![]() Join Date: Nov 2010 Location: windsor ontario canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score I have to say that the quality and completeness of the kit is very good. I am going to the track this Wednesday and Saturday to get my MS6 into the bottom 12 and maybe an 11. I will let you know how it goes. |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score I can hardly wait.
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | KiwiFlavor (09-19-2018) |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | KiwiFlavor (09-19-2018) |
| Not Ranked : 0 score Hey, if a certain person (s) can do it on a K04, anyone can do it with a CS.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | KiwiFlavor (09-19-2018) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Where's OP at! The suspense is killing me!
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | CorkSport (09-20-2018) |
3 days for tuning and getting used to it is short...And the small CS isn't the first choice of average peoples targeting 11s... Unless he get the larger prototype CS that doesn't seem to be availaible for sale yet https://corksport.com/blog/corksport-big-turbo/
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | CorkSport (09-20-2018) |
(Thread Starter) | Not Ranked : 0 score Well I had trouble shifting 1-2 and 2-3. Which caused us to cut the day short. I am not sure if it is me or the car. Having to granny shift 1-3 and 2-3 I still managed a 12.5@113. I was only at 68 duty cycle on the wastegate and never put race gas in it since I was struggling to shift. So the turbo wasn’t maxed out 23-24psi, 11.3-11.4 afr and 15* timing on pump gas and meth. Next year it will go 11’s on this turbo for sure. It could easily get a ms6 to 115mph. I just need to do my part. |
![]() Join Date: Sep 2018 Location: Just North of Boston.
Rep Power: 0 ![]() Thanks: 3
Oh and I ran a 2 consistently for the past 3 weeks, so whatcha got on that? And by 2, I mean 2 wheels up on stands, in the driveway, as I am in the middle of some bullsh*t! Nice runs though, 12.5@113! Just waiting to get flamed by someone telling me how they consistently run 8's or some craziness.... Last edited by Tomumass06; 09-30-2018 at 06:48 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score He's referring to the duty cycle of the boost control solenoid.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Tomumass06 (09-30-2018) |
| Not Ranked : 0 score Fstrnyou, how do you get all that info "below the line" starting with "2006 MS6Gt-159.7k Miles...." etc? Is this achieved by editing your signature or by some other whimsical means? Again, I cannot "Forum", haha. |
| Not Ranked : 0 score Signature
| Los Angeles: 2014 Porsche Panamera Turbo S is a 911 Turbo for the family man | Haltech | Automotive News | 0 | 11-21-2013 10:20 AM |
| Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] | Haltech | Automotive News | 0 | 05-03-2013 07:50 AM |
