 Old 12-30-2019, 06:34 AM   #1
Gary1001's Avatar
Posts: 12   (View Stats)
Gary1001 is an unknown quantity at this point
Default Burnt Plugs?
All the plugs have a caramel ring at the base of the porcelain. is this normal?
Pulled them at 15k miles to do a compression test (which was 170 across all cylinders). NKG 3787 gaped to .28.
The only mod I have is a stage 1 98 tune (OTS Cobb).
Stock setup apart from an AP. Planning 3inch intake, internals, BNRS1 (got it cheap), CPE tmic, test pipe and E30 tune along with some handling and stopping goodies.
Gary1001 is offline   Reply With Quote
 Old 01-05-2020, 02:21 PM   #2
cardoc4u's Avatar
Posts: 46   (View Stats)
cardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud of
It is not uncommon to see that, and does not mean the plug is "cooked". I recommend setting the gap to .026" .
CHEERS!
2012speedy3: cobb sri,tip, accessport, rmm, aem wmi, tbe(with meow),fuel pump innards,fmi
self-tuned @ 309whp/326tq
13.522 @105 mph
cardoc4u is offline   Reply With Quote
The Following User Says Thank You to cardoc4u For This Useful Post:
Gary1001 (01-05-2020)
Burnt ECM JDL360 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 05-14-2018 07:52 PM
another burnt valve thebestdj07 Mazdaspeed3/6 General Discussion 11 10-19-2014 05:56 PM
Burnt Clutch? jeffreyj MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-19-2012 08:44 PM
1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 12-13-2008 04:17 PM
Page generated in 0.22611 seconds with 22 queries
