(Thread Starter) | Not Ranked : 0 score So has anyone picked up a cam tool that fits snugly and doesnt allow the cam to turn? Im to the point of wanting to make my own. I also am not interested in an aluminum tool.
Edit: sorry didnt see that you wanted to stay away from alum Sent from freeks kitchen
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | 06Speed6 (12-19-2012) |
(Thread Starter) | Not Ranked : 0 score Yeah I am wanting a steel tool. I think edge has a tool and I think the oem tool is also steel but im tired of spending money on crap tools that allow play. Anyone have any experience with those?
| The Following User Says Thank You to 06Speed6 For This Useful Post: | atvfreek (12-19-2012) |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score I had a thread about these a couple weeks ago. I have my kit and it looks damn good. I should have my package from onlinemazdaparts.com tomorrow, and the chain will go on when I get back from vacation after Christmas. I'll let you know how it does. The kit I have has shim packs in it so play should not be an issue. Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
| The Following User Says Thank You to chuckms6 For This Useful Post: | 06Speed6 (12-19-2012) |
| Not Ranked : 0 score OEM? the OEM one i have used was legit and pretty much needed to be tapped in to the cams because it fit so well lol
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Just shim the fucker. I understand wanting it to be rite, believe me. Have you mic'd them to see if they're all the same? Maybe it's your head that's out.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score @06Speed6; want me to mic the OEM tool for you in the morning? I can tell you it's very snug. Like superskaterxes said you have to sometimes give it a little tap to get it in place. |
| The Following 2 Users Say Thank You to timjs For This Useful Post: | 06Speed6 (12-19-2012), Easter Bunny (10-20-2014) |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score Here is my oem one and i have never had any play with all the motor i have built and used this with!! Very snug just like skater stated..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
| The Following 5 Users Say Thank You to qtrmile beast For This Useful Post: | 06Speed6 (12-19-2012), Easter Bunny (10-20-2014), roguemazda (04-24-2016), superskaterxes (12-20-2012), Tomas (12-21-2012) |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score I have two from SURE...or street unit...whoever sells them, and neither one had any fitment issues, both fit snug. I wonder if there's an issue with your cams if none have fit right so far... Sent from outer space...
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
| The Following User Says Thank You to tbot For This Useful Post: | 06Speed6 (12-19-2012) |
Thanks for offering to mic it, I can mic the cam if I decide to make one so I should be fine. Sounds like oem is the way to go then, now to find a good price for one, bitches aint cheap
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | ||
Groans: 793
| Not Ranked : 0 score Or the head was line bored high.
| Not Ranked : 0 score Well, for reference the thickness of the OEM one is .190 to .193 depending where I measured. |
| The Following 3 Users Say Thank You to timjs For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Thanks man!
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score If anyone knows a cheap place to get the OEM plate please post it. I've tried a few mazda dealers with no luck. They don't want to sell it.
| The Following User Says Thank You to Tomas For This Useful Post: | 06Speed6 (12-26-2012) |
(Thread Starter) | Not Ranked : 0 score I second that, those bitches are expensive.
| Not Ranked : 0 score what is CHEAP to you? here is a place for 148...OTC 303-1061 303-1061 - Camshaft Alignment Timing Tool (Mazda) here for 128 ...http://www.automotive-diagnostic-too...t-303-1061.htm here for the cam and crank tool 140.00 http://www.customautorepairtools.com...lignment-tool/ last place for 109...http://www.monstermarketplace.com/au...o-otc-303-1061
| Not Ranked : 0 score 109 is cheap enough. All those tools are steel right? Not aluminum? Guess this one is the same for $80 http://www.ebay.com/itm/Mazda-Twin-C...842c0a&vxp=mtr
i would try and find the cheapest OEM one possible because u know its built to stock standards. just because these other ones are made of steel doesent mean they are the correct width/length ect, which is the whole point of timing the motor.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 3 Users Say Thank You to superskaterxes For This Useful Post: |
![]() | | #19 | ![]() |
| Not Ranked : 0 score with that said then you might not want to get any of the ones that i posted for you to look at as i was just looking at price when i searched it..
| The Following User Says Thank You to qtrmile beast For This Useful Post: | superskaterxes (12-27-2012) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score the only one i would trust is OTC as they make half the mazda SST's anyway
| The Following User Says Thank You to superskaterxes For This Useful Post: | chuckms6 (12-27-2012) |
![]() | | #21 | ![]() |
Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() | |
| The Following User Says Thank You to chuckms6 For This Useful Post: | superskaterxes (12-27-2012) |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score OTC makes most Ford tools and half work on some mazda somewhere. OTC is good enough for me.
![]() | | #23 | ![]() |
| Not Ranked : 0 score What type of price are you looking for? I get discounts from my local dealer and i can see what they charge me for one if you want?
![]() | | #24 | ![]() |
| Not Ranked : 0 score What's the actual Mazda part# for that tool? I'm curious what MMS pricing is.
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score post 16 i posted several places that have them but they are copies not OEM...
![]() | | #28 | ![]() |
| Not Ranked : 0 score Just want to say I used the timing kit I got and it worked flawlessly. The link is in the other timing tool thread. Tapatalking
![]() | | #29 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| The Following 4 Users Say Thank You to jmhinkle For This Useful Post: |
![]() | | #30 | ![]() |
![]() Join Date: Jan 2013
| Not Ranked : 0 score I'm from Russia. Can anybody measure the plate and make a picture with dimensions, I want to do plate myself. If someone need a 303-507 (CT-B121) tool dimensions (mm): Thanks. Last edited by Stepik; 05-15-2013 at 03:09 AM. |
| The Following User Says Thank You to Stepik For This Useful Post: | torquemaniac (12-24-2013) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score That will cost you 20000 rubles and a mail order bride.
| The Following User Says Thank You to Tomas For This Useful Post: | Easter Bunny (10-20-2014) |
![]() | | #32 | ![]() |
![]() Join Date: Jul 2014 Location: Hungary/Europe
Rep Power: 0 ![]() Thanks: 1
I would need the plate (303-1061) dimensions also, because here in Europe we have not got such a good support and community to hire it for 1 or 2 days so I'm gonna make it my own. Thanks! | |
![]() | | #33 | ![]() |
| The Following 2 Users Say Thank You to Stepik For This Useful Post: | Code Monkey (10-20-2014), PanDee (10-21-2014) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Thank you Stepik! You helped me a lot, just one day before starting the VVT and chain replacement work! Greetings from Hungary! |
![]() | | #35 | ![]() |
| Not Ranked : 0 score What the fuck is going on here. Some kind of eastern block circle jerk?
![]() | | #36 | ![]() |
![]() Join Date: May 2010 Location: Stockholm, Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 646
| Not Ranked : 0 score I'm retarded. I sure feels that way. I bought a cam alignment tool and now It wont fit. Everything tells me it should, the measurements provided in this thread and others confirm that the part that should fit the slot is 5mm. My CAT is 5mm, but I cant get anything bigger than 1mm when I use a feeler gauge to measure between the top of the head and the slot in the cam. What am I doing wrong? Is the slot offset so my cams are 180* wrong? |
![]() | | #37 | ![]() |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
Can you take a picture of the camshafts so we can see the orientation of the lobes as well as a picture of the slotted ends of the cams? | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I was just on the wrong phase, ob nore turn fixed the problem. False alarm! |
| Cheapest cam timing tool set? | chuckms6 | Mazdaspeed3/6 General Discussion | 15 | 12-05-2012 07:52 PM |
