanian saying states one needs an old chicken to make the soup good.
So after these years I'd like to hear some opinions. I want to change my factory callipers, they're pretty old and I feel they don't perform as I'd like (mainly street spirited driving, occasional track/circuit racing).
Right now I have two options:
1. brand new factory callipers;
2. some decent aftermarket callipers that are proven to perform well under these conditions.
Therefore I'd like to hear a few opinions apart from the stupid colour mismatch (my car is blue for I'll be good with silver callipers in the back until I paint them with some Foliatec Blue RS paint).
I'd also like to know how much larger rotors can these callipers accommodate and where can I source them (330mm rotors would be nice, even though not necessarily a must).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-26-2017, 06:37 PM   #98
SaveMelMac's Avatar
Been running these for a few years now and about 20k miles no issues what so ever. Just driven on the street. I have been happy. Sorry that's the only input I can contribute
 Old 06-26-2017, 08:14 PM   #99
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
I had these on my first pu and they were great for street driving. I recently was in the market to upgrade braking system as I needed new rotors and looked at these again. For the price I was going to pay for these calipers and a pair of rotors was setting me back $1200. I kept searching and found a complete BBK from wilwood 6 pot and 2 piece rotors, pads and SS lines for $1150 on Edge. I'm not knocking the CS calipers as they're great if you just want a caliper and still have life left in your rotors, but if you're upgrading all components you can get an entire kit for just a few more Hondos. And that weight redux!
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Rear brake caliper piston wont go in? AFcadet MazdaSpeed 3/6 - Suspension & Brakes 19 09-19-2012 04:06 PM
Product Release! CorkSport LED 3rd Brake Light for 2010+ Mazda3 Sedan CorkSport CorkSport 0 04-03-2012 11:20 AM
Page generated in 0.41773 seconds with 30 queries
