Like Tree31Likes
 Old 04-30-2013, 07:38 PM   #41
Thanks for addressing the battery box, the ECU and battery are covered for a good reason and most seem to disregard that... I would still like to see a hard partition between them but beggars and choosers, intake looks nice; though strangely I was hoping for something a bit different audio clips of this turbine in use?
You can actually use some split loom and polyken high temp tape to cover the exposed wiring if you no longer have the ECU cover.
Pointless (05-01-2013)
 Old 04-30-2013, 08:51 PM   #42
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Like this?
Sent via stockish Black Mica Pu
Pickles Tune in progress
 Old 05-01-2013, 02:46 AM   #43
MS3MYK's Avatar
Posts: 1,967   (View Stats)
Im so in for this! I love my CS TIP. I wanna go to a big intake though.
Are you guys going to have an option for us VTA guys? JW
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
 Old 05-01-2013, 04:32 AM   #44
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Yes, but I think in the case of silicone it's not quite the case. The surface is not as smooth, the bends are not as smooth, the volume and flow changes under boost (in some cases). If you compare the designs, I think the flow differences are much more related to the shape and path of the air than the volume. If you can keep things cylindrical you can almost always outflow things that are not.
Air clings to smooth surfaces. Think "golf ball".
"Exclusivity" - CP-enis
Demodded.
The Seals
CamSpeed360 (05-01-2013), Easter Bunny (05-01-2013), MS6 Sanchez (05-01-2013), SLOWHATCH (05-01-2013)
 Old 05-01-2013, 04:50 AM   #45
Ziggo's Avatar
Posts: 3,843   (View Stats)
The flow in the intake is turbulent, not laminar.
Zigatapatalka
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
Easter Bunny (05-01-2013), El_Diablo (05-03-2013), MechEnix (06-25-2013), mize13 (02-13-2014)
 Old 05-01-2013, 05:18 AM   #46
Tenchix's Avatar
Posts: 450   (View Stats)
Tenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the world
Originally Posted by Brydon@CorkSport View Post
Here are some pictures installed. Not the best shots but it gives you an idea.
How big is that box? Is it big enough for a group 25 batter? And I'm pretty sure if it fits a ms3. It'll fit the ms6. Correct? Oh it look great!
Tenchix is offline   Reply With Quote
 Old 05-01-2013, 11:22 AM   #47
Ziggo's Avatar
Please check the calculations in the following spreadsheet. Not sure where your Reynolds number equation came from but it looks wrong to me because it doesn't include a viscosity term, but it may be a different form I am not aware of. Reynolds numbers over 2300 are transitional IIRC with numbers over 4000 being turbulent. MAF sensors are designed to operate in fully developed, turbulent flow.
https://docs.google.com/spreadsheet/...&usp=drive_web
Zigatapatalka
Ask Me About My:
The Following 10 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (05-05-2013), charlesfist (05-01-2013), Easter Bunny (05-01-2013), El_Diablo (05-03-2013), Lex (05-01-2013), MechEnix (05-30-2013), Micha (05-04-2013), mize13 (02-13-2014), ms3blackmica (05-01-2013), SpeedNess (05-01-2013)
 Old 05-01-2013, 11:39 AM   #48
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Coksport's Dolphin penis?
ABolewski likes this.
The Following 3 Users Say Thank You to SLOWHATCH For This Useful Post:
ABolewski (05-01-2013), Easter Bunny (05-01-2013), warlord (05-01-2013)
 Old 05-01-2013, 11:56 AM   #49
3dpilot's Avatar
Posts: 88   (View Stats)
3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute3dpilot has a reputation beyond repute
Joel@corksport; CARB legal for the Cali inmates?!?!?!
dot584 likes this.
3dpilot is offline   Reply With Quote
The Following User Says Thank You to 3dpilot For This Useful Post:
dot584 (09-13-2013)
 Old 05-01-2013, 12:07 PM   #50
SpeedNess's Avatar
Posts: 207   (View Stats)
SpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the worldSpeedNess is the leader of the world
Ziggo is right,
air density=1.2 (kg/m^3) @ 20 celcius
Q=Flow=VA
Q=0.300 (kg/s)*(1.2 (kg/m^3)=0.25 (m^3/s)
V=velocity= Q/A=(( 0.25 m^3/s)*4)/(pi*0.076m)=55.11 (m/s)
Re=(density*V*Diameter)/dynamic viscosity
dynamic viscosity @ 300 k approx 27 celcius = 1.983 E -5 (kg/m-s)
Re= ((1.2 kg/m^3) * 55.11 (m/s) * (0.076 m))/(1.983E-5 Kg/m-s) = 253,451.6
So the flow is very much turbulent at 300 g/s
I did a quick Reynold's number calculation for air flowing in a pipe/intake that is 3" (76mm) and circular.
