 Old 02-17-2018, 04:23 PM   #1
94dsm's Avatar
Posts: 27   (View Stats)
94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts94dsm is infamous around these parts
Default Another compression thread.
Sup guys, sorry if this is in the wrong place the search bar keeps closing when my keypad opens on my phone. Anyways, I was looking at a getting my second speed today, took it into the shop and did a compression test, car reached 180,180,179,180 ... my question is, it took almost 15,20seconds of cranking. After throwing a booster pack on they all read between 190-195(seems high).. both rests cranked until needle stopped moving. But was moving just about 5psi each time... usually i get about half my max reading on the first crank when ive done tjis on other cars(non speeds). Was wondering if this is normal or something i should look into., I didn't have a leak down tester to further investigate. There was also oil on the plug threads. Tha ks in advance
94dsm is offline   Reply With Quote
The Following User Says NO Thank You to 94dsm For This Un-useful Post:
mituc (02-17-2018)
 Old 02-17-2018, 10:22 PM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
How many "another" are you going to open? Phoken look into the "other" initial compression thread and do a leak test, but not until you get sober.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Low compression and BNR S4 feldm4n MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-17-2017 04:46 PM
Restoring compression Tuff Gong Mazdaspeed3/6 General Discussion 22 08-09-2015 04:55 PM
Bad Compression 'MERICA MazdaSpeed 6 - Engine, Transmission & Driveline 14 08-08-2012 12:55 PM
Low compression MaverickX3 MazdaSpeed 6 - Engine, Transmission & Driveline 55 12-10-2010 04:41 PM
Page generated in 0.22654 seconds with 21 queries
