 Old 02-11-2014, 12:22 PM   #1
Zmcg1995's Avatar
Posts: 258   (View Stats)
Zmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond repute
Default Boost leak test not holding pressure
So im doing a boost leak test. Hooked my tester right into the turbo and once i put air into the system, it holds up to 9psi and than it wont hold anymore... Once i stop putting air in it the pressure goes down a little over 1 psi per second maybe 1.5 psi per second. Shouldnt i be able to hold around 15-20 psi in the system? And should it stay in the system or will it go down once i stop putting air in?
Zmcg1995 is offline   Reply With Quote
 Old 02-11-2014, 12:25 PM   #2
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Sounds like you've got a leak.
But yes, air will slowly bleed off. But this sounds like its happening a little quickly
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Zmcg1995 (02-11-2014)
 Old 02-11-2014, 12:28 PM   #3
Zmcg1995's Avatar
Yeah but i cant really hear any leaks and i sprayed alot of tubes and cant seem to find any leak which i dont understand
 Old 02-11-2014, 12:46 PM   #4
smoogs12's Avatar
Groans: 423
You probably won't hit 20 psi. You dont need to.
Generally if its bleeds off at 1psi/sec or less then you are probably good to go. If you are more around 1.5-2 you might have a leak.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
p057 (02-12-2014)
 Old 02-11-2014, 12:47 PM   #5
Zmcg1995's Avatar
And also im kinda a noob so im not really sure what exactly i should be spraying. I mean im spraying the turbo inlet and some others but if someone could help me out on what i could spray that would be a big help
 Old 02-11-2014, 01:22 PM   #6
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
The BPV, boost tubes around the TMIC, etc...
 Old 02-11-2014, 01:30 PM   #7
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Do you have an AP? Take a WOT log.
Any significant boost leak will be reflected in your boost levels, AFRs, and WGDC behavior.
 Old 02-11-2014, 02:57 PM   #8
Zmcg1995's Avatar
There was a crack in the TIP. Couldnt hear it unless you had lots of air pressure. Ordered a corksport TIP couple days ago anyway so hopefully that solves it.
The Following 2 Users Say Thank You to Zmcg1995 For This Useful Post:
jack_hammer (02-12-2014), p057 (02-12-2014)
 Old 02-11-2014, 06:23 PM   #9
Zmcg1995's Avatar
Also when doing a boost leak test do you just wanna check the things after the turbo for leaks or before aswell?
 Old 02-11-2014, 11:44 PM   #10
Groans: 665
Enough being nice to the brownie.
Stop asking stupid shit.
Search & Read.
Get an Accessport.
Donate.
/thread
p057 (02-12-2014)
 Old 02-12-2014, 12:00 AM   #11
sidekick's Avatar
Posts: 3,093   (View Stats)
You want to check everything after the boost leak tester. Anything before the turbo = vacuum leak, anything after = boost leak, when in boost. The valve cover vent/PCV system have given me issues when doing boost leak tests, so try to rule that out when doing a boost leak test.
Agent_Orange (02-12-2014), lilred (02-12-2014)
 Old 02-12-2014, 07:46 AM   #12
Groans: 665
Yeah, the VC vent should really be plugged while leak testing.
lilred (02-12-2014), sidekick (02-12-2014)
 Old 02-12-2014, 08:06 AM   #13
lilred's Avatar
Posts: 5,792   (View Stats)
Think I mentioned it in the other thread... lol
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 02-12-2014, 08:37 AM   #14
sidekick's Avatar
The downside is then the pressure just escapes elsewhere. I've had oil spray out in a fine mist from the pressure sensor on top of the VC.
The Following 3 Users Say Thank You to sidekick For This Useful Post:
86AmishMs3 (02-15-2014), Agent_Orange (02-12-2014), jdmage_mx5 (02-12-2014)
 Old 02-12-2014, 09:44 AM   #15
smoogs12's Avatar
Groans: 423
I dont know how I would feel about all that positive pressure inside my CC.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 02-12-2014, 10:38 AM   #16
jm211's Avatar
Posts: 943   (View Stats)
Use common sense where things could leak. On a stock system there honestly isnt many and if you use common sense and a bit of due diligence leaks shouldnt be an issue.
Common spots are hoses, couplings and the clamps that hold them in place.
 Old 02-12-2014, 11:06 AM   #17
sidekick's Avatar
Yeah, it could cause issues with seals. At a minimum, the VC vent hose should be removed/plugged.
Part of my issue was the engine was completely cold, so the rings were not really sealed most likely.
 Old 02-12-2014, 11:18 AM   #18
smoogs12's Avatar
Groans: 423
But if you plug it then the pressure cant escape.
I would think you would want to leave it open to reduce the pressure and the stresses on seals.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 02-12-2014, 11:43 AM   #19
sidekick's Avatar
Yeah, I'm not really sure on that. It makes sense to plug it to hold the pressure, so you can see if pressure is escaping at the normal 1PSI per second, but it also could damage seals if you do that. It could go either way, but I'm not sure what the "proper" procedure is. Ultimately, if WGDC, boost, and fuel trims look normal, it's not really necessary to do a boost leak test anyways.
 Old 02-12-2014, 11:50 AM   #20
pzr2874's Avatar
Groans: 146
as long as you don't go over 20psi on a BLT... you should be fine.
my experience
The Following User Says Thank You to pzr2874 For This Useful Post:
 Old 02-12-2014, 12:48 PM   #21
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Next time light a cigarette blow ass tons of smoke into the tip and then pressure test, the smoke will come
Out the cracks
 Old 02-12-2014, 01:27 PM   #22
jm211's Avatar
Gives me a reason to smoke, for the health of my car!
 Old 02-12-2014, 01:37 PM   #23
pzr2874's Avatar
Groans: 146
Or use a fog machine. Some shops use a smoke test as opposed to the soapy water... not that it makes a difference though.
 Old 02-12-2014, 01:40 PM   #24
Daily Driver
Nitr0EngiE's Avatar
Sm oke machine usually charge 40 for a smoke test, cigarettes can be had for free
pzr2874 (02-12-2014)
 Old 02-12-2014, 08:35 PM   #25
Groans: 665
my experience
Right, for a good BLT you want between 15-20 psi, and extra mayo.
lilred (02-13-2014), pzr2874 (02-16-2014)
 Old 02-15-2014, 10:05 PM   #26
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I generally do about 5psi over what I plan on running. So 30psi. Let the valve cover leak by the air (you will get a little blowby which is normal) and regulate your air so you maintain pressure, then search for leaks.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Leak / Pressure Test Fail SurrealMS6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 01-18-2013 08:08 PM
Boost leak test Laloosh Mazdaspeed3/6 General Discussion 17 07-06-2008 08:48 AM
Page generated in 0.43579 seconds with 28 queries
