Closed Thread
 Old 01-17-2009, 05:12 PM   #1
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
Default Blown motor?
So today my boost gauge peaked it's max.. So I was babying it after I seen that. So, coming up hill I got to 15psi and clutch went out car started ticking got no power so I threw it in netrual asap.
Good thing is no rods went threw the block no oil no nothing. Sounds like it's a bent rod. =( stupid me. Stupid me.
I was set at 18psi last night but with this mbc the it differs on the temp outside. And I forgot about that =(
So yeah I'm out a car and thing sucks it was my DD.
Buildabong is offline
 Old 01-17-2009, 05:18 PM   #2
spheed3's Avatar
Posts: 487   (View Stats)
spheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond repute
Are you sure a hose or something didn't come off because of all that boost? Sucks that it's your DD...
Black Mica 08.5 GT
I'm parting out. Buy my stuff: http://www.mazdaspeedforum.org/forum/foru...ing-out-59908/
spheed3 is offline
 Old 01-17-2009, 05:19 PM   #3
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
how did your boost gauge hit its max but you didn't get over 15psi? Should i just assume you were going up a hill in the wrong gear and over boosted the car? If so you earned that blown motor.
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 01-17-2009, 05:23 PM   #4
Buildabong's Avatar
Groans: 213
I fixed the boost last night.
Gear was 2nd not even flooring it man. Barley on the throttle. Sucks balls man
 Old 01-17-2009, 05:27 PM   #5
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
What is your boost gauge peak 20 25 30psi?
What do you mean clutch went out?
MBC's love to PTFB (part throttle full boost) thats why they suck.
If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap.
CraigHJr is offline
 Old 01-17-2009, 05:28 PM   #6
Fux Wit It
Darksun280's Avatar
Groans: 175
Man Bong you know what real talk, you were destined to blow. Thats even IF your motors really blown. Pull the oil pan and check it out.
 Old 01-17-2009, 05:37 PM   #7
Buildabong's Avatar
Groans: 213
we are going to do that later on
My gauge is 20psi auto meter and it hit the vac side. =/
No oil leaked. We are hoping it's just a rod. I hope so lol and I wasn't even racing today. I was just cruising!! Sucks so bad lol
 Old 01-17-2009, 06:17 PM   #8
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
You are worried because it went all the way down in vacuum? Not quite sure I follow all the things you are saying. I am honestly not being mean with what I am about to say. Sit down and put together a post of what happened in an organized way. I really couldn't follow with the way you typed it and then responded a few posts later.
-JEWBERT
jhershorin is offline
 Old 01-17-2009, 06:23 PM   #9
CraigHJr's Avatar
I think he ment it went over 20psi all the way around to touch the vac scale...Thats my interpertation of off the scale.
CraigHJr is offline
 Old 01-17-2009, 06:24 PM   #10
dcs191919's Avatar
Posts: 73   (View Stats)
dcs191919 is a jewel in the roughdcs191919 is a jewel in the roughdcs191919 is a jewel in the rough
I think what he means is the boost needle went all the way around to vac side,meaning he hit like 25-30 psi.
dcs191919 is offline
 Old 01-17-2009, 06:28 PM   #11
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Be lucky the rod didn't shoot out the block. If it just bent grab the cp rod/piston combo from streetunit and you'll be set for that 30 psi lol.
smakdown61 is offline
 Old 01-17-2009, 06:47 PM   #12
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
so where was this magical fuel cut savior that every1 is bitching about being removed?
Laloosh is offline
 Old 01-17-2009, 06:50 PM   #13
Fux Wit It
Darksun280's Avatar
Groans: 175
lol it couldn't interfere with destiny. Nah really though when i hit 30 psi back in the day it was like 18 degrees out and i didn't cut fucking car tried to ride it out.
 Old 01-17-2009, 06:53 PM   #14
Laloosh's Avatar
it was because he bought my manifold....that i cursed with bitterness and hate. Autoxrace bought my fmic and hes fucked, buildabong bought my mani and mount, and hes fucked. The curse of what should have happened to my car is spreading liek a virus....lol
Laloosh is offline
 Old 01-17-2009, 07:02 PM   #15
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
This is one of the reasons why I went with an EBC over a MBC. If i over boost by .5 psi an alarm goes off and it compensates... 1 psi and it fully opens the WG.
OP, Sorry to hear about your engine man. I hope it's just a rod and that nothing more major happened.
phantom3 is offline
 Old 01-17-2009, 07:24 PM   #16
Buildabong's Avatar
Groans: 213
lol damn u laloosh! Wooo msf banned son! Hahaha "personal attacks" haha what fags
Yeah my gauge went passed boost and hit the little needle for the vac lol I look down and go WTF ah something bass going to happen lol
How much is cpe stuff?
 Old 01-17-2009, 07:33 PM   #17
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
damn that sucks big balls...I think you're the only one so far who run meth and got their engine blown...and i was thinking of getting a mbc...would it be safe if i just run mbc without any bcd or map clamp so i know where my limit is at? maybe just set it to 16-17psi?...shit guess no one is cured cuz even stockers getting their shit blown up...maybe i'll just stick with what i got and just put more stickers...lol.
Decepticon is offline
 Old 01-17-2009, 07:47 PM   #18
Fux Wit It
Darksun280's Avatar
Groans: 175
He does not count for running meth and blowing up. He just hooked it up and was on a crash course for awhile. Don't mix him in with us others. Any way a D03 nozzle aint gonna stop 30 psi+ from destroying your motor.
