 Old 04-16-2008, 10:36 AM   #41
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
i can't wait...jon how is the power holding up near after 6k? Is it holding boost?
Laloosh is offline   Reply With Quote
 Old 04-16-2008, 11:01 AM   #42
ultraspeed619's Avatar
Posts: 268   (View Stats)
ultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the world
+1 Hoping to hear that this wheel is holding up! Can't wait to hear when my turbo is done and is ready to ship out!
MAZDASPEED6
Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs |
Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces |
Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems |
Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk |
ultraspeed619 is offline   Reply With Quote
 Old 04-16-2008, 02:35 PM   #43
Jspeed6's Avatar
Posts: 6   (View Stats)
Jspeed6 is an unknown quantity at this point
...once this is all proven to work/hold up and stop the smoking (im on my second smoking turbo) Im in! this is very exiting, I too feel there is great power to be made with the reworked stocker. Can someone PM me the details/ procedures for getting my stocker reworked by you guys as well as price? thanks. and great work to all
"Stock"
Jspeed6 is offline   Reply With Quote
 Old 04-18-2008, 12:31 AM   #44
ptperformance's Avatar
Posts: 4,123   (View Stats)
Low 20's at redline with a 24 spike. The WGA needs additional adjustment for better results. WGA testing is getting done on this car as well so we should have better answers in a week or so.
 Old 04-18-2008, 12:32 AM   #45
Its still holding up very well. I have the other smaller wheeled stocker here for 311, I just need to hear back from him that he got the turbine housing installed and tested.
 Old 04-18-2008, 12:36 AM   #46
Long term testing would take months if not years to complete. Right now we have 3 people testing for us and I have one on my car now as well. The smoking is coming from some where else (I think) and I hope to have a fix for that as well.
The details and price are as follows:
I need a stock turbo from you for core build up.
Cost is $599 for the turbo and $199 for the turbine housing work, full ceramic coatings on both will come standard.
Testing will be to 28 psi and we will not warranty shaft failures at this time for the bigger wheeled unit. The smaller stock wheeled unit should have our 90 day warranty on them. Hope this helps.
 Old 04-18-2008, 08:58 AM   #47
det_ms3's Avatar
Posts: 479   (View Stats)
det_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the world
that 599 is that if you supply the turbo? or even if say i gave you my stocker? just to clarify.
2008 Sunlight Silver MS3 the toy
2012 Chrysler 200 Limited 3.6l the daily driver
det_ms3 is offline   Reply With Quote
 Old 04-18-2008, 09:12 AM   #48
JumpingJackson's Avatar
Posts: 967   (View Stats)
Why no shaft failure warranty?
 Old 04-18-2008, 04:59 PM   #49
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
Because some idiot will try to run his turbo without a wastegate, then blaim it on PTP. They don't know how much boost you are running, something can be reccomended, but do people always follow that? The factory put a boost limit on the MS3, but many raise the boost.
mexicant is offline   Reply With Quote
 Old 04-18-2008, 05:36 PM   #50
Theres nothing wrong with raising boost. You just have to be sensible when you do it.
 Old 04-19-2008, 08:21 AM   #51
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
20lbs of boost on this upgrade turbo at redline? What is boost set at?
Performance Racing is offline   Reply With Quote
 Old 04-19-2008, 12:43 PM   #52
That is if you give me your stocker. We can do a core fee as well so you have no down time.
 Old 04-19-2008, 12:47 PM   #53
Consider yourself lucky that there is any warranty on them. 99% of all modded turbo upgrades are without any warranty, zero, nada, zip, zilch, nothing. We are one of the few modded stocker upgrade companies that offer a warranty with our turbos.
We are not going to warranty the shaft because at this moment we don't have the faith in the factory design. Its going to take some more work and verification that there is enough to support the bigger wheel set ups. Not only that but we have seen what customers do to the SST for the SRT4N, I can only suspect that the MS3 owners are going to do the same. When I get a turbo back for the SRT4N and its been over boosted (fins on compressor are all opened up), then I know that someone was either running with a major boost leak or running upwards of 30 + psi.
When we get it all figured out then maybe we will have a warranty on the shafts, only time will tell.
 Old 04-19-2008, 12:50 PM   #54
Bolded the part that most people seem to miss. When we do testing there is nothing sensible because we are trying to break it. Testing of the SST for the SRT4N found failures at 32 psi, this was running the turbo up to that pressure and not letting the BOV vent. By doing this we found the "failure point" for the SST. We also have other tests that play a part in getting a product to market, those are trade secrets.
 Old 04-19-2008, 12:52 PM   #55
23 to 24 spike. We can calm down the spike if need be but the car runs fantastic with the spike in there. We did see a 21/20 set up when we were tuning on 94 pump gas. Redline in this case is 6500, we are not running it all the way out and we have control of the throttle as well.
 Old 04-19-2008, 01:28 PM   #56
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
I'm just curious what you are tuning with? And how do you have throttle control now?
L76-powered
mdogg is offline   Reply With Quote
 Old 04-19-2008, 04:26 PM   #57
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Yeah, my concern is that the stock ECM might have the stock turbo's compressor map built into the programming to prevent over spinning based on MAP and MAF data.
Does anyone know the mechanism by which the ECM decides to stop to fun at >5500 RPMs? It is clear that it using the throttle position to kill massflow/pressure, but not what it is looking at when to determine this.
 Old 04-19-2008, 08:15 PM   #58
That is something people are just speculating on. We may really never know the truth.
 Old 04-20-2008, 01:07 PM   #59
12 volt hard wire to the driver motor, sets a code but doesn't kill the power. Tune is being ran with our tuning module. Its something that I have been trying to get marketed for a while and I will have something here very soon when I get that car over to Santa Anna.
 Old 04-20-2008, 01:16 PM   #60
Its possible but there are to many elevation calculations and other concerns like engine wear that come into play for something like that to be programmed into an ECU. Just not enough space.
MAP can be completely dissabled (showing no boost with a clamp device) and nothing gets affected. The MAF data can be manipulated as well with a good piggy back to read safe AFR's and fuel trims but run a 3" intake (trust me I know now). So the MAF and MAP based logics are not installed in this car. The 5500 RPM cut is controlled by RPM? Not sure but as time progresses on people will have a fix for it.
Here is the real problem, finding a DBW control box. I have talked with 20 different shops, EMS builders, GM R&D, and DCX engineers not one of them want to build something that gives control to the end user. Know why? LIABILITY!!!! If one item screws up and the car goes WOT all by its self, huge problems for who ever does this. I have a way to over come it but I will never ever post a how to or tell anyone how to do it. To much risk that some one would screw it up or have the car go WOT and kill someone.
As time continues on someone will be able to shut off the saftey for the DBW and let us have 100% throttle opening from the factory ECU. Its only time.
Tire and Wheel Calculator SpdFreak MazdaSpeed 3/6 - Wheels & Tires 11 01-06-2012 09:21 AM
Tire and Wheel Calculator SpdFreak MazdaSpeed 3/6 - Wheels & Tires 1 02-02-2011 12:47 PM
Effects of Wheel Size/Weight on Vehicle Performance Crossbow MazdaSpeed 3/6 - Wheels & Tires 3 02-18-2009 10:26 AM
Big Wheel Turbo upgrades inside... redrocketz Mazdaspeed3/6 General Discussion 50 07-15-2008 04:55 PM
big wheel jlarson1983 Mazdaspeed3/6 General Discussion 57 04-01-2008 07:29 PM
Page generated in 0.40295 seconds with 30 queries