Re = (Q*D)/(v*A)
where Q is the volumetric flow
D = diameter
v = air velocity
A = cross sectional area
At 20* C and sea level air density is about 1200 g/m^3
That means that if we flow 300 g/s we are flowing around 0.25 m^3/s
Air velocity in a 76mm pipe flowing 0.25 m^3/s is around 55 m/s
That leaves us after some cancellations of radius with 0.25*2/ (55*pi*0.076) which is a Re of ~0.04 which much less than 1 at that flow rate.
Generally the Re has to be quite a bit larger to have turbulent flow.
Of course this is idealized for just a straight pipe and the bends in the intake do affect the airflow and create turbulence, but the MAF sensor requires a level of laminar flow to achieve a correct reading so at least part of the intake has laminar flow. Further as the velocity of the air increases the flow becomes more laminar and this is why MAF sensors in larger intakes are able to read large airflow rates fine while they struggle with low airflow rates.
Wondering how you determined flow to be turbulent and to what extent.
Lex your formula is Ok, but the mistake is that "v" in this formula is not velocity it should be Kinematic Viscosity of the fluid
HKS Intake l Cobb TIP l CorkSport TMIC l Cobb AP l AT Internals l SU Test Pipe
Turbosmart Dual Port l Stratified Shift Extension/Knob l CPE RMM l Dashawk
Last edited by SpeedNess; 05-01-2013 at 12:07 PM. Reason: MSF Database - Automerged Doublepost
SpeedNess is offline   Reply With Quote
The Following 9 Users Say Thank You to SpeedNess For This Useful Post:
ABolewski (05-01-2013), atvfreek (05-05-2013), BigRedSpecial (05-01-2013), charlesfist (05-01-2013), El_Diablo (05-03-2013), Jeremy3eb (05-01-2013), Lex (05-01-2013), mize13 (02-13-2014), ms3blackmica (05-01-2013)
 Old 05-01-2013, 12:31 PM   #51
Originally Posted by SpeedNess View Post
Ziggo is right,
Q=Flow=VA
Doh! That's the mistake! Thanks for pointing this out guys! Time to recalculate the material effects on the flow of the intake.
The Following 8 Users Say Thank You to Lex For This Useful Post:
ABolewski (05-01-2013), Easter Bunny (05-01-2013), El_Diablo (05-03-2013), MechEnix (05-30-2013), Micha (05-04-2013), ms3blackmica (05-01-2013), SLOWHATCH (05-02-2013), SpeedNess (05-01-2013)
 Old 05-01-2013, 12:54 PM   #52
Probably not.... CARB is very VERY expensive and we would have to pass that cost on to each intake and it would make them too expensive, especially considering this won't be a high volume part. Sorry...
XerocX likes this.
3dpilot (05-03-2013)
 Old 05-01-2013, 12:59 PM   #53
Tokay444's Avatar
Groans: 793
Originally Posted by SLOWHATCH View Post
Dolphin penis?
narwal penis.
SLOWHATCH likes this.
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (05-01-2013), El_Diablo (05-03-2013), H3R3TIC (05-16-2013), SLOWHATCH (05-01-2013), snailD (05-01-2013)
 Old 05-01-2013, 01:10 PM   #54
Gibbo's Avatar
Posts: 156   (View Stats)
Gibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the world
Correct. This is an awesome thread learning this exact stuff at UNI right now. Changing the boundary flow to turbulent from laminar soon as possible will reduce the drag, allowing greater flow, yes?
Also, can you see a possibility of designing an air box for this if it won't be possible to modify the existing corksport air box for the stage 2 intake..?
Sent from my LG-P880 using Tapatalk 2
Gibbo is offline   Reply With Quote
 Old 05-01-2013, 02:06 PM   #55
J.Dy's Avatar
Posts: 109   (View Stats)
J.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond repute
Would this work with the stock airbox for smog purposes?
