Like Tree14Likes
 Old 04-10-2014, 05:30 PM   #1
Thumbs up Product Release! CorkSport Mazdaspeed 3 Aluminum Radiator
The 2010-2013 Mazda 3 is known to have a lot of strengths but the OEM radiator is not one of them. The factory radiator core sits at a mere 13 mm wide doing its best while struggling to keep your coolant cool. The CorkSport Mazda 3 Aluminum Radiator is here to stand up to the […]
More...
Celestspeed3 and [R]usty like this.
The Following 20 Users Say Thank You to CorkSport For This Useful Post:
3starmagnum (04-12-2014), 86AmishMs3 (04-11-2014), A_tired_goose (08-19-2014), beachshoer (04-10-2014), bioevolve (04-10-2014), Celestspeed3 (04-10-2014), derek13p (04-11-2014), Dralphy (04-10-2014), Easter Bunny (04-10-2014), El_Diablo (04-11-2014), Fjager (04-10-2014), Hush (04-11-2014), Ireland (04-10-2014), jdmage_mx5 (04-10-2014), JSmith (04-10-2014), PapaSmurf (04-10-2014), rtabagaboy (04-11-2014), swsmailman (04-10-2014), Zdraveca (04-11-2014), [R]usty (04-10-2014)
 Old 04-10-2014, 05:33 PM   #2
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
This is awesome! I might have to look into this.
Inb4whereisthedata
 Old 04-10-2014, 05:33 PM   #3
[R]usty's Avatar
Posts: 2,204   (View Stats)
Wow really? Badass!
2010 Mazdaspeed3 w/tech
 Old 04-10-2014, 05:36 PM   #4
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Inb4whereisthedata
I actually wouldnt mind seeing how much lower the coolant temps are compared to stock, wouldnt be that hard of a test. I mean if youre going to spend $350 on an aftermarket radiator there should be a decent difference.
MZRSPEED likes this.
860whp/677wtq
2.7 V6 Ecoboost
The Following 4 Users Say Thank You to PapaSmurf For This Useful Post:
breakfstincluded (04-10-2014), El_Diablo (04-11-2014), Mast (08-19-2014), Mauro_Penguin (04-11-2014)
 Old 04-10-2014, 05:36 PM   #5
swsmailman's Avatar
Posts: 1,118   (View Stats)
Really awesome! Would love to see some data and review from testers as I do wonder how much this would help in Texas.
2013 Liquid Silver MazdaSpeed
The Following 2 Users Say Thank You to swsmailman For This Useful Post:
derek13p (04-11-2014), PapaSmurf (04-10-2014)
 Old 04-10-2014, 05:47 PM   #6
I was scrolling down just to mention you lol. It would be hard for this to not be an improvement over stock.
 Old 04-10-2014, 06:01 PM   #7
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
@CorkSport;
What test data do you have for this? Any that you are willing to share?
The Following 3 Users Say Thank You to JSmith For This Useful Post:
El_Diablo (04-11-2014), Mauro_Penguin (04-11-2014), PapaSmurf (04-10-2014)
 Old 04-10-2014, 06:02 PM   #8
In before gen Juan and ms6 guys bitching they didn't get one.
sidekick likes this.
The Following 18 Users Say Thank You to Easter Bunny For This Useful Post:
08cosmic3 (04-10-2014), Alexander (04-20-2014), ArmanRus (04-12-2014), Boost_creep (04-11-2014), Code Monkey (04-10-2014), CorkSport (04-10-2014), Cujo (04-11-2014), Darth_Nuruodo (04-10-2014), derek13p (04-11-2014), El_Diablo (04-11-2014), faeker (04-11-2014), Fatpig78 (04-11-2014), magicka (04-10-2014), Mauro_Penguin (04-11-2014), motherfnmonsta (04-10-2014), ms6mil (04-10-2014), PapaSmurf (04-10-2014), sidekick (04-13-2014)
 Old 04-10-2014, 06:09 PM   #9
Where the fuck is the MS6 version?!?!?!?
The Following 11 Users Say Thank You to Code Monkey For This Useful Post:
ABolewski (04-12-2014), derek13p (04-11-2014), Easter Bunny (04-10-2014), El_Diablo (04-11-2014), emag remrofni (04-14-2014), Fatpig78 (04-11-2014), jambisgone696 (04-10-2014), Mazdazilla6 (04-11-2014), ms6mil (04-10-2014), SarcasticOne (04-10-2014), trancehead (04-11-2014)
 Old 04-10-2014, 06:13 PM   #10
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Originally Posted by JSmith View Post
@CorkSport;
Give me mid season. I'll get you all the data you could ever hope for.
