 Old 09-06-2017, 11:43 AM   #1
1324Kyle's Avatar
Posts: 58   (View Stats)
1324Kyle is on a distinguished road
Groaned at 8 Times in 5 Posts
Default Boost Leak
While accelerating recently, I heard some noise and quickly realized I have a boost leak, I hold about 7lbs of boost so I assume it has to be either a hole in a tube or something else
Anyways when the car is warm it idles with a oil pressure of about 11psi. From what I read, this is ridiculously low so that's why I'm curious if you guys think I need a new engine or do should do something to look for a leak (if there is one) maybe pump smoke in there or something.
I'd appreciate any insight on the situation,
Thanks
-Kyle
Update: Now believe it's the BOV
1324Kyle is offline   Reply With Quote
 Old 09-12-2017, 06:52 PM   #2
1324Kyle's Avatar
Didn't mean to bump, initially put my "Update" above in here, then decided to move it up hoping more people may see it.
Thanks
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 12:29 PM
Not hitting boost targets, not boost leak ADHDAdditiv MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-18-2014 02:18 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Page generated in 0.22931 seconds with 20 queries
