Like Tree4Likes
  • 3 Post By MazdaBoy2.3
  • 1 Post By SpencerC
 Old 09-12-2014, 06:52 AM   #1
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Default Short Shifter Review (2010 MS3) - MazdaBoy2.3
My review of the CS Short Shifter - CORKSPORT Adjustable Short Shifter
Purchased the short shifter on Monday and received it on Wednesday! Considering it was traveling from once side of the country to the other, I was very happy to see it so quickly. Thank you @Spencer@CorkSport; !
As always, @CorkSport; is top notch with its packaging.
The provided instructions were very clear, although the time estimate of 1 hour may be a bit ambitious for the first run at it. I would plan for closer to two if this is your first time taking it all apart.
Here are some pics to give you an idea of what it looks like installed (at shortest length)
I gave it a go with my @maisonvi; shift knob and had to actual raise it a bit. Hand was hitting plastic surround.
Driving impression: shifts feel much more solid, and a large amount of the "play" has been removed. I have it set to the shortest throw and really close to the shortest height, and it shifts like butter.
Corksport short shifter - 2010 MS3:
CS shifter - a Little more aggressive:
Recommendations: At a price of $200 this should include the small amount of the lithium grease that is reccomended. Also, the plastic clip shown below is a scary little bugger, I could easily see it being broken during install as our cars age and the plastic becomes more brittle. I would have gladly paid more $ in order to have a new one of these included.
Should you buy it? If you want to improve your shifts this is a must have. We will see how it holds up, but my initial impressions are incredibly positive.
Will update through out the day...at work...
The Following 20 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
bigdog (09-12-2014), blakjak0271 (09-12-2014), Cevaes_64 (09-12-2014), cyclist20 (09-12-2014), DaUberSchwebel (09-14-2014), donjohnk (09-12-2014), Donut (09-15-2014), Finchee (09-13-2014), Hush (09-12-2014), InkedInspector (09-12-2014), JgamB (09-12-2014), Jsn_Rob (09-14-2014), maisonvi (09-12-2014), motherfnmonsta (09-19-2014), rfinkle2 (09-12-2014), speed3okie (09-12-2014), SpencerC (09-12-2014), ST_Fan (09-16-2014), TMOtester (09-12-2014), XxSmarTz (09-14-2014)
 Old 09-12-2014, 07:11 AM   #2
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
I've been considering one of these for a while. I like the finish on it a lot. That wouldn't be my sole reason for getting one but still it looks damn sexy!
2012 black mica. Totaled 10/31/14.
Johnasaurus is offline   Reply With Quote
The Following 2 Users Say Thank You to Johnasaurus For This Useful Post:
MazdaBoy2.3 (09-12-2014), SpencerC (09-12-2014)
 Old 09-12-2014, 07:28 AM   #3
Groans: 51
And of course....I should post the carnage...
Yes, plastic can be sharp...lol
 Old 09-12-2014, 08:37 AM   #4
The sacrifice to the car gods was accepted it seems.
-Derrick
himurax13 (09-12-2014), MazdaBoy2.3 (09-12-2014)
 Old 09-12-2014, 08:43 AM   #5
Groans: 51
-Derrick
If I ever got rid of the car and the next owner opens up the center console, they will probably thinking someone was murdered in it. Haha
 Old 09-12-2014, 08:14 AM   #6
speed3okie's Avatar
Posts: 960   (View Stats)
speed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the world
Good Review!
Mod List:
CORKSPORT : Shifter Bushings / Interior Led Kit / Hood Struts / Short Ram Intake / Coolant Tank / Ecu Relocation-Battery Box / Disi Silicone Boost Tubes / Mid-chassis Brace / Fog Light Kit / Mud Flap Kit / Underhood Led Light Kit /
Disi Silicone Bypass Valve Hose / Turbo Inlet Pipe / Mazdaspeed MZR Bypass Valve / Leather Shift Knob / MS3 Race Rear Motor Mount /Adjustable Short Shifter /
Strut - Spring Combo Set
JBR: Tru-Torsion 3-Way Adjustable Rear Sway Bar / Transmission Side Motor Mount 80a Durometer /
Passenger Side Motor Mount 80a Durometer /
DIODE DYNAMICS: Interior Led Kit
SPC : Rear Camber Arms
Ebay: Race Pipe
Optima: Red Battery
MOOG : Front and Rear End Sway Bar End Links
AutoTech : HPFP Internals
35% Tint
-------------------------------Not done yet-------------------------
Need More Parts
speed3okie is offline   Reply With Quote
The Following User Says Thank You to speed3okie For This Useful Post:
 Old 09-12-2014, 08:59 AM   #7
RACER_X's Avatar
Posts: 266   (View Stats)
RACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the world
Groaned at 31 Times in 14 Posts
OP, can/should you mount this w a short shift plate?
