| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
![]() Join Date: Apr 2011 Location: Hatboro, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 731
| Not Ranked : 0 score Nice! If I didn't already have the CP-e I would have considered this one. Nice how you can convert it to an SRI. Kinda curious who the "competitor" is that you are comparing to. I'm thinking it must be AEM/Mazdaspeed because CP-e doesn't make those kind of improvement claims (+33 hp).
__________________ 2011 MS3 - SOLD 2000 Miata LS, Flyin Miata Turbo'd (GT2560R), 3" TBE, Megasquirt EMS, 650cc injectors |
![]() Join Date: Jan 2012 Location: darlington, md
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 494
| Not Ranked : 0 score I do like how you can run a short ram or a cold air with one kit |
-Derrick | |
| Not Ranked : 0 score Very cool. (especially the convertibility between sri and cai)... really great idea, imo. @CorkSport, any plans on 3" housings etc. for BT applications? |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score What is the diameter of the piping? I just ordered it anyway but if it is 3" that would be awesome. Also like @rfinkle2 said a 3" MAF and 3" inlet would be great.
__________________ www.MOTOIQ.com Beater Titan |
__________________ 2011 MS3 - SOLD 2000 Miata LS, Flyin Miata Turbo'd (GT2560R), 3" TBE, Megasquirt EMS, 650cc injectors | |
| Not Ranked : 0 score I know about the SRI and TIP, was just hoping the CAI portion was 3"
| The Following User Says Thank You to Todd98SE For This Useful Post: | rfinkle2 (08-23-2012) |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Can this be adapted to an existing CS SRI+TIP setup?
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | rfinkle2 (08-23-2012) |
| Not Ranked : 0 score Yes, they sell the upgrade CAI portion separately. $99
Groans: 890
| Not Ranked : 0 score Ouch. Considering a $30 difference in package price, $99 kinda hurts.
| Not Ranked : 0 score Didn't notice that, but yeah that kind of sucks. Oh well, CS is a good company.
| The Following User Says Thank You to Todd98SE For This Useful Post: | rfinkle2 (08-22-2012) |
(Thread Starter) | Not Ranked : 0 score The CAI portion is 3 inches. -------------------------------- The CAI is sold as an apples to apples version without the TIP to go against the Injen and AEM intakes out on the market. If you add the TIP (which there is an option to do this) the price for the complete intake CAI to TIP is $349. We knew people would want to add the CAI to existing SRI intakes so we setup the separate option to buy just the cold air part at $99. Make sense? -Derrick Last edited by CorkSport; 08-23-2012 at 08:11 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to CorkSport For This Useful Post: | rfinkle2 (08-23-2012) |
![]() Join Date: May 2012 Location: North Las Vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 116
| Not Ranked : 0 score On my 2012 MS3 the fender liner is not vented like first gens. Thus is the only cold air, or outside air being pulled through the small triangle opening in bottom corner of the grill? Obviously, the cold air intake is pulling the air from a lower location in the engine compartment so the air will be denser since heat rises. However, since there is no air box; a certain amount of air must be pulled from the engine compartment at WOT. Lastly, did your testing results determine if your cold air or short ram with intake box resulted in the lowest inlet air temperature? Thanks for making great products!
__________________ CorkSport: Fog light Kit/LED Rear Bumper Lights/Shifter Bushing Kit/License Plate Relocate/Front Lower Arm Bar/Camber Plates/Four Point Rear Chassis Bracing/Camber Arms/ Cobb: AP Version 3/ AEM: Port Injection WME/ Dominant Engineering: Adjustable Rear Toe Arms - Heim Joints/ Tri-Point Engineering: Adjustable Rear Sway Bar - Race/ Whiteline: Front and Rear Control Arm Bushings - Caster Correction/Bump Steer Correction/Front Sway Bar/ KW: Variant III/ POWERGRID: Front End Links/ JBR: Stage 2 Catch Can Kit/ CP-E: Catted DP/Triton/TMIC/Stage 2 Rear, Engine & Transmission Mount/ Sure: Full3 Aeros/AGS Shift Nob/ HTP: Battery Tray/ NGK: One Step Colder/ AutoTech: Internals/ AutoEXE: Oversized Cold Pipe/Boost Tubes/ AEM: Oversized Air Filer -- 21-2145DK/ Renewable Lubricants Inc: Bio Synthetic HD Super High Performance 5W40 Low Ash/ TSW: Nurburgring 18X8.5 + 45/ BFGoodrich: G-Force Sport COMP 2 255/35R18 (runs wide)/ ![]() |
![]() Join Date: Nov 2010 Location: Nashville,TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Neutral : +1 score
__________________ 2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD 2004 Corvette Z06 SCCA Bowling Green Match Tour - GS 1st place SCCA Wilmington Champ Tour - GS 2nd place SCCA National Championship - GS 3rd place SCCA Grenada Match Tour - AS 1st place | |
| The Following 2 Users Say Thank You to ztnedman1 For This Useful Post: | BigjohnB20 (08-30-2012), Johnny_Law (09-02-2012) |
