  • 1 Post By Mazdazilla6
 Old 08-10-2011, 01:42 PM   #1
Josh Whitehead's Avatar
Posts: 54   (View Stats)
Josh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud ofJosh Whitehead has much to be proud of
Groaned at 6 Times in 4 Posts
Default 06-07 Mazdaspeed 6 TSB and Recall list.
Figured I would put this up, I did this a few years ago and I need to update it which I will try to do here in the next few weeks.
Recall 4106E
Recall 4807H
Recall 4907H
09-014/06 - 2006 MAZDA6, MAZDASPEED6, 2007 CX-7 - POWER WINDOW AUTO OPEN / CLOSE AND ANTI-PINCH FEATURES INOPERATIVE
01-009/06 - 2006 MAZDASPEED6 - COOLANT LEAK AT RADIATOR SUB-TANK HOSE
01-023/06 - 2006 MAZDASPEED6 - MIL ILLUMINATION WITH DTC P0300 OR DTCs P0301 - P0304 DURING PDI
09-021/06 - 2006 MAZDA6 AND MAZDASPEED6 - INFORMATION DISPLAY DOES NOT ILLUMINATE / CLOCK RUNS FAST IN SUB-ZERO TEMPERATURE
09-048/06 - 2006 MAZDA6, MAZDASPEED6, AND 2007 CX-7 - WINDOWS OPEN UNINTENTIONALLY
09-050/06 - 2006 - 2007 MAZDASPEED6 - REMOTE KEYLESS ENTRY (RKE) TRANSMITTER SPECIFICATION CHANGE
03-001/08 - 2006 - 2007 MAZDASPEED6 - OIL SEEPAGE FROM TRANSFER CASE
09-004/08 - 2006 - 2007 MAZDASPEED6 - TCS / DSC WARNING LIGHT ON WITH DTC C1956
08-002/06 - 2004-2006 RX-8, MPV, 2006 MAZDASPEED6 - AIRBAG (SAS UNIT) REPLACEMENT CAUTION - DTCs B1342 / B2477
09-024/07 - 2006 - 2007 MAZDASPEED6 - TRUNK LID REQUEST SWITCH INOPERATIVE DUE TO FAILED ADVANCED KEYLESS ANTENNA - DTC B1131
09-023/07 - 2006 - 2007 MAZDASPEED6 - TRUNK LID REQUEST SWITCH INOPERATIVE - NO DTCs
05-003/07 - 2006 - 2007 MAZDASPEED6 - CLUTCH PEDAL IS DIFFICULT TO OPERATE
01-040/07 - MULTI MODEL - FRONT CRANKSHAFT BOLT SERVICE WARNING
01-002/08 - MULTI-MODEL - VARIABLE VALVE TIMING (VVT) NOISE WHEN STARTING ENGINE
01-037/06 - MULTI-MODEL - MIL COMES ON WITH DTC P2407 (LDP SENSOR ERRATIC)
01-022/08 MULTI-MODEL- ROUGH IDLE, LACK OF POWER, AND/OR MIL ON WITH DTC P2177/P2187 (FUEL SYSTEM LEAN)
M-Tips
Mar_Apr_08_Correct_Oil_Filter_Wrench_For_LF_L3_Eng ines.pdf
May_Jun_07_CX-7_Mazdaspeed3_6_DISI_Fuel_Pump_Pressure_Specs.pdf
May_Jun_07_Mazdaspeed3_6_DISI_Oxygen_Sensor_Remova l_Precaution.pdf
Sept_Oct_06_2006-2007_CX7_MX5_Mazdaspeed6_RX8_Customizable_Features .pdf
Jan_Feb_08_All_Models_Short_Antenna.pdf
Jan_Feb_08_Multimodel_Cooling_Fan_Runs_After_Ign_T urned_Off.pdf
Mar_Apr_07_Multimodel_Engine_Oil_Specification_5W-30[1].pdf
Jul_Aug_05_2006_Mazda6_Mazdaspeed6_Power_Window_In itialization[1].pdf
May_June_05_2006_Mazdaspeed6_Power_Windows[1].pdf
Mar_Apr_06_2006_Mazdaspeed6_Fire_Wall_Tube.pdf
2006 Mazda MAZDASPEED6 TSBs (Technical Service Bulletins) | MazdaProblems.com
06 MS6 Touring -AEM CAI (True 3" mod), Cobb AP
07 MS6 GT bone stock - sold
93 Mazda RX-7 "OMG WTF" - LS1/T56 swap - 10.71@136 pump gas and drag radials - sold
89 Mustang LX - 436 CI/ 5-spd - 525 RWHP 475 RWTQ N/A 11.02@127 pump gas and slicks - sold
93 Z28 LT1/T56 360 RWHP stock longblock NA - sold
Ford and ASE Master Certified Techinician
Josh Whitehead is offline   Reply With Quote
The Following 11 Users Say Thank You to Josh Whitehead For This Useful Post:
Decepticon (07-23-2013), dkapetansky (08-10-2011), Hickpunk (09-04-2012), jrlms6 (08-10-2011), keefover (08-12-2011), redmnsterut (08-10-2011), robertof (03-06-2012), Stealth01 (08-10-2011), svd (09-20-2011), urbansurfer (08-10-2011), xI Leveler Ix (09-11-2012)
 Old 01-19-2014, 09:25 PM   #2
Links aren't working anymore.
bco98 likes this.
Jh8909 (01-27-2014), jrlms6 (06-24-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/06-07-mazdaspeed-6-tsb-recall-list-88451/
Used Vehicle Review: Mazdaspeed6, 2006-2007 - Autos.ca | Page 3 This thread Refback 04-25-2015 08:45 PM
Used Vehicle Review: Mazdaspeed6, 2006?2007 - Autos.ca This thread Refback 02-14-2013 08:31 AM
Used Vehicle Review: Mazdaspeed6, 2006?2007 - Autos.ca | Page 3 This thread Refback 02-14-2013 07:29 AM
Rear keyless entry receiver This thread Refback 01-18-2013 12:12 PM
Mazda 6 MPS/Mazdaspeed6: - 7 - MAZDA Club Belarus - MAZDA - This thread Refback 10-16-2011 07:19 AM
MAZDA Club Belarus - MAZDA - - - Mazda 6 MPS/Mazdaspeed6: This thread Refback 10-12-2011 12:09 PM
2007 Mazdaspeed 3 heavey smoke recall kingbird72 Mazdaspeed3/6 General Discussion 62 07-11-2011 07:16 PM
Camry pedal recall prompts secondary repair, Toyota denies it's recalling a recall Haltech Automotive News 0 12-03-2010 09:50 AM
Page generated in 0.26988 seconds with 21 queries
