 Old 01-09-2013, 03:44 PM   #1
soaringeagle129's Avatar
Posts: 227   (View Stats)
soaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond reputesoaringeagle129 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Default $$$ to burn. Suggestions
Whats up fellas. Been some time since I've been on the forums. School and work have been kicking my ass.
To the point, I sold my toy miata and have some cash to burn in the speed 3. Thought I would get some suggestions on what would be some good next mods. Mods list is already decent (bellow). I need to replace my clutch and was thinking about doing a lighter flywheel. Custom tune is going to happen when I go back to VA. Considering doing sway bars as well. Thoughts? Not looking to go BT.
Good to be back on the forums. Looking forward to getting myself updated on shit.
CP-e CAI, Turbosmart BPV, CNT Catted TBE, Jbarone SSP, Jbarone Heaver Shifter knob, Denso sparks, Drilled/Slotted brakes, Motegi 18x8 rims, Hawk Street pads, Sure Street RMM, Turbo XS FMIC, Cobb AP, Cobb TIP, Megan racing CO, Autotech FPI.
soaringeagle129 is offline   Reply With Quote
 Old 01-09-2013, 03:46 PM   #2
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Sway bars would be nice. I just installed a RSB the other day makes a huge difference. I would also grab JBR TIGs/Coolant Bypass
2012 MS3
Stratified 91
 Old 01-09-2013, 03:50 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Ditch the Megan CO's and get some of quality.
RSB also.
And ditch the slotted/drilled rotors.
Neverlift (01-09-2013)
 Old 01-09-2013, 03:52 PM   #4
RSB also.
i hear ya on the Megans. They have turned to shit...
 Old 01-09-2013, 03:55 PM   #5
helmetface's Avatar
Groans: 219
If you want to stay on a budget, I highly suggest Bilstein Sports with a quality Spring. If you're looking for CO's the sky is the limit obviously but you get what you pay for. Make sure they are SS and if you're looking for super low's don't expect comfort.
Just my 2c
Fail_6 (01-10-2013)
 Old 01-09-2013, 04:01 PM   #6
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
Side mounts.
Pseud0logik is offline   Reply With Quote
 Old 01-09-2013, 04:10 PM   #7
Just my 2c
Thanks man I'll look into it. Any thought on a lighter flywheel?
 Old 01-09-2013, 04:14 PM   #8
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Don't mess with the flywheel and clutch, they are awesome from factory.
Add a meth kit on your shopping list. Since you don't want to go BT at least you can get more power from what you already have.
Good luck!
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-09-2013, 04:15 PM   #9
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Well if you are getting a new clutch, you can get a 6 puck clutch from ACT that comes with 2 types of lighter flywheels.
Sent via oil leak.
Pickles Tune in progress
 Old 01-09-2013, 04:20 PM   #10
helmetface's Avatar
Groans: 219
I agree with @mituc; the stock setup is legit and plenty of people have made far more power than will ever be had on the K04.
That is, if yours is in need of replacing, Stock+Fidenza Flywheel is a great option.
But I wouldn't be concerned with it unless it's needed.
Handling: New Struts/Springs or CO's and RSB(do endlinks too if they've got 40k+)
Power: You can buy a used meth kit for around $300 and or get a tune for e85. That will give the K04 a lot more to work with.
Fail_6 (01-10-2013)
 Old 01-09-2013, 04:20 PM   #11
Good luck!
Hadn't even thought of meth. Good point though. Any specific kits you would recommend?
 Old 01-09-2013, 04:49 PM   #12
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
hows about an occ and bsd with a tray.
if you dont get smog checked i think catless is fastest.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 01-09-2013, 04:53 PM   #13
helmetface's Avatar
Groans: 219
DO and Snow are quality for cheaps.
Meh on BSD, OCC a must though.
Last edited by helmetface; 01-09-2013 at 04:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-09-2013, 05:03 PM   #14
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I was thinking like a few other people OCC, meth, other engine mounts.
 Old 01-09-2013, 05:31 PM   #15
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
give the money to me, i'll burn it for you.
The Following 2 Users Say Thank You to Manny For This Useful Post:
Dmurray06 (01-09-2013), Fail_6 (01-10-2013)
 Old 01-09-2013, 05:44 PM   #16
Hookers and blow.
Dmurray06 (01-09-2013), Fail_6 (01-10-2013), jdmage_mx5 (01-09-2013), lilred (01-09-2013), mxlplx71 (01-09-2013)
 Old 01-10-2013, 09:32 PM   #17
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
I was really surprised by the ride quality on the KSports. They are much better than the typical $1k coilover setup. Sway bar is a good idea. Agreed on the OCC. TIGs & SafeSeals too maybe?
 Old 01-10-2013, 10:51 PM   #18
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
sway bars + strut tower bar. add some bling to the bay
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 01-10-2013, 11:58 PM   #19
Stretcher's Avatar
Posts: 46   (View Stats)
Stretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of lightStretcher is a glorious beacon of light
Why not gold plate the valve cover?
Stretcher is offline   Reply With Quote
AP Screen burn-in thanox2 Cobb Tuning 11 08-02-2011 03:34 PM
How much oil do you normally burn? TegRacer324 MazdaSpeed 3 - Engine, Transmission & Driveline 46 09-30-2009 10:31 AM
Page generated in 0.41929 seconds with 32 queries