J.Dy is offline   Reply With Quote
 Old 05-01-2013, 02:44 PM   #56
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
will this work for MS6 guys keeping the battery in OEM location?
redboat is offline   Reply With Quote
The Following 2 Users Say Thank You to redboat For This Useful Post:
dot584 (05-16-2013), ESA (05-24-2013)
 Old 05-01-2013, 02:47 PM   #57
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
Interested for the MS6...
Mfinlay04 likes this.
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
The Following 2 Users Say Thank You to scubasteve711 For This Useful Post:
ESA (05-24-2013), Mfinlay04 (05-16-2013)
 Old 05-01-2013, 05:25 PM   #58
Checking this out tomorrow. Might just clear. Or we have to get a little creative for the MS6.
The Following 7 Users Say Thank You to CorkSport For This Useful Post:
ABolewski (05-01-2013), ciezczak1 (09-13-2013), dot584 (05-16-2013), ESA (05-24-2013), Micha (05-04-2013), MZRSpeeder6 (05-01-2013), redboat (05-01-2013)
 Old 05-01-2013, 07:41 PM   #59
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
4'' would be tuff with stock batt
at 104000 2 bent rods
tuned by nishan
 Old 05-02-2013, 11:01 AM   #60
I think we could do 4" fine with the ECU relocated and the battery pushed back the way Brydon did it but like Brydon said, 4" is neat but the stock head wouldn't be able to handle anything near 4" flow.
rigor (05-02-2013)
 Old 05-03-2013, 09:15 AM   #61
100mm (4") Pipe with plenty of space using the stock size battery. Sorry about the bad picture.
The Following 6 Users Say Thank You to CorkSport For This Useful Post:
ABolewski (11-14-2013), El_Diablo (05-03-2013), evil MS3 (05-03-2013), ms3blackmica (05-03-2013), rigor (05-03-2013), ZetaDrift (05-03-2013)
 Old 05-03-2013, 05:49 PM   #62
rigor's Avatar
Groans: 40
moving ecu is cheating
looks good!
i may have to do the same the little battery sucks on cold mornings
tuned by nishan
Last edited by rigor; 05-03-2013 at 05:49 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to rigor For This Useful Post:
atvfreek (05-05-2013), helmetface (05-03-2013)
 Old 05-03-2013, 05:57 PM   #63
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
moving ecu is smart
fixed.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
rigor (05-03-2013)
 Old 05-04-2013, 02:11 AM   #64
Juice's Avatar
Posts: 1,094   (View Stats)
Juice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the worldJuice is the leader of the world
Just curious, are you going with a new car battery holder? Are you setting up for a 51r battery? I see you moved the ecu to the front in the battery compartment. Is this to accommodate bigger tip?
Training at a Tsa secret location. Sequestration is here!
If you need military police, do not call me.
Juice is offline   Reply With Quote
The Following User Says NO Thank You to Juice For This Un-useful Post:
Easter Bunny (05-04-2013)
 Old 05-04-2013, 05:34 AM   #65
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
They make reference to a new battery box they are making for the stock battery.
A little tapa tapa taparoo...
 Old 05-04-2013, 06:56 PM   #66
TexanMS3's Avatar
Posts: 28   (View Stats)
TexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of lightTexanMS3 is a glorious beacon of light
Groaned at 3 Times in 1 Post
Can't wait to see the bigger intake!
TexanMS3 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to TexanMS3 For This Un-useful Post:
evil MS3 (05-13-2013), Kyle Undefined (05-14-2013), NavySailorMS3 (05-13-2013)
 Old 05-04-2013, 07:04 PM   #67
Tokay444's Avatar
Groans: 793
If you have problems with your silicone intake/tip deforming, your problem is pressure ratio. Your intake is just plain too small. There shouldn't be enough vacuum there to distort its shape.
Demodded.
The Seals
 Old 05-14-2013, 05:15 PM   #68
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
Bringing the post filter large amount of air N/A logic into the turbo setups. I am very happy with this setup is looking.
AustinK is offline   Reply With Quote
The Following 3 Users Say Thank You to AustinK For This Useful Post:
ABolewski (11-14-2013), Juice (05-14-2013), kritz (05-16-2013)
 Old 05-14-2013, 10:36 PM   #69
Yatta's Avatar
Posts: 1,862   (View Stats)
rats nest... I like the shop light though... I'm waiting to see another way.