![]() Join Date: Jun 2010 Location: Sacto, CA (Rancho Cordova)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
__________________ 2010 MazdaSpeed3 - Black Mica COBB AP On Stage1+CS+TIH 91 BTv200 | CorkSport SRI/TIP | Forge BPV v1 | JBR Knob + Bushings | TRZ Poly RMM | CorkSport RSB | Eibach ProKit | SPC Rear Camber Arms | TSW TrackStar5 18x8 ET50 | 225/40/18 Toyo Proxes 4+ | G2 Red Calipers | RallyArmor Urethane MudFlaps | Hella SuperTones | Viper Security | Kenwood/Hertz/Audison Audio | Weather Tech FloorLiners | Emblem Blackout | Window Tint - 65% Front/15% Rear |
![]() Join Date: Jun 2011 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
Yes there is air pulled at WOT from the engine bay area but at that point all the air is being drawn from the outside of the car. The real difference is stop and go or lower speeds. Once you drive for a bit engine air is very close to outside air. Last edited by Gwynne; 08-30-2012 at 12:30 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #19 | ![]() |
| Not Ranked : 0 score | |
| The Following User Says Thank You to Gwynne For This Useful Post: | E.Tinker (08-30-2012) |
![]() | | #20 | ![]() |
__________________ 2010 MazdaSpeed3 - Black Mica COBB AP On Stage1+CS+TIH 91 BTv200 | CorkSport SRI/TIP | Forge BPV v1 | JBR Knob + Bushings | TRZ Poly RMM | CorkSport RSB | Eibach ProKit | SPC Rear Camber Arms | TSW TrackStar5 18x8 ET50 | 225/40/18 Toyo Proxes 4+ | G2 Red Calipers | RallyArmor Urethane MudFlaps | Hella SuperTones | Viper Security | Kenwood/Hertz/Audison Audio | Weather Tech FloorLiners | Emblem Blackout | Window Tint - 65% Front/15% Rear | |
![]() | | #21 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| Not Ranked : 0 score CARB exemption? Awesome product though. Great idea being able to switch it so easily.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
| The Following User Says Thank You to ABolewski For This Useful Post: | Gwynne (08-30-2012) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score They'd probably have to shell out another $10K or so for CARB of give them a separate EO# for what amounts to about a foot of pipe. Convertible works for me.
![]() | | #23 | ![]() |
| Not Ranked : 0 score Exactly. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score As long as there is a CARB number on some part of the intake your smog guy probably isn't going to give you any trouble even with the CAI portion attached.
| The Following User Says Thank You to Todd98SE For This Useful Post: | CorkSport (08-31-2012) |
![]() | | #25 | ![]() |
Assuming you tested on the same vehicle and the same day, did the CAI or SRI with Cold Air Box resulted in the coldest air intake temperature? Since the CAI doesn't have a box, it will be less restrictive at WOT? Does the Cold Air Box still pull part of air from the stock inlet system? If not can it be left intact so I can plum the outlet into the air box? Thanks for your time!!
__________________ CorkSport: Fog light Kit/LED Rear Bumper Lights/Shifter Bushing Kit/License Plate Relocate/Front Lower Arm Bar/Camber Plates/Four Point Rear Chassis Bracing/Camber Arms/ Cobb: AP Version 3/ AEM: Port Injection WME/ Dominant Engineering: Adjustable Rear Toe Arms - Heim Joints/ Tri-Point Engineering: Adjustable Rear Sway Bar - Race/ Whiteline: Front and Rear Control Arm Bushings - Caster Correction/Bump Steer Correction/Front Sway Bar/ KW: Variant III/ POWERGRID: Front End Links/ JBR: Stage 2 Catch Can Kit/ CP-E: Catted DP/Triton/TMIC/Stage 2 Rear, Engine & Transmission Mount/ Sure: Full3 Aeros/AGS Shift Nob/ HTP: Battery Tray/ NGK: One Step Colder/ AutoTech: Internals/ AutoEXE: Oversized Cold Pipe/Boost Tubes/ AEM: Oversized Air Filer -- 21-2145DK/ Renewable Lubricants Inc: Bio Synthetic HD Super High Performance 5W40 Low Ash/ TSW: Nurburgring 18X8.5 + 45/ BFGoodrich: G-Force Sport COMP 2 255/35R18 (runs wide)/ ![]() | |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I got some answers from the engineer:
It does not pull from the stock system. You would have to build something to connect the two but most of the factory stuff can be left in. Obviously the stock intake box must be eliminated. | ||
![]() | | #27 | ![]() |
| The Following User Says Thank You to Johnny_Law For This Useful Post: | Gwynne (09-10-2012) |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! Corksport Stage One Power Series Short Ram Intake for Mazdaspeed 3 | CorkSport | CorkSport | 1 | 02-28-2012 07:16 PM |
| Product Release! Corksport 2010+ Mazda 3/Mazdaspeed 3 LED Bumper Lights | CorkSport | CorkSport | 8 | 02-15-2012 10:26 PM |
| CorkSport Product Release! CorkSport 2007-2009 Mazdaspeed 3 Front Mount Intercooler for SRI | CorkSport | CorkSport | 6 | 11-14-2011 03:15 PM |
| CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available | CorkSport | CorkSport | 0 | 08-05-2011 06:30 PM |
