 Old 01-25-2016, 11:12 PM   #1
Ozynigma's Avatar
Posts: 743   (View Stats)
Default Show us your curves
I am wondering what boost people are achieving with their Corksport turbos and how quickly they are spooling up. I particularly want to know what people are achieving with stock intake and exhaust manifolds.
My boost curve from last years dyno tuning is attached.
I hit 23psi at 4000rpm and maximum boost of 25psi at 6500rpm.
When this tune was done I had stock engine internals, I now have a forged build.
I have a 7gph nozzle spraying 50:50 water methanol starting from 12.5psi with maximum flow from 18psi.
I am going back on the dyno next Monday with the built motor and I am wondering how much harder we can push this puppy.
The Following 4 Users Say Thank You to Ozynigma For This Useful Post:
ericrapp0507@gmail.com (01-26-2016), Gitcherex (01-25-2016), MS3Shadow (01-26-2016), Xxblinddzxx (01-26-2016)
 Old 01-26-2016, 05:29 AM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Graph doesnt load?
 Old 01-26-2016, 04:26 PM   #3
Ozynigma's Avatar
Graph doesnt load?
It does on a browser but not in Tapatalk. Its a pdf. I will see if I can jpeg it as well.
 Old 01-26-2016, 11:58 AM   #4
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Looks good!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 01-26-2016, 04:30 PM   #5
Ozynigma's Avatar
Here is my graph in jpeg
 Old 01-26-2016, 05:01 PM   #6
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Should you choose to, you could dial in a little more wastegate actuator preload on the wastegate flapper, and that will probably get you up to 20psi 200-300rpm faster. How much timing you running at redline with 25psi?
MINI H1 6.0 - CAR LED TAILS
 Old 01-26-2016, 06:49 PM   #7
Ozynigma's Avatar
Thanks for the input Dale, I have read a few of your threads with great interest, I am just getting my teeth into the tuning side. Previously I have just paid the tuner to get me this far.
16.5 degrees advance at redline building from about 7 degrees at 4000rpm.
The bottom line of my BCS DC Base table is;
100,100,100,100,100,70,53,48,51,53,55,56,58,58
So this means 100% WGDC to 2500rpm then drops then ramps up slightly to hold/build boost to redline.
I am thinking a bit more WGDC at 3000 and 3500rpm could help spool up faster too.
 Old 01-26-2016, 06:53 PM   #8
gdawg25's Avatar
Posts: 248   (View Stats)
How do you adjust wastegate preload on the CS turbo?
 Old 01-26-2016, 09:24 PM   #9
Ozynigma's Avatar
A barrel screw adjuster on the actuator rod
Mazdaspeed 3 and 6 Turbo Upgrade
The Following 2 Users Say Thank You to Ozynigma For This Useful Post:
CorkSport (01-27-2016), gdawg25 (01-26-2016)
 Old 01-26-2016, 06:16 PM   #10
sheston's Avatar
Posts: 1,847   (View Stats)
I've read you can play with VVT to boost quicker as well. It would be interesting if you documented these changes so we all can learn :-)
 Old 01-26-2016, 06:46 PM   #11
I've played with VVT for a while. I never saw anything out of the noise regarding spool and/or flow. When I made the preload adjustment, I saw a pretty noticeable change in low end torque and turbo response. It could be that the preload adjustment masked any VVT changes since I did the preload change first.
Craziest AFR curves ever? Flawless MazdaSpeed 3/6 - ECU Computer Tuning 4 07-03-2015 07:31 AM
Paris Motor Show's Pavilion 8 offers curves, angles and rare perspective Haltech Automotive News 0 10-03-2014 03:30 PM
Boost curves for k04 EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 54 11-11-2012 01:14 PM
Name Those Curves! Haltech Celeberty Smut 0 07-10-2009 10:50 PM
Page generated in 0.32071 seconds with 26 queries
