 Old 02-10-2018, 04:44 PM   #1
Whatsgoingon's Avatar
Posts: 6   (View Stats)
Whatsgoingon is an unknown quantity at this point
Default Is this a bad idea?
I’ve had my eye on a 2008 Mazdaspeed 3 for a little while now but im not sure if it would be a good idea to buy it. To start off, the car has 143k miles on it. The previous owner had a BNR stage 2 turbo installed on it (I dont know when it was installed, but ill try to figure out) along with a turbosmart BOV, Cobb intake, and Cobb catback exhaust. Would these mods decrease the reliability, as this car would become my DD. I would greatly appreciate any input on this. Thanks for your replies in advance!
Whatsgoingon is offline   Reply With Quote
 Old 02-10-2018, 05:36 PM   #2
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
High miles. I would not buy a daily with 100k miles. I would definitely not buy a car marketed as a fwd hot rod with 140k miles.
 Old 02-10-2018, 09:53 PM   #3
Varomnia's Avatar
Posts: 459   (View Stats)
Depends on finances. Your wording makes it sound like you couldn't afford to rebuild the car when it dies. Key word when, not if. These do not make good DD'ers at higher mileage.
If you're going to buy, set aside $200/month for repairs. That way, you got the funds to build if needed, and if it lasts 4 years without a problem (lucky you) then you got the funds to build anyway and go crazy with it.
I'd buy a crap civic as a DD to hold me over and buy a mazdaspeed shell and go crazy with the shell when I have money. But I have peculiar circumstances that make me want to go this route.
 Old 02-11-2018, 05:15 PM   #4
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
factor in either building a new motor or having one built, mine exploded with 111K on it, I think I was able to put 4kish on it before it went boom, taking the piston out that had the rod get pissed it appears that I had a ring problem, should have done a compression test after I bought it.
my car will be a DD but with forged pistons, H beam rods, CS turbo and so on, should be decent in my mind.
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
i have no idea what im doing? charern 2010 MS3 - ECU Computer Tuning 6 01-30-2013 09:58 PM
A 458 Italia-powered Fiat 500 is not a good idea, it's the best idea Haltech Automotive News 0 06-22-2012 12:10 PM
no idea what im doing Daftboy 2010 MS3 - ECU Computer Tuning 47 05-13-2012 11:05 AM
Just an idea... Fagwagon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 11-13-2009 05:11 PM
Page generated in 0.24832 seconds with 23 queries