 Old 01-17-2009, 07:47 PM   #19
Buildabong's Avatar
Groans: 213
Oh I ment m3f banned lmfao my bad
Yeah and it does suck. And I have my meth at like 11psi lol
 Old 01-17-2009, 08:29 PM   #20
Decepticon's Avatar
guess no one is safe..what year and how many miles?..i tried comparing all of the listed ms3s with blown engines even from other forums and i can't seem to find any trend as far as aftermarket set up goes. If you just installed meth and doesn't count, then no car that run meth has blown yet nor with EBCs...but even stocks have blown...could just be certain cars just like with the engine mount issues and the fuel pump issues...or could just be driving methods who the hell knows...i guess the best and first thing to buy when modding a stock ms3 is rods and pistons...lol.
 Old 01-17-2009, 08:30 PM   #21
Laloosh's Avatar
all those mods on the stock fuel pump....what did you think was gonna happen
Laloosh is offline
 Old 01-17-2009, 08:31 PM   #22
D03 is good for 20 psi and thats it. Theres more to it then just meth, colder plugs while being changed FREQUENTLY and smart driving. When you start modding these cars, you just cant beat on them and neglect them.
Haltech is offline
Darksun280 (01-17-2009)
 Old 01-17-2009, 08:33 PM   #23
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
fak that reminds me i need some new colder plugs
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 01-17-2009, 08:41 PM   #24
Fux Wit It
Darksun280's Avatar
Groans: 175
+ 1 billion
 Old 01-17-2009, 08:53 PM   #25
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
i'm on my buddies slow internetcomputer, ive talked with Tim(my bro) on text. just want to say soory for his perdicament. I think this is proof that a standback(or good tune) and dash hawk are a must so you dont get too lean modding at part throttle!
gsrtype1 is offline
The Following User Says Thank You to gsrtype1 For This Useful Post:
Buildabong (01-17-2009)
 Old 01-17-2009, 09:01 PM   #26
Decepticon's Avatar
There have been reports of cars with upgraded fuel pumps, and tune (ap or sb) with their engine blown...i would have to agree with Haltech on this...
guess this goes for any cars.
 Old 01-17-2009, 10:48 PM   #27
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
wait a minute,your still on the stock fp?That should have been done way before anything else.
Grim is offline
 Old 01-17-2009, 11:09 PM   #28
bf360's Avatar
Posts: 2,069   (View Stats)
bf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the world
Groaned at 42 Times in 35 Posts
can you explain again how you blew? wtf does clutch went out and going up hil at 15 psi mean?
stock fp?
bf360 is offline
 Old 01-17-2009, 11:58 PM   #29
Buildabong's Avatar
Groans: 213
it felt funny on my clutch it started like vibrating.. and u can hear something in the engine clunking hardcore.
and i was going up hill part throttle and hit 15psi and it went down hill from there. =(
 Old 01-18-2009, 12:07 AM   #30
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
sucks for you
phillyb is offline
 Old 01-18-2009, 12:35 AM   #31
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
Palerider's went going up a hill like that didn't it? I wonder if he noticed anything similar?
In reality I love lenny
kingpin748 is offline
 Old 01-18-2009, 07:21 AM   #32
Fux Wit It
Darksun280's Avatar
Groans: 175
wait bong you don't have the pump in yet? If the answers yes i'm sure alot of us are done with this thread.
 Old 01-18-2009, 07:26 AM   #33
gsrtype1's Avatar
Groans: 102
Actually he does have the upgraded fuel pump internals and the D05 nozle.
gsrtype1 is offline
 Old 01-18-2009, 07:35 AM   #34
gsrtype1's Avatar
Groans: 102
Sounds like he had a super lean spot at part throttle under extra load(going up hill) and no way to know it or tune it out like he could have with the dashawk and standback. But if he over boosted to 30+psi rite aronnd that time.. ?? could have been that. who knows...
gsrtype1 is offline
 Old 01-18-2009, 07:52 AM   #35
Fux Wit It
Darksun280's Avatar
Groans: 175
I still have faith you'll make it.
 Old 01-18-2009, 08:02 AM   #36
gsrtype1's Avatar
Groans: 102
WTf?..lol Hey could happen to anyone but I have my tune down 12afrs all the way.
gsrtype1 is offline
 Old 01-18-2009, 08:29 AM   #37
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
so then he does have CDFP internals? wtf guys...this thread is so difficult to read and follow.
BONE STOCK.
94jedi is offline
 Old 01-18-2009, 10:02 AM   #38
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
hence why when going up a hill its good to stay out of boost. your engine probably started vibrating from all the load you were putting on it with boost and going up hill, and then to not have a upgraded cdfp....sorry but you were asking for this if something bad did happen.
bova is offline
 Old 01-18-2009, 10:04 AM   #39
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
after getting the cdfp upgrade...its something i wished i had done long before. theres even guys with just intake/AP getting fuel pressure dropping in these colder temps
aaronc7 is offline
 Old 01-18-2009, 10:19 AM   #40
Buildabong's Avatar
Groans: 213
yeah sucks i think fuel pump should be the first upgrade people should get cp-e or internals
Closed Thread
ANOTHER VICTIM OF A BLOWN MOTOR ev0nstispanka MazdaSpeed 3 - Engine, Transmission & Driveline 107 01-06-2009 11:52 PM
another blown engine b-ron MazdaSpeed 6 - Engine, Transmission & Driveline 28 12-16-2008 08:29 AM
Motor Blown, Rod through block cageyvet MazdaSpeed 3 - Engine, Transmission & Driveline 35 12-12-2008 03:31 PM
Blown Seal? Rican219 MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-19-2008 09:52 AM
Page generated in 0.57289 seconds with 39 queries
