Like Tree3Likes
 Old 01-16-2020, 09:20 AM   #1
joefromkocomo's Avatar
Posts: 30   (View Stats)
joefromkocomo is just really nicejoefromkocomo is just really nicejoefromkocomo is just really nicejoefromkocomo is just really nicejoefromkocomo is just really nice
Jesus. So last night I was driving and giving it a little gas from 3k in 3rd gear, still on the Cobb Stage 0 which is allegedly a simulated stock map. I look down at my AP after a quick pull from 30-60 and see that the upper bound of my boost number was ~17.6 lbs. I know for damn sure a stock map should be tuned with a boost target of 15.5-15.6 lbs. I started logging so I could take a look at home to see what was going on, and sure enough I had one cell of boost spike. Shifting from 3rd to 4th, as soon as the turbo spooled in 4th it spiked to 17.68 lbs. I know the K04 is capable of 18-19 lbs safely, but if I'm 2 lbs over target that doesn't seem too great. No KR reading at all. I'm really just thinking of uninstalling the AP until it's time for tuning at this point. Am I thinking correctly, or am I just paranoid? Datalog attached.
'07 Mazdaspeed3 Mostly Stock... for now.
joefromkocomo is offline   Reply With Quote
 Old 01-16-2020, 12:12 PM   #2
Police - Grammarhead
Vansquish's Avatar
I wouldn't install anything just yet.
Please re-take some datalogs and include the following logging parameters (some things were missing in your log, and other unnecessary parameters were present). Note that a proper WOT datalog should be taken on a flat, smooth, straight road and it should begin just under 3000rpm and run to at least 6000rpm in a single gear (preferably 3rd or 4th).
Accelerator Pedal Position
Actual AFR
Boost (psi)
Boost Air Temp
Calculated Load
Coolant Temp
HPFP Actual Pressure
Inj. Duty Cycle
Intake Temp
Intake Valve Adv.
Knock Retard
Long Term Fuel Trims (LTFT)
MAF Voltage
MAF Airflow
RPM
Short Term Fuel Trim (STFT)
Spark Advance
Throttle Position (not throttle duty cycle)
Vehicle Speed
Wastegate Duty
joefromkocomo (01-18-2020)
 Old 01-16-2020, 08:10 PM   #3
Actual AFR
Boost (psi)
Boost Air Temp
Calculated Load
Coolant Temp
Inj. Duty Cycle
Intake Temp
Intake Valve Adv.
Knock Retard
MAF Voltage
MAF Airflow
RPM
Spark Advance
Vehicle Speed
Wastegate Duty
I'll edit the logging parameters and take one either tomorrow or Saturday and post. Very clearly I still have much more research to do if I wasn't aware that stock maps are load based, which would make boost spike less of an issue. It sounds like sustained values over the boost target are the real issue.
tegxsi: I don't think what I was doing there would be considered true WOT. I wasn't on a stretch of road where I felt good really laying into it for a true WOT pull. More like I saw something I didn't like and wanted to take a quick log to see if it did it again and was something I needed to look further into. Of course this is all speculation, I'll just get a proper datalog and post again with real data instead of speculative bullshit.
The Following 2 Users Say Thank You to joefromkocomo For This Useful Post:
MSMS3 (01-18-2020), Vansquish (01-16-2020)
Need help with spike Zak MazdaSpeed 3/6 - ECU Computer Tuning 4 02-09-2011 07:59 PM
WTF is this spike? Jarods7920
Cobb ATR Support
1 12-14-2010 05:19 PM
Spike of KR only happens sometimes at WOT Lex MazdaSpeed 3 - Engine, Transmission & Driveline 26 07-08-2009 09:37 AM
Strage KR Spike badams118 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 01-31-2009 05:38 PM
Page generated in 0.28044 seconds with 23 queries
