Like Tree5Likes
 Old 10-18-2013, 04:51 PM   #41
glockman25's Avatar
Posts: 335   (View Stats)
glockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the world
Groaned at 8 Times in 5 Posts
How bout a built in shift knob like one piece no threaded piece
glockman25 is offline   Reply With Quote
 Old 10-18-2013, 04:55 PM   #42
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
How would you get the boot on and off then?
Spiral1183 likes this.
Ryguy is offline   Reply With Quote
 Old 10-18-2013, 05:01 PM   #43
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
Groaned at 20 Times in 11 Posts
1. Make a heavy knob that comes with it.
2. Make a shift boot that comes with it.
3. It needs to have at least one bend in it to bring the knob closer to the driver's side. Preferably two bends, one to move it closer to the driver side and one to bring it further back towards the arm rest.
4. Make a model with a base as well.
dan7225 is offline   Reply With Quote
 Old 10-18-2013, 05:10 PM   #44
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Originally Posted by Brydon@CorkSport View Post
I've never driven a subaru that clicks. Or I'm not sure what that means. I think the big difference is Subarus use a shifter that is directly attached to the transmission that move metal rods to change gears. The MS3 use a cable shifter so there is always something lost in feeling.
Hes talking about how shift linkage feels. Its notchy and feels more solid.
Me personally I have removed all the weights, ssp combos. I also went back to the stock shift knob.
Whatever you make, make a heavier stock like shift knob.
Okthanxbai
The Following User Says Thank You to Voltron For This Useful Post:
breakfstincluded (10-20-2013)
 Old 10-18-2013, 05:14 PM   #45
glockman25's Avatar
Damn didn't think about that. No boot needed a shift plate would be cool looking
 Old 10-18-2013, 05:25 PM   #46
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Everybody and their brother makes heavier shift knobs. Does the same thing as a heavier counterweight.
I'm gonna try adding weight to the counterweight while keeping the stock knob and see how that does. I'll just tape a heavy piece of steel or iron to it, I'm sure the welders got something lying around. If that's any good I'll rig up something more permanent. My shifter feels notchy no matter what. 2nd gear is better with that ford gear oil, but everything else stayed the same.
 Old 10-19-2013, 07:44 PM   #47
Mr.Bison's Avatar
Posts: 118   (View Stats)
Mr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the world
Maybe a slight height reduction while offering crisper throws...just added Ford cum to the tranny too, something like this would be perfect.
12' CWP MS3
--SURE Aeros SRI--Black Rear Valence--SURE Anchors--CS RMM 80D--FoMoCo Juice--CS Axleback--TWM Spector
Mr.Bison is offline   Reply With Quote
 Old 10-20-2013, 09:50 AM   #48
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
How about some gated shifter action?
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Last edited by Alexander; 10-20-2013 at 09:50 AM. Reason: MSF Database - Automerged Doublepost
Alexander is offline   Reply With Quote
The Following 5 Users Say Thank You to Alexander For This Useful Post:
chaser27 (10-20-2013), Cujo (10-21-2013), jm211 (11-21-2013), manila (11-21-2013), ZetaDrift (10-22-2013)
 Old 10-20-2013, 12:00 PM   #49
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
mmm... shift cable upgrade... would sell like hotcakes
hnda etr (11-21-2013)
 Old 10-20-2013, 05:03 PM   #50
daytonabluez05's Avatar
Posts: 222   (View Stats)
daytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant futuredaytonabluez05 has a brilliant future
would it come with shifter base bushings by any chance?
daytonabluez05 is offline   Reply With Quote
 Old 10-20-2013, 06:21 PM   #51
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
The TWM full replacement shifter at 10% of the cost would be nice.
Alexander (10-23-2013), Realgib3 (10-25-2013)
 Old 11-15-2013, 05:44 PM   #52
jm211's Avatar
Posts: 943   (View Stats)
@CorkSport; im excited on some updates for this. Would ya'll mind posting some product updates and which platforms you are building for?
The Following User Says Thank You to jm211 For This Useful Post:
Kdawg207 (11-21-2013)
 Old 11-19-2013, 09:08 AM   #53
anotherneon's Avatar
Posts: 128   (View Stats)
anotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant future
Groaned at 14 Times in 7 Posts
Rod brakes or stop bolts so you cant over throw the shifter once its in gear. Perhaps the rod hitting the rod brakes will give those users the satisfaction of knowing they are in gear and hearing that "click" they are looking for. It also gives your had feedback knowing you're in gear.
anotherneon is offline   Reply With Quote
The Following User Says Thank You to anotherneon For This Useful Post:
jm211 (11-19-2013)
 Old 11-21-2013, 11:51 AM   #54
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
What i'm looking for:
Something to get rid of the stock shifter slop
Something that won't fall apart(i see you are using the threaded holes for multiple cable adjustments like the cobb)
One that won't eat up the stock plastic shifter housing on the gen 1.
or if it has a chance of eating it provide something like the seriouspeed plate.
SeriouSpeed Slick Shift - SeriouSpeed.com - Get Serious
EDIT: i'd also like to see a perch for the shift boot.
There will only be machined surfaces that touch the factory pieces. So no need for a plate like seriouspeed.
How would a machine surface prevent the ware of the stop that forces you to push down for reverse?
Smooth transitions. Similar to Gen2 from Gen1 operations.
I'm not sure Brydon is either a) understanding this issue or b) isn't clear in his description.
The issue that people are talking about is that on the Cobb STS, the "Pin" that hits the factory composite shifter body is flat and sharp (at least it was on their old ones, not sure about how the ones produced nowadays are) and eventually digs away the material on the reverse lockout "bridge". This "bridge" is the piece that the SeriousSpeed metal plate covers. This is the part that makes you press down on the shifter to continue pressing the shifter to the left to get into reverse gear.