Already have a JBR plate, dunno if it's worth changing over our adding
ΜΟΛΩΝ ΛΑΒΕ
2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's
2015 F150 Platinum
2012 MS3 Liquid Silver
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Enkei Raijin 18x8 et45
JBR 3.0WP, RSB, RMM & SSP II
Stratified Tune
TrackMasters hood prop and ecu reloc.
TurboSmart BOV
RACER_X is offline   Reply With Quote
The Following User Says Thank You to RACER_X For This Useful Post:
 Old 09-12-2014, 09:02 AM   #8
Groans: 51
I don't beleive @CorkSport; reccomends the use of both. I will say that I have used a SSP in the past and definitely prefer this over it. I'd sell the SSP and upgrade to this personally.
The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
Jsn_Rob (09-14-2014), SpencerC (09-12-2014)
 Old 09-12-2014, 11:00 AM   #9
SpencerC's Avatar
Posts: 2,159   (View Stats)
Thanks for the review! Really appreciate it!
You can certainly use a Short Shift plate with it, but it might be incredibly short throw, and possibly not catch all the gears. You might get locked out.
MazdaBoy2.3 (09-13-2014)
 Old 09-12-2014, 11:35 AM   #10
mazdaspeedmyk's Avatar
Posts: 124   (View Stats)
mazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the worldmazdaspeedmyk is the leader of the world
I've been using a TWM SSP with my short shifter since it was released. It is definitely short. I had to use the shortest throw setting and adjust the shifter cable in order for it to make its way through all the gears. It's been great.
2010 Mazdaspeed3 - Celestial Blue Mica
mazdaspeedmyk is offline   Reply With Quote
The Following 2 Users Say Thank You to mazdaspeedmyk For This Useful Post:
MazdaBoy2.3 (09-13-2014), SpencerC (09-12-2014)
 Old 09-12-2014, 11:48 AM   #11
Groans: 51
I added a video of a little more aggressive run through the gears. Roads are still cold/damp so can't give it the full thrashing yet ;-)
 Old 09-13-2014, 10:59 AM   #12
1CleanSpeed's Avatar
Posts: 11   (View Stats)
1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future1CleanSpeed has a brilliant future
Great write up ! I got mine 3 weeks ago and even I was surprised it didn't come with the grease and even one of those plastic clips .. It's very easy to break
1CleanSpeed is offline   Reply With Quote
The Following User Says Thank You to 1CleanSpeed For This Useful Post:
 Old 09-14-2014, 03:16 AM   #13
shaneski's Avatar
Posts: 505   (View Stats)
You're not wrong about that plastic clip, i was just about at the point of give up and put the stock set up back in, added an extra 45 mins of install time trying to get that bitch off and i broke around 4 of the tabs off.
If the kit came with that clip would be so much quicker and easier to just break the original one off.
 Old 09-14-2014, 03:18 AM   #14
Yikes I only broke one but your right it was frustrating , if life was easy there would of been a extra clip lol
 Old 09-15-2014, 10:31 PM   #15
N!NJA's Avatar
Posts: 418   (View Stats)
N!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond reputeN!NJA has a reputation beyond repute
Didn't see the question asked yet I'll be the one to do it. Will this fit the ms6? Hope so I hate only having one option.
N!NJA is offline   Reply With Quote
 Old 09-16-2014, 11:08 AM   #16
It will not fit the MS6.
-Derrick
 Old 09-16-2014, 12:42 PM   #17
N!NJA's Avatar
That sucks. I really want something adjustable.
 Old 09-18-2014, 01:08 AM   #18
havocforming's Avatar
Posts: 30   (View Stats)
havocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond reputehavocforming has a reputation beyond repute
Good write up. Ive had mine since shortly after release in my 2013. Love it. still get the occasional 3rd gear grind but nowhere near as frequent as before. Shifts are definitely more solid. Only problem i ran into was the guide pin for the reverse lockout, popped out and fell into the carpet under the center console. loctited it in so hopefully it stays now.
