Closed Thread
 Old 10-19-2014, 02:45 PM   #1
thebestdj07's Avatar
Posts: 48   (View Stats)
thebestdj07 has a spectacular aura aboutthebestdj07 has a spectacular aura aboutthebestdj07 has a spectacular aura about
Default another burnt valve
anyone have any idea what would cause me to keep burning exhaust valves? its a stock msp6 with 140k. about 4000 miles ago on cyl 3 it burnt one getting onto the highway. had it replaced and ran good. same thing happed today. 0 compression on cyl 3 and ~150 on the rest with the engine warm. it always has left a black smoke cloud when going wot.
thebestdj07 is offline
 Old 10-19-2014, 03:16 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Obviously your cylinder temps/EGTs are above normal levels if your repeatedly cooking valves.
Any CELs?
Any way to monitor your AFRs?
What is the state of your EGR system?
Agent_Orange is offline
Easter Bunny (10-19-2014)
 Old 10-19-2014, 03:16 PM   #3
sidekick's Avatar
Posts: 3,093   (View Stats)
Has the timing chain ever been replaced? Have you adjusted the valves?
sidekick is offline
 Old 10-19-2014, 03:33 PM   #4
no cel prior to it happening. i have a wideband but no place on the factory pipe to put it. egr was cleaned this past winter when the head was off. timing chain and vvt were done also. valves clearance was checked last time head was off all were in spec.
it does use alot of oil say quart ever 150 miles.
 Old 10-19-2014, 03:43 PM   #5
sidekick's Avatar
If you're using a quart of oil every 150 miles, I'd say you have much bigger issues... But bad injector? Or injector stuck open? Major detonation in cylinder 3? Did they re-machine the valve seat when replacing the bad valve last time? If the valve is not making good contact with the seat, you can get major hot spots, which could then lead to a burnt valve.
sidekick is offline
Agent_Orange (10-19-2014), Easter Bunny (10-19-2014)
 Old 10-19-2014, 03:50 PM   #6
yea the shop re machined the seat into the head. as far as the oil what would you think? the turbo just got a new chra installed.
 Old 10-19-2014, 03:53 PM   #7
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Who tuned it?
Gr8Speed is offline
 Old 10-19-2014, 03:55 PM   #8
Who tuned it?
mazda lol. its bone stock
The Following User Says Thank You to thebestdj07 For This Useful Post:
Gr8Speed (10-19-2014)
 Old 10-19-2014, 04:17 PM   #9
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Let it burn another one and lemon law (if applicable) that car.
Enki is offline
 Old 10-19-2014, 04:21 PM   #10
i wish in ohio its 12mo or 18,000 miles.
 Old 10-19-2014, 05:13 PM   #11
Turbo_Steve's Avatar
Posts: 944   (View Stats)
If you are going to fix it I would replace the injector on that cylinder for sure. Also replace your primary o2 sensor if it's never been changed. Clean or replace the maf sensor too. 140k is probably a good idea to change all 4 injectors. But 1 quart every 150 miles tells me you need a complete rebuild.
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline
 Old 10-19-2014, 05:56 PM   #12
sheston's Avatar
Posts: 1,847   (View Stats)
That's your problem, being stock - JK. You just need some E85 or Meth to cool down the combustion
sheston is offline
Closed Thread
clutch slipping or burnt up? MImarine MazdaSpeed 6 - Engine, Transmission & Driveline 5 07-09-2013 08:54 AM
Burnt Clutch? jeffreyj MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-19-2012 08:44 PM
Burnt my seat Snotrocket Interior 38 04-04-2011 06:50 AM
Oil smells burnt? SRTie4k MazdaSpeed 3 - Engine, Transmission & Driveline 13 11-16-2009 08:17 AM
Image burnt onto screen Death-From-A-Mile
Cobb Access Port/Maps
3 09-16-2008 01:43 PM
Page generated in 0.32071 seconds with 26 queries