Once the material gets chewed up enough, the shifter can then glide right past first gear and into the reverse gear "shift area" - especially if you have any downwards force on the shifter when you try to go in to first - like when you rest your hand on the shift knob like i do. This is the main reason I purchased the TWM full replacement, to replace the OEM assembly.
Brydon, your STS either needs to have a ball/rounded end on the "reverse lockout pin" so that it doesn't dig away at the OEM composite assembly, or include the same type of metal plate like SeriousSpeed has to repair existing damage and/or prevent future damage. Make it an "add-on" option.
If you already understand what I'm saying, well then... Your replies need to be better lol
The Following 3 Users Say Thank You to hnda etr For This Useful Post:
breakfstincluded (11-21-2013), Deldran (11-22-2013), El_Diablo (11-21-2013)
 Old 11-21-2013, 11:58 AM   #55
hnda etr's Avatar
Groans: 90
Well their recent history would point to Gen 2 only lol...
 Old 11-21-2013, 12:03 PM   #56
This "bridge" is the piece that the SeriousSpeed metal plate covers. This is the part that makes you press down on the shifter to continue pressing the shifter to the left to get into reverse gear.lol
Do you has a link or directions to where I can find such plate?
Are there any issues with it?
 Old 11-21-2013, 12:09 PM   #57
jm211's Avatar
Good point. Well, one can be hopeful. They've been quiet on here lately.
 Old 11-21-2013, 12:19 PM   #58
ABolewski's Avatar
Posts: 1,279   (View Stats)
If you guys want less slop, at minimum the entire shifter base needs to be replaced (e.g. The TWM MS3 full replacement shifters), but really the issue is the cables. Nothing really can be done about that. The design of the chassis and trans don't lend themselves for metal shift rods, and unless you want to convert the engine to mount longitudinally, you can't mount the shifter directly on the trans.
The only novel thing CorkSport could do is add adjustable shift knob height.
Has anyone ever heard of Nokon cable housing?
It's for road and mountain bike shifters (and those that use cable brakes). It is a system of barrels and spheres with holes through them, where a teflon tube runs through, all with the cable inside. Although you will still have the cable which eventually stretch and give slightly, the cable housing, which in bikes is probably 75% or more of the issue, is now completely solid with zero give.
Here's an example of it on a bike. I used it on my shifters, and when I used my XTR v-brakes (I would swap with my juicy 7's for dry days) braking and shifting were phenomenally better than when I had traditional cable housing. The old housing required a lot of constant adjustment (and replacement) where as the Nokon needed to be dialed in just once and even the inner cable never needed to be touched for shifters or brakes.
Just a thought.
(sold)
Last edited by ABolewski; 11-21-2013 at 12:22 PM. Reason: Shitty fucking ship internt doublepost
The Following 2 Users Say Thank You to ABolewski For This Useful Post:
sidekick (01-07-2014), silvapain (11-21-2013)
 Old 11-21-2013, 12:25 PM   #59
hnda etr's Avatar
Groans: 90
Ummm... it's in my post (where I quoted 2.0t03speed) and in the original post by 2.0t03speed?
Just a thought.
Why the double posting? lol
The problem is with our cables stretching, like you mentioned. It's not with the housing/sheathing. Once the cables stretch, you start getting more "slop/play" in your shifter and the only thing you can do is replace the cables.
A cable shifter system itself is inherently less precise and more vague than a direct linkage or rod system is, as Silvapain already stated.
Except for Kim@CorkSport; showing up in shout for sexual harassment lol
Last edited by hnda etr; 11-21-2013 at 12:31 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to hnda etr For This Useful Post:
ABolewski (11-21-2013), Kim@CorkSport (11-25-2013)
 Old 11-21-2013, 12:31 PM   #60
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
A true short shifter would be nice... Back in my ricer days, I had a short throw shifter in my neon. Made custom by some guy at his work, went by 'Maddog'. Kind of how Tokay makes seals. Cost me $50 + my shifter (after receiving the new one) because neon. Best shifting ever. I prefer relatively short throws though. I still have the POS somewhere if you want pictures for some reason
 Old 11-28-2013, 08:33 AM   #61
RevolverRob's Avatar
Posts: 423   (View Stats)
RevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the world
Groaned at 22 Times in 13 Posts
Late to the game.
Screw the cheap shifter. I want a solid built replacement that just doesn't suck. Metal base, metal over-travel stops, adjustable length throw, combined with a SERIOUS shift cable because the stock one is SHIT. I know your competitors offer a good shifter, but I'm working on being CS loyal and no one offers a quality shift cable.
-Rob
2010 Mazdaspeed 3 - Celestial Blue - Stock'ish - Driver Mod
In honor of: PTE. Andrew Miller, 2 Field Ambulance, 1 RCR Battle group, gave the ultimate sacrifice for the ultimate cause of freedom, June 26, 2010.
RevolverRob is offline   Reply With Quote
The Following 5 Users Say Thank You to RevolverRob For This Useful Post:
chaser27 (11-28-2013), Cheapspeed (11-28-2013), El_Diablo (11-30-2013), Hectik1 (01-10-2014), Mauro_Penguin (12-13-2013)
 Old 01-06-2014, 11:21 PM   #62
Updates?
Mazdaspeed 6 Short Shifter install DIY TWM Performance MazdaSpeed 6 - How-To's 5 04-30-2013 11:57 AM
Real Suede Shifter/Ebrake boots bigx5murf Miata - Wheels, Tires & Appearance 4 11-26-2010 09:09 AM
Is this a real TWM shifter? wankular MazdaSpeed 3 - Engine, Transmission & Driveline 18 03-06-2010 03:09 AM
Page generated in 0.42834 seconds with 35 queries