Fueled by the haters.
The Following 5 Users Say Thank You to Celestspeed3 For This Useful Post:
daafisch (04-12-2014), Easter Bunny (04-10-2014), El_Diablo (04-11-2014), Mauro_Penguin (04-11-2014), nilashish (04-10-2014)
 Old 04-10-2014, 06:47 PM   #11
jdmage_mx5's Avatar
Does this still fit for those running a FMIC where the piping runs in between the intake manifold and radiator? Such as the cxracing or CPE kit?
 Old 04-10-2014, 07:08 PM   #12
someguy's Avatar
Posts: 914   (View Stats)
Does the system use more coolant because of the bigger core? Is it lighter weight than the stock radiator?
I guess in the heat of summer this will help keep BAT's down because the block won't be so hot which is pretty cool.
 Old 04-10-2014, 07:09 PM   #13
markos213's Avatar
Posts: 166   (View Stats)
markos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond reputemarkos213 has a reputation beyond repute
No gen one love?
markos213 is offline   Reply With Quote
The Following 3 Users Say Thank You to markos213 For This Useful Post:
08cosmic3 (04-10-2014), BruhhWill (04-11-2014), Ferdball (04-12-2014)
 Old 04-10-2014, 07:09 PM   #14
do you have any idea what a radiator is, how it works or what it does?
breakfstincluded (04-10-2014), El_Diablo (04-11-2014), faeker (04-11-2014), Mauro_Penguin (04-11-2014), MechEnix (04-10-2014), [R]usty (04-10-2014)
 Old 04-10-2014, 07:13 PM   #15
someguy's Avatar
Obviously yes....they are legit questions.
Coolant amount, could be the same if it's just bigger fins/surface area...could be more if the actual core and passages are longer/bigger.
BAT's lower if the engine block isn't heat soaking everything (ie efficiently transfering heat through the radiator)...but won't make much difference unless your stock radiator wasn't able to keep up, since the thermostat should maintain a relatively constant temp under normal conditions.
Don't be a prick.
The Following User Says NO Thank You to someguy For This Un-useful Post:
Easter Bunny (04-11-2014)
 Old 04-10-2014, 07:20 PM   #16
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
this might just be the must have item for a lot of us that have hot summers and fmic's. thank you
Any chance for a group buy on this item
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Last edited by Fjager; 04-10-2014 at 07:20 PM. Reason: MSF Database - Automerged Doublepost
Fjager is offline   Reply With Quote
The Following User Says Thank You to Fjager For This Useful Post:
someguy (04-10-2014)
 Old 04-10-2014, 07:37 PM   #17
rolanblack's Avatar
Posts: 2,110   (View Stats)
Cool story bro but is clearance tight where brake booster/Mani is at with the fan back on?
 Old 04-10-2014, 07:49 PM   #18
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
I was going to overlook this, but I......
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following 5 Users Say Thank You to ms6mil For This Useful Post:
derek13p (04-11-2014), Easter Bunny (04-11-2014), El_Diablo (04-11-2014), kby (04-11-2014), SLOWHATCH (04-11-2014)
 Old 04-10-2014, 08:18 PM   #19
Fjager's Avatar
looking at where the mounting points are from the pictures it bulges more forward to the ac condenser than to the rear toward the intake mani, it should be the same clearance or just a tad less but not enough to mess with FMIC piping.
FMIC W/DIY Sprayer
CPE DP
 Old 04-10-2014, 10:15 PM   #20
magicka's Avatar
Posts: 520   (View Stats)
I was going to bitch, but you can get a Koyo for the GenWin.
2009 CWP MS3 GT
The Following 5 Users Say Thank You to magicka For This Useful Post:
08.5MS3 (04-11-2014), breakfstincluded (04-11-2014), Easter Bunny (07-08-2014), maisonvi (04-11-2014), that1rowdyracer (04-12-2014)
 Old 04-11-2014, 06:53 AM   #21
Don't be a prick.
Since you are to ingnorant to see how stupid your questions are let me answer them for you.
