 Old 03-15-2008, 02:18 PM   #1
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
Default AEM Water/Meth Injection Kits In Stock
Alright, I got 4 of these on the shelf, I want to know if I can move these.. hate looking at them.
Info:
You don’t have to worry whether AEM has your application because the Water / Methanol Injection Kit is designed to be universal for practically any vehicle. It includes everything you need to adapt it to your steed. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error.
-Universal kit includes everything you need for installation
-Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
-Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
-One-gallon tank with integral fluid level sensor
-Dash light for system status and low fluid warning
-Methanol Compatible (up to 50% in solution with water)
-Includes three jets to match your power requirement
How it works:
Once installed, the Water / Methanol Injection Kit uses a boost-dependent, variable-flow progressive controller to determine the amount of water / methanol mixture (up to 50%) to feed into the inlet stream from the included one-gallon reservoir. The controller commands a progressive 150-PSI pump that delivers the mixture, and flow adjustments at the inlet are made via three included jets designed to match most engine power requirements. The result is significant horsepower gains using pump gas—at about half the cost of Racing Fuel.
Why you want one
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
MSF.org Member Price: $359.00
Free ground shipping with insurance, tracking, etc.
To order your today, or if you have any questions, please post, PM, IM, or email us.
-Pathik
Performance Racing
Performance Racing is offline   Reply With Quote
 Old 03-26-2008, 01:18 PM   #2
Bravnik's Avatar
Posts: 383   (View Stats)
Bravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond repute
Groaned at 33 Times in 22 Posts
I have been looking at a W/M solution for some time. My only concern is what will it do to our AFR's seeing as most are 10's or lower. I know I'm at like Mid to High 9's when WOT running 19PSI, Test Pipe, Map Clamp, Forge and MS CAI. Do you know what kind of drop in our AFR's we can expect?
I'm looking for a W/M solution to make up for the crappy gas in CA. 91oct + Ethanol of 10% = the suck. I think my car would run a lot better with 93oct+.
Thanks for the advice.
Bravnik is offline   Reply With Quote
 Old 04-10-2008, 04:24 PM   #3
det_ms3's Avatar
Posts: 479   (View Stats)
det_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the world
you're car will run better with 93. i've tried running 92 in my car a couple times and my car hates me for it. i don't have anything to watch the AFR's but you can feel the difference in the car and loves it when i run 93 or 94. 94 is optimum but it usually costs me 10-13 cents more than 93 so i've been holding off on running it lately. but trust me your car would love you for it if you could find it in CA or something to make up for it. Also i read something on octane boosters years ago and there were a few out that really do work. i can't remember which ones maybe you could google it.
2008 Sunlight Silver MS3 the toy
2012 Chrysler 200 Limited 3.6l the daily driver
det_ms3 is offline   Reply With Quote
 Old 04-10-2008, 05:09 PM   #4
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
In-Line Check valve?
mexicant is offline   Reply With Quote
Direct Injection Systems mrlilguy157 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 04-07-2014 01:51 PM
Water/Meth Bravnik MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 05-03-2008 06:39 AM
Stock pump looks OK on stock engine enganear MazdaSpeed 3/6 - ECU Computer Tuning 33 04-08-2008 09:21 AM
Porsche 911 update includes 100% more awesome: Direct-injection, dual-clutch gearbox Haltech Automotive News 0 04-04-2008 04:50 PM
TATUNG THWP-3L Eletronic Hot Water Dispenser - Ret $29.99 Free Shipping Haltech Hot Deals Section 0 03-26-2008 07:20 PM
Page generated in 0.28338 seconds with 23 queries
