 Old 02-14-2012, 08:43 AM   #1
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
Default 60-130 the final tune.
So after getting the SURE big MAF dialed in just right, I decided to grow some balls, crank the boost up and bring it on sooner. - I had pushed it back about 500 RPM in fear of blowing up, But this motor has been amazing I decided to push it a little further.
full boost is now @ 3800 RPM
This is my most aggressive tune and my final tune for this turbo, Any further and I know I will loose the engine.
24PSI 22* max timing and a target AFR of 11.7 to 12.2
car pulled insanely hard spinning from 65-80 and then again after the shift into 5th around 113. 60-130mph in 8.4 seconds with no running start I went WOT @60, and had an extra 150 pounds in the car.
with no extra weight and some sticky tires I should be able to run an 8 flat... but then again the engine has been running extremely well lately, this may be the calm before the storm.
now does anyone want to do some runs before I do lose it lol... Vids of course.
dturboman is offline   Reply With Quote
The Following 4 Users Say Thank You to dturboman For This Useful Post:
802MS3 (02-15-2012), Brian MP5T (02-15-2012), Docnox (02-18-2012), Vinnie (02-15-2012)
 Old 02-15-2012, 01:40 PM   #2
59ksmall's Avatar
Posts: 167   (View Stats)
59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of59ksmall has much to be proud of
Damn, what mods do you have?
59ksmall is offline   Reply With Quote
The Following User Says Thank You to 59ksmall For This Useful Post:
dturboman (02-15-2012)
 Old 02-15-2012, 05:59 PM   #3
dturboman's Avatar
[QUOTE=59ksmall;1261844]Damn, what mods do
Gt30 and all supporting mods, lots of meth, lots of timing and magic sauce.... Not to be confused with McDonald's secret sauce.
 Old 02-15-2012, 02:54 PM   #4
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
so what does this translate into a 40-120 time?
The Following 5 Users Say Thank You to karl-hungus For This Useful Post:
BrianZX10R (02-15-2012), doubleflusher (02-15-2012), dturboman (02-15-2012), predapio (02-15-2012), SofaKingAwesome (02-15-2012)
 Old 02-15-2012, 05:48 PM   #5
dturboman's Avatar
40-120 in maybe 20 seconds, I would never get traction on street tires that is.
I can't wait for a warm day.
Yeah it should be fun.... 50+ day and we have some nice runs... Should be decent
Last edited by dturboman; 02-15-2012 at 06:11 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to dturboman For This Useful Post:
doubleflusher (02-15-2012), karl-hungus (02-16-2012)
 Old 02-15-2012, 04:13 PM   #6
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
you da man
'08 CWP MS3 w/ T3 3071r
 Old 02-15-2012, 04:14 PM   #7
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Groans: 62
Don't kill it before the pedobear meat! I can haz ride?
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
The Following User Says Thank You to Don06speed6 For This Useful Post:
 Old 02-15-2012, 05:52 PM   #8
dturboman's Avatar
To be honest she should have blown a while ago so who knows, whats this pedafile meat you speak of. I have seen a post in nator pa about it but never read it....lazy right
Originally Posted by Schmitty5 View Post
160k ... what have your replaced?
Tires, brakes,clutch, and drive belt.
Last edited by dturboman; 02-15-2012 at 05:54 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-15-2012, 04:20 PM   #9
snowms3's Avatar
Posts: 287   (View Stats)
snowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond repute
cant wait to get a bigger turbo
2009 cwp MS3. COBB SRI, COBB inlet pipe, CPE catless DP, GHL catback(drone-free), SURE RMM, JBR PMM 80d, DASHHAWK, COBB AP STRATIFIED TUNED BY LEX 3/10 E85, ATP FMIC, HKS SSQ Full recirc, AUTOTECH INTERNALS, WHITELINE 27mm Adjustable RSB, Einkei RPF1 gold/ Firestone Wide Oval Indy 500 235/45/17, GORILLA BLACK LUGNUTS.
snowms3 is offline   Reply With Quote
The Following User Says Thank You to snowms3 For This Useful Post:
 Old 02-15-2012, 04:27 PM   #10
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Beanfab / Tuned by Nishan
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
BrianZX10R (02-15-2012), dturboman (02-15-2012), trf5000 (02-15-2012)
 Old 02-15-2012, 05:48 PM   #11
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
The Following User Says Thank You to Schmitty5 For This Useful Post:
 Old 02-15-2012, 06:24 PM   #12
Groans: 62
Pedobear meat @ tonellies on the 25th
 Old 02-15-2012, 06:33 PM   #13
dturboman's Avatar
So are you saying I should come to this? I know noone on here... Only met flusher for 1 minute when i bought tires off him.
U guys do runs at this meet or just eat?
The Following User Says Thank You to dturboman For This Useful Post:
Don06speed6 (02-15-2012)
 Old 02-15-2012, 06:36 PM   #14
Groans: 62
Eat and bullshit. Its a good time, runs can be set up I'm sure. I'm not from the area but I'm sure a local knows of somewhere to run. The moar the merrier!!
 Old 02-15-2012, 06:39 PM   #15
dturboman's Avatar
Turnpike, 95, or route1 are the only places to pull serious speeds... That I know o
@doubleflusher maybe we can do some runs this day if your going to this.
 Old 02-15-2012, 06:52 PM   #16
Groans: 1,443
I usually get the runs after I eat Tonelli's.
Let's see what the wife says, before I commit.
The Following 2 Users Say Thank You to doubleflusher For This Useful Post:
Don06speed6 (02-15-2012), dturboman (02-15-2012)
 Old 02-15-2012, 06:55 PM   #17
dturboman's Avatar
Sounds like great food, we can do it whenever... Let me know what works for you. Nights or weeks are my free times.
 Old 02-17-2012, 09:37 PM   #18
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
more info about the sure big maf aeros?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
dturboman (02-18-2012)
 Old 02-18-2012, 04:22 PM   #19
dturboman's Avatar
Here's a little review i did on it.... its been a huge improvement over a universal big MAF
SURE Big MAF TESTED!
86AmishMs3 (02-18-2012)
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Final dealer arbitration case today; final rulings due within 10 days Haltech Automotive News 0 07-14-2010 01:30 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.38316 seconds with 29 queries