No
No
No
Now shut the fuck up.
faeker (04-11-2014), Fatguy729 (04-11-2014)
The Following 2 Users Say NO Thank You to Easter Bunny For This Un-useful Post:
emag remrofni (04-14-2014), someguy (04-11-2014)
 Old 04-11-2014, 07:25 AM   #22
someguy's Avatar
No
No
No
Explain then oh wise godly one, until then you're just full of shit.
*edit*
Thinking about this, honestly can you explain? If I'm missing something here...the only one that is pretty unlikely is lighter weight, although yes I think it would be possible (more thermal efficiency through better materials, thinner but more plentiful fins, etc) it should have been obvious that that's probably not the case. The other two seem to make sense.
 Old 04-11-2014, 07:47 AM   #23
Fatpig78's Avatar
Posts: 127   (View Stats)
Fatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond reputeFatpig78 has a reputation beyond repute
Let us know how many chicks we can pick by saying we have an aftermarket radiator
Celestspeed3 likes this.
07 Cosmic Blue Mica MS3 GT:
Cobb AP, Torq R3 Street; Sure CounterWeight; Corksport CAI/TIP; Cobb Shift Knob on Stratified extension w/ TWM shortshifter; Corksport Internals; Custom straight 3 inch catback exhaust by RPM
Fatpig78 is offline   Reply With Quote
The Following 2 Users Say Thank You to Fatpig78 For This Useful Post:
bstover17 (04-11-2014), Easter Bunny (07-08-2014)
 Old 04-11-2014, 08:03 AM   #24
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
This is terrible marketing, if your going to sell a product you need to tell the consumer why they should replace their radiator with this one. What will this do for me? Or how will this be better?
dereeek likes this.
timmcc02 is offline   Reply With Quote
The Following 7 Users Say Thank You to timmcc02 For This Useful Post:
breakfstincluded (04-11-2014), dereeek (04-11-2014), El_Diablo (04-11-2014), Fatguy729 (04-11-2014), JSmith (04-29-2015), Mauro_Penguin (04-11-2014), [R]usty (04-11-2014)
 Old 04-11-2014, 09:20 AM   #25
A larger radiator is not a product that need explanation. If you needed one you would know.
A larger radiator will have a larger capacity which will increase the thermal mass of the coolant meaning it will take longer for the coolant to overheat. it will also have longer fins and possibly a better optimized fin configuration to aid the radiator in shedding heat.
 Old 04-11-2014, 09:40 AM   #26
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
@Easter Bunny;, the sales of such a radiator could benefit by providing data points of why theirs is better. @CorkSport; should know by now that we demand data. Why they continue not to provide such data upon release is really quite baffling. This practice isn't the most confidence inspiring and always leaves people feeling like they're hiding something. Why do we continually have to beg and plead @CorkSport; for information that the average consumer needs to make an informed purchase? Why must we continually test their products for them?
Don't get me wrong, I'm happy to see new products, I just wish they would wake the fuck up and give us some hard data on a release for once, clearly showing how this will benefit us.
Also, by data, I mean give us some temp comparisons such as cool down, warm up, heat soak at a dead stop and so on. Not just "well it's bigger, it has to be better!!" because that's not always the case.
Mauro_Penguin likes this.
Last edited by El_Diablo; 04-11-2014 at 09:40 AM. Reason: MSF Database - Automerged Doublepost
The Following 10 Users Say Thank You to El_Diablo For This Useful Post:
breakfstincluded (04-11-2014), daafisch (04-15-2014), dereeek (04-11-2014), gmoney542 (04-12-2014), JSmith (04-11-2014), Mauro_Penguin (04-11-2014), mize13 (04-14-2014), PapaSmurf (04-11-2014), Pu Manchu (04-12-2014), [R]usty (04-11-2014)
 Old 04-11-2014, 09:41 AM   #27
JSmith's Avatar
Groans: 106
Larger is subject to interpretation. What is larger? I think you mean thermal capacity of the cooling system instead of thermal mass of the coolant.
Data is what we need to verify that this is indeed an upgrade. A poorly designed radiator with a larger capacity is not, and will not respond the same as, a radiator with an optimized fin configuration.
The Following 2 Users Say Thank You to JSmith For This Useful Post:
El_Diablo (04-11-2014), someguy (04-11-2014)
 Old 04-11-2014, 09:51 AM   #28
someguy's Avatar
That was a better response, still a bit vague but not as rude lol
Yeah, pretty obvious when you need cooling system upgrades...you can't keep coolant temps within operating temperature.
