![]() Join Date: Feb 2010
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I got my BNR Stage 2 tuned last week. It was a warm day, and on a mustang dyno, but I can't help wishing I saw better numbers. Max torque was 280, at 3750rpm. Max HP was 230 at 5500rpm or so. Only other drivetrain mod I have is a Cobb SRI. Most dynos I've seen of MS3's whether modded or not have had the max torque and HP numbers having a difference of not more than 20 or 30. I noticed the torque curve falling quite fast, so the HP doesn't climb very much with rising RPM. The shop said this was because I am still on the stock exhaust, which is very restrictive. However, living in CA, I don't really want to mess with the exhaust system... But I wonder if there's anything else in my car that is preventing the torque curve from being more flat? Thanks for any insight. |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score our exhaust is not restrictive, the downpipe is however
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score and stock fuel pump I'm assuming? what psi did you get tuned to? |
| The Following User Says Thank You to manelscout4life For This Useful Post: | SLOWHATCH (10-03-2011) |
| Not Ranked : 0 score Do you have any datalogs. Probably still a lot more power to squeeze out. There aren't too many shops that know how to tune speeds. Just about anybody that knows how to tune these cars is right here on this forum. Sent from my Desire HD using Tapatalk
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 539
| Not Ranked : 0 score PERM Tuning /thread
__________________ 2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03 FREEKTUNE |
![]() Join Date: Apr 2011 Location: Decatur, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score That's super low imo. Above post has the rights about it, get some internals and a downpipe and make 320HP+ and 400TQs!
__________________ 2007-Mazdaspeed 6 BNRSIII~all supportings Zoom Zoom Boom part out. |
| Not Ranked : 0 score The STG 2 is not a big flow turbo but we need more info including an important WOT log to see what's going on.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (10-11-2011) |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
| Not Ranked : 0 score yes, fuel pump internals for sure, then downpipe and a proper tune again. It will wake the eff up. But leave it be until you get a fuel pump internal setup or you will most likely boom it up.
__________________ 06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver 91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's |
(Thread Starter) | Not Ranked : 0 score Thanks for the replies. For some reason I'm not getting the notifications so I didn't think anyone was replying to this. Yes, I am on stock fuel pump. It was tuned to 20psi tapering to 16. I'm getting some boost cut and/or fuel cut also, which the tuner is trying to fix by reducing the trims in the rpms where it's happening. He said I don't need a fuel pump... what he said was really needed was a DP. But as I said, being in CA, I'm not sure I want to do anything to the exhaust. But maybe it's not as bad as I thought and I should just go through with a DP... I need to figure out how to post logs. What parameters do I need to log? Boost pressure, RPM, AFR, ... ? |
![]() Join Date: Jan 2011 Location: Scranton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,797
Groans: 62
| Not Ranked : 0 score You need a new tuner
__________________ Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL |
| Not Ranked : 0 score I was going to be nicer about it but arrive at the same conclusion. For your sake, make sure you are logging fuel pressure constantly while on the dyno. Or any other hard, full redline pulls. If your fuel pressure starts to fall off by more than a little bit(IE its at 1600, and then it starts to fall off quickly to 1200 or even less), let off the gas and turn down the boost at the RPM it starts to fall off. Then get and install a set of HPFP internals, break them in and then retune. If your pressure is not falling off, please take these posts as attempts to save you thousands of dollars in a new engine.
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score fuel pump or internals at least. if he says you dont need it he shouldnt touch your car. DP will make it worse without fuel pump.
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
| The Following User Says Thank You to crazyp For This Useful Post: | Don06speed6 (11-15-2011) |
| Banned ![]() ![]() Join Date: Apr 2011 Location: Lanoka Harbor, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 68
| Not Ranked : 0 score Email Finkle. Hell help you out with tuning. You definitely need fuel pump internals ASAP You don't need a downpipe to make good power. I made 267whp and 269tq with an intake, TIP, and catback. Personally, I wouldn't trust that guy tuning your car. Let Finkle help you out, and then go back to that dyno. I bet you put down 290whp |
![]() Join Date: Oct 2011 Location: Diamond Bar CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score u need everything, not just an upgraded turbo
__________________ -2014 Evo X GSR -2007 MAZDASPEED 6 (SOLD) BNR S3// ALL-SUPPORTING MODS |
(Thread Starter) | Not Ranked : 0 score thanks for the referral. i'm not acquainted with Finkle... is this "rfinkle2"? i would get "everything" if i could afford it! I went to the tuner that I did because he was the only "Cobb authorized tuner" anywhere near me. I figured Cobb wouldn't stand behind them if they didn't know what he was doing.... but what do i know. |
![]() Join Date: Nov 2009 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
Groaned at 6 Times in 4 Posts
__________________ Mazdaspeed3 E85 ~ Sold 333/383 Mazdaspeed6 #10018 TiGrey Forged Internals, PTE5858. 2015' Freektuned on 93Octane 322/337 (stock top mount and BPV) 2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor) 2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling) Mazda CX-5 AWD Daily | |
![]() Join Date: Apr 2010 Location: Boston, Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,996
Groaned at 26 Times in 20 Posts
| Not Ranked : 0 score You guys make me laugh with the fuel pump comments left and right, "get internals and you'll be ok." I for one am on the STOCK PUMP and I hold 1700+ all fucking day. He very well may not need one and needs to look elsewhere for shit, as in a new tuner for starters. And I would get a DP pronto to take advantage of a Stg. 2 turbo.
