  • 2 Post By levon.mark
 Old 05-24-2014, 06:46 PM   #1
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
Default Quick Question about my springs
Just yesterday I installed my CS springs and Bilsteins all around. Then I dropped the car, and the rear looks lower than the front (like kinda looks noticeably stupid and ruins the look of the car).
So I was going to try to loosen my control arm, and jack up the wheel, then tighten the control arm bolt (to drop the front more).
But before I waste time doing that, is this part of the settling process of the springs; Is the front supposed to be higher than the front right after install?
thanks
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 05-24-2014, 07:16 PM   #2
rolanblack's Avatar
Posts: 2,110   (View Stats)
You need to drive around for the new suspension to settle first.
 Old 05-24-2014, 07:23 PM   #3
levon.mark's Avatar
I already know that. But from what I've seen with the H&R springs w/ bilsteins is one can see that it drops a lot more
in the front automatically
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 05-25-2014, 09:31 AM   #4
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
The front wheel well is cut higher than the rear. To check the level of drop, look at the body.
Sent from my LG-MS770 using Tapatalk
it's fun to do bad things
The Following 4 Users Say Thank You to jack_hammer For This Useful Post:
Easter Bunny (01-01-2015), jm211 (05-27-2014), levon.mark (05-25-2014), Micha (05-27-2014)
 Old 05-25-2014, 12:55 PM   #5
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Also h&r front springs are softer than stock
 Old 05-25-2014, 02:50 PM   #6
Billcraft78's Avatar
Posts: 230   (View Stats)
Billcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the worldBillcraft78 is the leader of the world
They will settle in
Corksport Sri, Tip, Rmm, springs, CPE tmic, CPE cbe, UR test pipe, JBR PMM, stage 2 oil catch can in vta, shift knob, boost tubes, ssp, AP V3, autotech internals (Freektuned ots+ tune) Forge BPV, alcohol injection systems-progressive meth kit
Billcraft78 is offline   Reply With Quote
 Old 05-25-2014, 09:04 PM   #7
levon.mark's Avatar
Either I got used to it or they're settling in.. thanks guys
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following User Says Thank You to levon.mark For This Useful Post:
SpencerC (05-28-2014)
 Old 05-25-2014, 11:07 PM   #8
rolanblack's Avatar
Told you man.
 Old 05-27-2014, 12:22 AM   #9
Micha's Avatar
Posts: 3,436   (View Stats)
And it is because the front wheel wells are huge compared to the rear.
I am slow again.
I modded it a little.
 Old 05-27-2014, 07:56 AM   #10
jm211's Avatar
Posts: 943   (View Stats)
+6
The Following User Says Thank You to jm211 For This Useful Post:
Micha (05-27-2014)
 Old 05-28-2014, 11:57 AM   #11
SpencerC's Avatar
Posts: 2,159   (View Stats)
Glad it worked out. It usually does.
 Old 05-29-2014, 01:07 AM   #12
levon.mark's Avatar
I got my alignment today and car handles way better. Still little higher in front, but who cares; it's level.
WA_MS6 and CorkSport Vincent like this.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 05-29-2014, 04:48 AM   #13
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
That's a pretty significant difference in the gap. It would drive my OCD self crazy.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 05-29-2014, 08:07 AM   #14
iammike's Avatar
Posts: 1,415   (View Stats)
Can't speak for the Bilsteins but the Koni's raise the front slightly from the OEM struts because of the placement of the knuckle stop. I had the CS springs on the OEM struts then the Koni's and I had noticeably more front wheel gap until I modified the knuckle stops on the Koni struts.
Mike
 Old 05-30-2014, 12:46 PM   #15
levon.mark's Avatar
Bilstiens do the same as Konis. Honestly It still kinda annoys me but oh well.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 11-19-2014, 02:16 AM   #16
levon.mark's Avatar
I've been looking at my car and Im honestly bummed how dumb it looks. It's actually noticeable (still to this day) that the front is higher than the rear. Corksport should at least mention this to anyone running this springs on konis or bilstiens.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 11-19-2014, 03:31 AM   #17
Go to a level area. If you place a level on the door handles, it will not read higher in the front than in back. I think you are focusing on wheel wheel gap. As @jack_hammer; stated, front wheel well is higher than the back. Same as on my ms3.
Easter Bunny (01-01-2015), jack_hammer (11-19-2014)
 Old 12-16-2014, 10:38 PM   #18
levon.mark's Avatar
Yup Yup, Correction *wheel cap*. I wished I bought coils, but whatever I am trying to go fast not look cool anymore.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-01-2015, 03:26 PM   #19
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
I didnt get that gap difference with mine, not that I can tell anyway. Maybe they just haven't settled yet for me.
 Old 01-01-2015, 03:44 PM   #20
levon.mark's Avatar
what tires are you running? your sig says H&R springs lol.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-01-2015, 03:54 PM   #21
Hargarbl's Avatar
Groans: 51
Yeah I was originally planning on running H&R's but didn't like the fact that they made the front softer than Oem. The tires are 235/40/18 cheap ass nankangs that came with the evo wheels.
 Old 01-01-2015, 10:29 PM   #22
levon.mark's Avatar
Hmm I think I might get 235/45 18, think they'll fit?
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-01-2015, 10:38 PM   #23
Hargarbl's Avatar
Groans: 51
Depending on offset yes or no, however a 235/45 is about and inch bigger in diameter, where a 235/40 is only 0.2 smaller. You can find tire size calculators online, plus there is the fitment thread in the forums. All should help.
 Old 01-01-2015, 10:44 PM   #24
levon.mark's Avatar
Ya It's half way through winter and I am not sure what I am going to do. I run gen pu wheels in the winter though. I'll probably get super sports too.
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-01-2015, 11:02 PM   #25
Groans: 549
There's a thread for that
 Old 01-02-2015, 12:16 AM   #26
levon.mark's Avatar
This is it IIRC The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS ?
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 01-02-2015, 06:58 PM   #27
Groans: 549
Probably
Quick bpv question Cdez MazdaSpeed 3/6 - Turbo Induction 7 08-08-2013 07:05 PM
Quick question on a quick potential sale... HeliBif MazdaSpeed 3/6 - Wheels & Tires 0 05-10-2012 02:48 PM
quick question brandonms3 Mazdaspeed3/6 General Discussion 28 06-16-2011 03:27 PM
just got my forge bypass valve in from streetunit, wondering what i do with the springs and hardware it came with? quick TheFranchizeSLB 2010 MS3 - How-To's 47 03-02-2010 04:55 PM
Another quick cx7 question. SgtP Mazdaspeed3/6 General Discussion 16 07-08-2008 08:55 AM
Page generated in 0.43964 seconds with 32 queries