Still would be interesting to see what the actual benefits are rather than just it's bigger.
 Old 04-11-2014, 10:06 AM   #29
El_Diablo's Avatar
Groans: 769
I'm also interested in the clearance allowed by the new radiator. Both front and rear.
 Old 04-11-2014, 10:34 AM   #30
I meant what i said, but both items are related
its a radiator not rocket science. I will go out on a limb and say without a doubt that this is better than the stock one. I challenge someone to install this and show scientifically that it did not improve the coolant temperatures. As i stated before simply allowing more coolant into the system is going to provide a tremendous benefit.
 Old 04-11-2014, 10:38 AM   #31
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
If I didn't need SEALS and a larger METH TANK I'd be picking this thing up now. 3 kids needing shit like clothing and food make it hard to spend car money.
Mods: stock
The Following 4 Users Say Thank You to faeker For This Useful Post:
El_Diablo (04-11-2014), Mauro_Penguin (04-11-2014), MS3G35 (04-11-2014), speed3okie (04-14-2014)
 Old 04-11-2014, 11:51 AM   #32
someguy's Avatar
Again, correct me if I'm wrong, but given that there is a thermostat to control coolant temperature, unless you are exceeded the thermal capacity of the cooling system this will provide zero benefits.
Would be relatively easy to prove scientifically that it will not improve coolant temperatures up here in the snowy white north lol
 Old 04-11-2014, 12:50 PM   #33
timmcc02's Avatar
You are absolutely right, while not rocket science, my point was they didn't even say it increases coolant capacity of the system and by how much, therefore from their description they are marketing this as an appearance modification
 Old 04-11-2014, 01:35 PM   #34
Don't you have a 6?
 Old 04-11-2014, 01:49 PM   #35
jrotaryb's Avatar
Posts: 416   (View Stats)
Do you regularly over-heat in track sessions??
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
 Old 04-11-2014, 01:53 PM   #36
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Don't you have a 6?
Not a chance
 Old 04-11-2014, 06:00 PM   #37
The car doesn't really over heat unless there is a mechanical problem. What happens is coolant temps rise to about 225F at this point the fans are running at mid to high speed and the motor will start to cut power output until the heat in matches the heat out if that makes sense. I managed to lower my ECT by about 15F across the board with the use of water and Mocool instead of coolant. With the new rad, I'm hoping I can extend it to a full 30-45min car on track without needing to come in. The extra cooling capacity basically delays this from happening or will preventing it altogether. I may end up putting one of these on the racecar for full track use.
TL/DR
Bigger rad means you can beat on it longer on track before heat soak.
The Following 4 Users Say Thank You to Celestspeed3 For This Useful Post:
daafisch (04-15-2014), Easter Bunny (04-12-2014), Mauro_Penguin (04-13-2014), MechEnix (04-11-2014)
 Old 04-11-2014, 06:26 PM   #38
MechEnix's Avatar
Posts: 186   (View Stats)
MechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond repute
How is this even a discussion. Larger surface area=more heat transferred from the fluid to the crossflowing air. Of course this will increase the time it takes for the engine to overheat when you're driving balls to the wall. This is probably more of a benefit if you track the car., for every day driving I doubt you'd see much benefit.
The bottom eq. is for parallel flow but whatever it's similar regardless. If you solve it you find q=UA(delta(T_lm)), where lm=log mean. Thus, as A increases q increases, or the amount of heat transferred increases.
Blah
% Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe
% Next up = Custom Tune
MechEnix is offline   Reply With Quote
The Following 3 Users Say Thank You to MechEnix For This Useful Post:
Celestspeed3 (04-12-2014), Easter Bunny (04-12-2014), faeker (04-12-2014)
 Old 04-11-2014, 06:31 PM   #39
Is that egyptian?
The Following 3 Users Say Thank You to Dizzy Turbo For This Useful Post:
Easter Bunny (04-12-2014), El_Diablo (04-14-2014), Hanzodurrr (04-11-2014)
 Old 04-11-2014, 09:56 PM   #40
MechEnix's Avatar
Originally Posted by Dizzy Turbo View Post
Is that egyptian?
just maths
Product Release! CorkSport Gen 1 Mazdaspeed 3 FMIC Radiator Shroud CorkSport CorkSport 16 08-25-2013 07:33 PM
CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.61584 seconds with 42 queries