__________________ '06 F350 Lariat PSD - 458whp/818wtq ![]() '07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm. '06 F150 SCrew 4x4 5.4l - sold '03 Marauder - Vortech on only 8psi 485whp/435wtq - sold '95 Mustang GT - sold '95 SHO MTX - sold |
![]() Join Date: Mar 2011 Location: Saskatoon, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 169
besides eventually you will need the internals, whether joe or bob says his fp holds on stock pump. the cost/risk isnt worth it to keep a stock pump
__________________ '12 Evo X | |
![]() | | #19 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score im still on stock catback and just shy of 400 right now (according to vdyno so probably still like 380ish on a real dyno) so stock catback is fine |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Why fix/replace shit when it's not broke? And it's not like I'm not monitoring it, obvifuckingously if I see it go south, then I'll replace it. And if you want to criticize, how about the OP....who puts in a stage 2 turbo and rocks stock everything and wonders why he's making only 280tq?
![]() | | #21 | ![]() |
Because my stock internal drop to low 800 then back to 1700 in a split second. I caught it by looking at the log. I was looking at the AP monitor the whole time I floored it. The fact that he said he have fuel cut and what not already stated the fact that he needs a stronger fuel pump.
![]() | | #22 | ![]() |
__________________ '06 F350 Lariat PSD - 458whp/818wtq ![]() '07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm. '06 F150 SCrew 4x4 5.4l - sold '03 Marauder - Vortech on only 8psi 485whp/435wtq - sold '95 Mustang GT - sold '95 SHO MTX - sold | |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hi All, I know this is a super old thread, but just thought I'd provide an update in case anyone is interested. So, I upgraded my fuel pump as recommended, and got a Cobb downpipe. This fixed some problems that I had after the first tune (fuel cut, surging), and I went back to get it tuned again. While the power was smoother now, you can imagine my frustration when my car still didn't make any more power than before. The tuner (Fine Line Imports in Santa Rosa) didn't offer much explanation, and only offered that I might want to install a catch can due to engine blow-by that he observed. Fast forward to today. I had my second kid, and my mazdaspeed3 has taken a backseat ever since then. I went back to the stock map, and have been just DD'ing it and enjoying it for what it is. But the BIG NEWS is that my BNR turbo broke. Apparently the bearings for the turbine went bad. So now either going to have BNR repair or replace it. The question I have is: if I'm going to be fixing the turbo anyway, has the tuning scene for speed3's in the SF bay area improved much over the years? The reason I drove almost 2 hrs to Santa Rosa was because there weren't any Cobb approved tuners near me at the time. After the disappointing experience with FLI last time, I'm hoping I can find another one (preferably closer). Does anyone have any recommendations?? It would be very much appreciated. Thanks all for reading and hoping I can breathe some new life into my Speed3. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score my comments were directed to op, just in response to what you posted not trying to say your wrong for having stock fp, but if op has all this shiz and no dp and no fp, his next step should be the fp, or else its just a matter of time. JMO and i wont rag on op for that shitty power, he didnt tune it. op you should pm finkle or dj
| The Following User Says Thank You to HARPER306 For This Useful Post: | jman46 (11-16-2011) |
![]() | | #25 | ![]() |
![]() Join Date: Apr 2016 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score e-Tunes have come a long way, my friend. Most e-Tuners can tune WAY more modded cars than yours in their sleep. I wouldn't even bother getting dyno tuned unless you are pushing serious power where tiny little changes can net big power differences. Any e-Tune by any one of the reputable tuners on this forum will probably yield better results at far lower cost than dyno tuning from a random local. |
![]() | | #26 | ![]() |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
E-tune is sufficient for most people at the convenience of your email. No need to drive 2 hours to a shop that PROBABLY don't know much about speeds.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score E-tune from one of our respected tuners after replacing the BNR 2. They will review your data logs and revise until it is spot on for your mods. The stock dp and mid pipe are where the restrictions are, not so much the CBE until you get above a true 300 whp. If your new downpipe has a high flow cat and you've either gone to a straight through race pipe or a high flow cat midpipe, then you are ready for that tune when you get the new turbo. Stand alone local tuners rarely know this platform and don't know how to tune for your mods. A good e-tuner is the perfect solution and will be your best friend.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks all for chiming in. A few questions: 1. Can someone point to a list of e-tuners? I went to the "E-Tuners / Custom Hardparts" subform (E-Tuners / Custom Hardparts - Mazdaspeed Forums) and only saw one forum for Stratified Automotive Controls. I noticed that Freektune is a forum sponsors, so that's another one. Should I just choose between these two? I found a few more on Google, but didn't see them in the forums... 2. I was seeing a bit of smoke at WOT in the lower gears before my turbo died. BNR had mentioned that a possible cause of failure for the turbo is blow-by. Assuming my compression is OK, would a catch can help, or is there anything else I should do? 3. I will be shipping my broken turbo back to BNR to have them repair it. Do you guys think that's a good idea, or should I just get a new one from them? I don't suppose any bay area Nator folks would be curious to take a peek at the old one before I send it off to BNR? |
![]() | | #29 | ![]() |
Groans: 211
2. Do a compression and leak down test and post the numbers. 3. Send it off for a rebuild or get an S3/S4 and downpipe. And an aftermarket TMIC as stock sucks and heatsoaks easily. Then you wont be disappointed in the HP numbers. But don't expect a wildly huge gain on our shitty California 91 octane. Maybe consider getting a second map from Freektune for E85. Most run around a 30% mix and gain around 50HP over pump gas only.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| Upgrading HU, should I upgrade amp? | sallyspeed3 | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 07-30-2011 06:41 PM |
| upgrading exhaust | Vinnie | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 02-18-2010 10:47 AM |
