![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score So I was going to try to loosen my control arm, and jack up the wheel, then tighten the control arm bolt (to drop the front more). But before I waste time doing that, is this part of the settling process of the springs; Is the front supposed to be higher than the front right after install? thanks
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score You need to drive around for the new suspension to settle first. |
(Thread Starter) | Not Ranked : 0 score I already know that. But from what I've seen with the H&R springs w/ bilsteins is one can see that it drops a lot more in the front automatically
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score The front wheel well is cut higher than the rear. To check the level of drop, look at the body. Sent from my LG-MS770 using Tapatalk
__________________ it's fun to do bad things |
| The Following 4 Users Say Thank You to jack_hammer For This Useful Post: |
![]() Join Date: Apr 2011 Location: Allentown, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,504
| Not Ranked : 0 score Also h&r front springs are softer than stock Sent from my HTC One using Tapatalk |
![]() Join Date: Aug 2013 Location: Breinigsville PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score They will settle in
__________________ Corksport Sri, Tip, Rmm, springs, CPE tmic, CPE cbe, UR test pipe, JBR PMM, stage 2 oil catch can in vta, shift knob, boost tubes, ssp, AP V3, autotech internals (Freektuned ots+ tune) Forge BPV, alcohol injection systems-progressive meth kit } |
(Thread Starter) | Not Ranked : 0 score Either I got used to it or they're settling in.. thanks guys
| The Following User Says Thank You to levon.mark For This Useful Post: | SpencerC (05-28-2014) |
| Not Ranked : 0 score Told you man. |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score And it is because the front wheel wells are huge compared to the rear.
__________________ I am slow again. 2017 Lightning Blue SuperCab Raptor ordered 1/3/17. Built 2/3/17. Delivered 2/8/17. I modded it a little. |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score +6
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
| The Following User Says Thank You to jm211 For This Useful Post: | Micha (05-27-2014) |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Glad it worked out. It usually does.
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score I got my alignment today and car handles way better. Still little higher in front, but who cares; it's level.
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score That's a pretty significant difference in the gap. It would drive my OCD self crazy.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
![]() Join Date: Aug 2012 Location: Columbia MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Can't speak for the Bilsteins but the Koni's raise the front slightly from the OEM struts because of the placement of the knuckle stop. I had the CS springs on the OEM struts then the Koni's and I had noticeably more front wheel gap until I modified the knuckle stops on the Koni struts.
__________________ Mike [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score Bilstiens do the same as Konis. Honestly It still kinda annoys me but oh well.
(Thread Starter) | Not Ranked : 0 score I've been looking at my car and Im honestly bummed how dumb it looks. It's actually noticeable (still to this day) that the front is higher than the rear. Corksport should at least mention this to anyone running this springs on konis or bilstiens.
| Not Ranked : 0 score Go to a level area. If you place a level on the door handles, it will not read higher in the front than in back. I think you are focusing on wheel wheel gap. As @jack_hammer; stated, front wheel well is higher than the back. Same as on my ms3. ImageUploadedByTapatalk1416393024.033886.jpg |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | Easter Bunny (01-01-2015), jack_hammer (11-19-2014) |
(Thread Starter) | Not Ranked : 0 score Yup Yup, Correction *wheel cap*. I wished I bought coils, but whatever I am trying to go fast not look cool anymore.
![]() | | #19 | ![]() |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score I didnt get that gap difference with mine, not that I can tell anyway. Maybe they just haven't settled yet for me.
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs Last edited by Hargarbl; 01-01-2015 at 03:43 PM. |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score what tires are you running? your sig says H&R springs lol.
![]() | | #21 | ![]() |
Groans: 51
| Not Ranked : 0 score Yeah I was originally planning on running H&R's but didn't like the fact that they made the front softer than Oem. The tires are 235/40/18 cheap ass nankangs that came with the evo wheels.
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hmm I think I might get 235/45 18, think they'll fit?
![]() | | #23 | ![]() |
Groans: 51
| Not Ranked : 0 score Depending on offset yes or no, however a 235/45 is about and inch bigger in diameter, where a 235/40 is only 0.2 smaller. You can find tire size calculators online, plus there is the fitment thread in the forums. All should help.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ya It's half way through winter and I am not sure what I am going to do. I run gen pu wheels in the winter though. I'll probably get super sports too.
![]() | | #25 | ![]() |
Groans: 549
| Not Ranked : 0 score There's a thread for that
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is it IIRC The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS ?
![]() | | #27 | ![]() |
Groans: 549
__________________ it's fun to do bad things | |
| Quick bpv question | Cdez | MazdaSpeed 3/6 - Turbo Induction | 7 | 08-08-2013 07:05 PM |
| Quick question on a quick potential sale... | HeliBif | MazdaSpeed 3/6 - Wheels & Tires | 0 | 05-10-2012 02:48 PM |
| quick question | brandonms3 | Mazdaspeed3/6 General Discussion | 28 | 06-16-2011 03:27 PM |
| just got my forge bypass valve in from streetunit, wondering what i do with the springs and hardware it came with? quick | TheFranchizeSLB | 2010 MS3 - How-To's | 47 | 03-02-2010 04:55 PM |
| Another quick cx7 question. | SgtP | Mazdaspeed3/6 General Discussion | 16 | 07-08-2008 08:55 AM |
