![]() Join Date: Apr 2011 Location: STL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
__________________ 2007 MazdaSpeed 3~ Sri, HKS Exhaust, testpipe,HKS bpv, cobb rear sway bar, turbo inlet, autotech internals, short shifter, sure rmm, and cobb ap 2009 Honda CBR 600 RR Phoenix Edition~ Stock |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score what other mods did you have and how many miles? |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score If it contributed to the failure, yes they can say the warranty doesn't apply...
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
![]() Join Date: Sep 2009 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score Remove everything BEFORE going to the dealer or it will be a tough sell for the warranty. Some dealers give a hard time because of the BPV/BOV. Tow it to your house or something. |
| The Following 2 Users Say Thank You to R.MS3 For This Useful Post: | alien_sporez (04-30-2011), rigor (04-30-2011) |
| Robust Mongoloid ![]() Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6482 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,137
Groans: 399
| Was it running the intake delete mod? How bout a "PhillyB hates me" sticker anywhere??
__________________ ______________________ Built By NATOR Tons of Ricer Mods
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
| Not Ranked : 0 score Be more specific what tuning device? Miles on car? I hope you were monitoring boost/fp/knock at the very least. If so any logs before the blow? Chances are you threw a rod. Stock it out take to dealer. |
| The Following User Says Thank You to dsmluck For This Useful Post: | alien_sporez (04-30-2011) |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score should of went big turbo! stock is dangerous! the tune has got you screwed
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 04-30-2011 at 05:11 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score Ive only had car a month and don't have gauges or anything to moniter that stuff. Car is at the dealer now. My buddy gave me his Cobb ap because be totaled his ms3 and when I try to hook it up it's says that there's already a devise locked to the car. I have 40,100 miles on car.
Groans: 60
| Not Ranked : 0 score Lol stock turbo isn't dangerous as long as you don't make stupid mistakes. The stock tune on the other hand is a pile of shit. Maybe if there is ever a bonefide cheap way to go BT like a Holset I'm sure everyone would be running them. |
(Thread Starter) | Not Ranked : 0 score There's also a metal ring Layin on the plastic cover that sits under engine so that's my guess what broke.
Groans: 40
| Not Ranked : 0 score you should of joined earlier and you could of avoided teh boom!
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
Groans: 60
The second you found out it had an unknown flash u should have talked to the seller and figured out what was up. The second thing you should have done was got a monitoring device. Pushing a car hard with an unknown and unmonitored tune is asking to blow. | |
| The Following 3 Users Say Thank You to dsmluck For This Useful Post: |
![]() Join Date: Aug 2009 Location: Kingwood, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 50
| Not Ranked : 0 score Could you be any less specific please? Regardless, the damage is done. Stock out, take it in, and hope for the best. Sounds like some kind of flash tune, since whoever had the car before you would've had to remove the tune in order to sell the tuning device. I would call a piasani dealer and see if they can check it out/remove the tune before you take it in. It's a long shot, but it may be worth your while. |
Groans: 40
to much boost down low and nothin but hot air up top
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan | |
Groans: 60
Makes me glad I owned my car since 10 miles. I know the person who beats the shit out of it and know where the blame goes if something breaks. | |
| The Following User Says Thank You to dsmluck For This Useful Post: | Bucker (04-30-2011) |
(Thread Starter) | Not Ranked : 0 score I was Told the car was inspected and 100 percent under warranty so me and the dealer will have a huge problem if they don't fix it. I owned my mustang for 2 years and ran numerous bottles through it with almost 100,000 miles and it never broke down 1 time. I'm starten to rethink the ms3 it's been in the shop longer than I've had the car now. First a hydraulic line for clutch blew out, then throw out bearing and now a blown motor even though this is all happening because the previous owner apparently ran the balls outta this car.
![]() | | #19 | ![]() |
Groans: 60
Never go WOT below 3k and spray Meth up top. Yea I will never make a ton of horsepower with it but I just got a new k04 under warranty and can't see myself being able to afford a proper BT build for sometime. | |
![]() | | #20 | ![]() |
Groans: 40
| Not Ranked : 0 score your going to have to battle on this one, tell them that you have done nothing to the car, that you bought it this way and bought it with the warrantee sill in tact, or you wouldn't of purchased the car gl man!
![]() | | #21 | ![]() |
Groans: 60
If so did it have all of the mods on it already? If so you might have a case. | |
| The Following User Says Thank You to dsmluck For This Useful Post: | rigor (04-30-2011) |
![]() | | #22 | ![]() |
Groans: 40
| Not Ranked : 0 score rilly spray meth on stock mtr obviously the turbo is a pos
![]() | | #23 | ![]() |
![]() Join Date: Oct 2009 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,684
| Not Ranked : 0 score Too bad you had it towed to the dealer. Hopefully someone else reading this will learn from this situation: ALWAYS HAVE THE CAR TOWED HOME TO STOCK IT OUT! Paying $100 for the car to be towed to your house and then to the dealer is a hell of a lot cheaper than paying $2500 for a blown motor out-of-pocket.
__________________ ● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ● ● 2010 Mazdaspeed 3 - GONE ● |
| The Following 2 Users Say Thank You to alien_sporez For This Useful Post: | Darksun280 (05-01-2011), Spoolme (05-04-2011) |
![]() | | #24 | ![]() |
Groans: 40
![]() | | #25 | ![]() |
Groans: 60
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes everything already installed when i bought it only thing I had done was tires and window tint.