 Old 05-14-2013, 10:40 PM   #70
rigor's Avatar
Groans: 40
factory rats nest !
i try not to drive it around with the drop light in it, also this is in the mock up stage many moons ago, no more stand back crap anymore..
The Following User Says Thank You to rigor For This Useful Post:
Yatta (05-14-2013)
 Old 05-16-2013, 02:11 AM   #71
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The airflow gain in alum vs silicone isnt so much from the material itself as it is from the shape. If the aluminum is mandrel bent and the inside isnt clogged up with weld sugar/beads then for the same ID alum should out flow silicone because silicone will collapse slightly and it bends/ovals upon installation. Round always outflows other shapes.
Heat transfer in a FI application is almost stupid, air is in the intake for a few thousanths of a second during boost and off boost it doesnt matter. If intake heat killed HP, no one would ever buy a SRI.
A TIP isnt rocket science, make it round, reduce the bend radius(es), sell for a lower price. Its real simple.
The best TIP is a massive air filter clamped to the turbo, anything else is splitting hairs.
kritz likes this.
2006 Mazdaspeed 6
The Following 5 Users Say Thank You to 06Speed6 For This Useful Post:
ABolewski (05-16-2013), dot584 (05-16-2013), Easter Bunny (09-13-2013), jack_hammer (05-16-2013), ms3blackmica (05-16-2013)
 Old 05-16-2013, 02:25 AM   #72
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Agreed.
There is not enough time for any drastic heat transfer to take place when moving air at high velocities such as the compressor wheel produces.
That theory alone tends to drive tons of people away from metal intakes all the time.
kritz likes this.
www.tunedbynishan.com
 Old 05-16-2013, 03:39 AM   #73
Tokay444's Avatar
Groans: 793
Spoon whale penis intake for the Honda fags isn't round. And that fucker flows.
Fyhn
Demodded.
The Seals
 Old 05-16-2013, 05:57 AM   #74
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i am king whale peen
Mfinlay04 and 3starmagnum like this.
The Following 5 Users Say Thank You to dooderek For This Useful Post:
06Speed6 (05-16-2013), ABolewski (05-16-2013), Mfinlay04 (05-16-2013), ms3blackmica (05-16-2013), Tokay444 (05-16-2013)
 Old 05-16-2013, 06:09 AM   #75
Mfinlay04's Avatar
Posts: 827   (View Stats)
Just curious if this was still a thing... haha
Joel what's the word on this? Looking to buy a TIP the first week of June and looking for other options.
2006 MS6 Titanium Grey
Tuned with
 Old 05-16-2013, 01:18 PM   #76
I don't think we'll hit June. If you can wait, I think it will be worth it to you.
Cheers,
Joel
 Old 05-16-2013, 02:34 PM   #77
himurax13's Avatar
Groans: 255
No black powdercoating?
Sent via rental car
 Old 05-16-2013, 02:41 PM   #78
I'm sure that will be an option. Black everything is very popular for our intakes.
 Old 05-16-2013, 03:58 PM   #79
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
"So.... do we still care about big intakes??"
YES.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 05-17-2013, 01:48 AM   #80
Mfinlay04's Avatar
Cheers,
Joel
What kind of price point are you guys trying to hit? I know from past CS products price was always fair but if this is going to be a "limited" production kinda deal will the price reflect that?
Sent from my Nexus 7 using Tapatalk 2
Tuned with
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/so-do-we-still-care-about-big-144282/
CorkSport Mazda Performance ? Blog » Our Videos, Your Input This thread Refback 05-02-2013 01:52 PM
CorkSport Mazda Performance ? Blog » SkyActiv vs. The Traditional Fuel Injected Motor This thread Refback 05-02-2013 08:29 AM
CorkSport Mazda Performance ? Blog » Fuel Pump Comparison Part 2 This thread Refback 05-01-2013 09:07 PM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Intakes finalems3 CorkSport 38 03-29-2013 11:16 PM
I'm confused about intakes curiosul 2010 MS3 - Engine, Transmission & Driveline 1 08-29-2012 02:32 PM
Questions about TBE and Intakes kingpin4534 MazdaSpeed 3/6 - Turbo Induction 14 05-04-2009 06:45 AM
Page generated in 0.66328 seconds with 46 queries