2013 MS3 w/Tech
Htp 3" one piece intake/TIP, Accesport V3, Autotech hpfp internals, JBR BSD/Baffle, JBR 88Duro Trilogy, CP-E QkSpl Catted downpipe, CP-E Triton CBE, Corksport Shortshifter
havocforming is offline   Reply With Quote
The Following User Says Thank You to havocforming For This Useful Post:
SpencerC (09-18-2014)
 Old 09-18-2014, 10:33 AM   #19
SpencerC's Avatar
Cool, good to hear another solid review. I know our engineers were told about the few people who mentioned the guide pin popping out, so I assume we have started adding loctite or something.
havocforming (09-19-2014)
 Old 09-18-2014, 11:25 AM   #20
dinoxor's Avatar
Posts: 346   (View Stats)
dinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the world
looks kinda like Cobb's STS
Too bad they didn't make one for the gen1 otherwise I would have purchased this in a heartbeat D:
Good review by the way!
Black Mica 2008.5
CS SRI+TIP • AT HPFP • TP
dinoxor is offline   Reply With Quote
 Old 09-18-2014, 02:33 PM   #21
SpencerC's Avatar
We are working on a GenJuan one.
dinoxor likes this.
MazdaBoy2.3 (09-19-2014), TRBLSM (09-18-2014)
 Old 10-03-2014, 12:08 PM   #22
Zoom66's Avatar
Posts: 281   (View Stats)
Great review, just ordered one of these for my car. Now waiting on Brown to deliver the goods....
The Following 3 Users Say Thank You to Zoom66 For This Useful Post:
MazdaBoy2.3 (10-07-2014), speed3okie (10-03-2014), SpencerC (10-03-2014)
 Old 10-07-2014, 07:54 PM   #23
Groans: 51
Good choice! If you need any help, shoot me a pm!
 Old 10-03-2014, 12:38 PM   #24
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
Put mine in about two weeks ago. Shifts great, a little goofy looking without the offset, but best part is adjustable height. I no longer smash my pinky and turn off the climate control whilst shifting.
2013 VRM MS3
darthxar is offline   Reply With Quote
The Following 2 Users Say Thank You to darthxar For This Useful Post:
MazdaBoy2.3 (10-07-2014), SpencerC (10-03-2014)
 Old 10-06-2014, 01:37 PM   #25
tikous360's Avatar
Posts: 182   (View Stats)
tikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the worldtikous360 is the leader of the world
nice review
tikous360 is offline   Reply With Quote
The Following User Says Thank You to tikous360 For This Useful Post:
 Old 10-07-2014, 08:04 PM   #26
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
just put mine in too.
Broke the clip, but only broke a small portion of it off and was able to still use it.
So far the only problem I've encountered is disorientation with 1st and reverse.
But other than that, I really like this shifter.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 10-08-2014, 05:22 AM   #27
darthxar's Avatar
Yeah that clip is a straight up motherfucker to get off. I spent longer on it than the whole rest of the install. If someone could source or make just that clip so we could just destroy it when disassembling, working on the shifter would be 100 times easier.
2013 VRM MS3
 Old 10-09-2014, 01:45 PM   #28
Zoom66's Avatar
Got mine in and it helped a lot during track day at Hallett OK. Found a good trick to remove the clip without breaking it. Got me a small zip tie and started threading it under the tabs unit it started to thread under itself to get all the tabs to swell evenly until you can pull it with your hand. I used a small needle nose plier to help to carefully keep pushing the zip tie in.
Customer Review ? Adjustable Short Shifter ? Voltron CorkSport CorkSport 7 04-07-2014 10:54 AM
TWM Replacement short shifter Review!! SmoothVanilla 2010 MS3 - Engine, Transmission & Driveline 1 10-15-2013 12:54 PM
Mazda 3 2010+ Short Shifter install DIY TWM Performance Gen2 MS3 General Discussion 0 02-24-2012 12:45 PM
2010 SPEED3 SHORT SHIFTER! BROXN 2010 MS3 - Engine, Transmission & Driveline 14 03-03-2010 06:50 PM
Page generated in 0.50825 seconds with 36 queries