![]() | | #27 | ![]() |
He probably knew what was about to happen (bad motor), traded it in, and it's now on your hands. I would take the advice of fighting with the dealer you bought the car from since it came that way. Next advice would be never to buy a car modded like that... | |
![]() | | #28 | ![]() |
Groans: 60
![]() | | #29 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score Spray meth everywhere
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Sounds like this car was used and abused prior. Sorry to hear. |
| The Following User Says Thank You to Lex For This Useful Post: | Darksun280 (05-01-2011) |
![]() | | #31 | ![]() |
| Banned ![]() ![]() Join Date: Apr 2011 Location: Lanoka Harbor, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 68
| Not Ranked : 0 score You guys all said I was going to be fucked going to the dealer, and everything was covered. You'll get it covered if you play your cards right. How long have you owned the car, and how many miles have you put on it since? |
![]() | | #32 | ![]() |
![]() Join Date: Sep 2008 Location: CT/NY
Groans: 35
| Not Ranked : 0 score Sooo what happened when it blew??? Well, on my way home from work, going 40mph in 6th, I tried to pass 2 cars up hill . . .
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score Well goodluck with whatever happens. So oil was everywhere you say, so hole in the block? Also stock turbo is fine for the most part. Just depends on few factors. the 07-08 ms3's seem to have more issues with smokey turbos bad seals,pvc. I have a 09, and have 0 issues, I also have only heard of 1 issue with 2010+ regarding stock turbo. What I will say though is our stock turbo is not a very awesome performer when pushed. Stock tune for the ms3 sucks, the k04 makes around 14-15 psi till 5k and then falls hard. A good tune would be 18 psi till 5700, then have it taper slightly to 15 psi @redline. With proper tune, youll be able to squeeze out 99.9% of the hp potential of this k04 while preserving turbo life. Aslo it has not been proven at all about wot below 3k blows motors..just hearsay. But Rigor is correct, even when pushing the turbo above the norm, its hot air. A nice TMIC or FMIC can help this alot, meth is awesome....but if your staying 18 psi and below, it is not needed. WE have no clue what kind of tune is on your car, that leaves alot of questions in the air...how were your afr's..did you have knock...what was your fuel psi..ect ect...bla bla fuckin bla. You have a used ms3 with couple bolt ons and unknown tune and then boom, so who fuckin knows what happened. Did the previous owner do reg. oil changes..or was he a fuckin retard who treated his car like shit....once again..alot of what ifs I do know that a properly tuned ms3 with proper mods, yes stock turbo can run just fine.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
| The Following 2 Users Say Thank You to zx2man For This Useful Post: | alien_sporez (04-30-2011), rigor (04-30-2011) |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have owned the car for a month and a half to two months and put about 4,000 miles on it because I took a trip to the Florida keys the week after i got it. About 1,600 miles there and then the 1,600 for the trip back.
![]() | | #35 | ![]() |
Groans: 60
On a long road trip like that with a new owner on a who knows how beat car I could see it happening. These cars should come with a ignition lockout that will not deactivate until you research these forums for at least a few weeks. This forum has saved many noobs (myself included) from the headaches. Op if they replace your engine don't give up on the car just keep it stock until you learn the ins, outs, and quirks of the platform.. Last edited by dsmluck; 04-30-2011 at 07:46 PM. | |
![]() | | #36 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score it is quite quirky indeed
__________________ |
| The Following User Says Thank You to Monotonous ONE For This Useful Post: | speed_AK (05-03-2011) |
![]() | | #37 | ![]() |
![]() Join Date: May 2009 Location: Tallmadge, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score But but but but.... they said it was covered 100%!!!!! All you're doing now is paying a price for being so gullible. Get that kind of stuff in writing next time. Sorry for your loss and happy rebuild time....or whatever you decide to do.
__________________ ::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 ::: ::: DIZZY TUNED by Boost_creep ::: |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's was in writing it had a sticker on the car that said 100 percent factory warranty on The passenger window thats one main reason I bought it. I found out after I bought it that a bov could void the warranty that's kinda why I'm freaking but it was all on there when I got it. The car would back fire bad sometimes also if that has anything to do with it. Ill keep you guys updated as to what really went wrong when I find out.
![]() | | #39 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score All of the decisions on what will or will not be covered under warranty will left to Mazda people. All the dealer does is communicate with them. If the dealer submits a request, a person from Mazda will visit and make a decision on if parts will be covered or not and labor will almost always be covered by the dealer. I take it it's a small dealer that sells just about anything? I'm assuming because any normal Mazda dealer would not have sold the car with aftermarket parts all over it. So in the end the decision will come down to what Mazda says. What you have said so far isn't looking very good. You said something about you trying to pair a Cobb Ap with the car? Not to mention your sig says "tune". If there is any sort of flash on the ecu, any dealer with a Mazda diagnostics computer will hook it up to the obd2 port and know immediately that the ecu has been flashed. Mazda will not honor warranty on car that's got a flashed ecu unless someone really lies to them at the dealer... At this point you will be left with the dealer to cover the whole thing and if they are small....... well good luck with that. My advice is that if you didn't mod the car to the way it is now, and the dealer sold it to you that way, fight them (get a lawyer). Keep in mind a new mzr motor installed at a variety of shops is going to cost your upwards of $7000.00 Of course there's cheaper options then new...
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
![]() | | #40 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score hopefully your couch is not fucked too hard.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| What should i get to prevent blown engine | MS6Danny | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 09-14-2009 09:57 PM |
| another blown engine | b-ron | MazdaSpeed 6 - Engine, Transmission & Driveline | 28 | 12-16-2008 08:29 AM |
