![]() Join Date: May 2008 Location: Fort Lauderdale
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
(Thread Starter) | Not Ranked : 0 score Any idea when you guys will have them?? My fuel cut is killing me n u guys r the only people (monopoly!!!) that sell em.lol. PLease keep me updated when they'll be back because fuel cut is driving me crazy man! |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 16 Times in 11 Posts
![]() Join Date: Mar 2008 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 914
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score I PM'd ken and he said he would make a post when he gets them in stock. Last week he told me hed be getting some in either this week(which was this past week), or next week(which is this week). so hopefully soon! I know I'm looking for internals as are a few others, so hopefully soon. | |
![]() Join Date: Mar 2008 Location: west palm beach, fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
| Not Ranked : 0 score all u need is a mapclamp i dont i had same cuts n solved it with a mapclamp ur def not out of fuel if i aint. if u have the cash now might as well either way ull need a mapclamp |
| The Following User Says NO Thank You to andre0121 For This Un-useful Post: |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 935
Groans: 61
__________________ ************************ Beginners guide to turbos<- New to this? Give it a look! -And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice. | |
(Thread Starter) | Not Ranked : 0 score i am completly lost...someone fix my brain bcuz im confused... |
Groans: 61
| Not Ranked : 0 score A mapclamp adjust perceived load and boost to the ECU to adjust the spark I believe. (dont quote). This is why adjusting your mapclamp can help with sputtering. Sputtering is a spark issue, fuel cut is fuel related.
| The Following User Says Thank You to Demi For This Useful Post: | phillyb (09-30-2008) |
(Thread Starter) | Not Ranked : 0 score hmmm..interesting..never thought of that...anyone agree? |
Groans: 61
| Not Ranked : 0 score Of course you need plugs too. I started getting sputtering in 3-6 when i first installed my MBC. Then i dropped the mapclamp down to 8psi and I only got it in 5-6th, because of the increase in boost seen in each gear (5th gets more than 4th). Then I threw the new plugs in but fucked up the gapping. Fixed the gapping and it stopped sputtering in 5th but i broke one of the contacts so i think i need a new set to fix it in 6th.
| Not Ranked : 0 score i have a CDFP and still get cuts
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score I started getting boost cut within the last week cause of the temp drops
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
| Not Ranked : 0 score same here the pump wont fix that for you =(
| Not Ranked : 0 score lol my bad it was a quick post wat i meant to say is u dont need a pump its a safety thing. if u have the money get it if not dont. wat u need is a mapclamp if ur havin violent cuts its boost u might be spiking high i did when i put my mani on. ur boost is probably goin wild so u need to clamp it n stertch ur coils. hope i sound better there lol its morning |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
| Not Ranked : 0 score whats this boost cut yall speak off? =P phillip, better fix that shit, i want zero excuses |
(Thread Starter) | Not Ranked : 0 score damn...so i need a map clamp to fix this boost/fuel cut? Again its not really violent more like hesitation n jerks a lil n backfires hard. |
Groans: 175
No hood 16 inch rims Gutted back seat empty gas tank with a teaspoon of 116 octane race gas Plugs gaped to 2 25 psi Theres the Laloosh killer formula right There
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
youll probably need at least a tablespoon to make it from 30-140. everything else looks great though.
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | ||
| Not Ranked : 0 score dont forget to drop a duece before the race |
![]() | | #19 | ![]() |
| Not Ranked : 0 score lose all the windows while youre at it. |
![]() | | #20 | ![]() |
| Not Ranked : 0 score GOT NOS !
![]() | | #21 | ![]() |
Groans: 175
| Not Ranked : 0 score Im on a diet as we speak. I need to ensure the proper amount of cars are put on young Christopher.
![]() | | #22 | ![]() |
Groans: 175
| Not Ranked : 0 score I was about to buy a top mount but I think im gonna just go form the rims. Cut down on that rotating mass.
![]() | | #23 | ![]() |
| Not Ranked : 0 score how did this shit spread here its like cancer lol
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score WTF?? dammit loosh!! had enought hacking yet?lol |
![]() | | #25 | ![]() |
Groans: 175
![]() | | #26 | ![]() |
![]() Join Date: Mar 2008 Location: Perth Amboy, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 704
Groans: 86
Groaned at 36 Times in 25 Posts
| Not Ranked : 0 score metamucil to keep you regular while dieting helps! maintain the deuce-dropping 1-2 times daily.... for maximized weight savings of course
__________________ L76-powered |
| The Following User Says Thank You to mdogg For This Useful Post: | Darksun280 (09-30-2008) |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 1791 ![]() Thanks: 2,239
Groans: 62
![]() | | #28 | ![]() |
| Not Ranked : 0 score 30 roll |
![]() | | #29 | ![]() |
![]() Join Date: Jun 2008
| Not Ranked : 0 score make vid |
![]() | | #30 | ![]() |
Groans: 175
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
Groans: 175
P.s Fuck Chris's couch....
![]() | | #33 | ![]() |
| Not Ranked : 0 score lol man, i never knew your main goal in life is to beat me phil. Wanna go lb for lb boost wise? |
![]() | | #34 | ![]() |
Groans: 175
25psi it is
![]() | | #35 | ![]() |
| Not Ranked : 0 score ill take you out running 7 less psi |
![]() | | #36 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score 2 things and i have no idea why no one has said anything about this. fuel cut and boost cut are two different things. they are somewhat related if i understand correctly, but please view this thread i just found - What is Fuel Cut - DSM Forums - which has some good faq in the beginning. possibly debatable, but good info nonetheless. if i understand what i read correctly, fuel cut has to do with the MAF boost cut has to do with the MAP a mapclamp would be used for boost cut, not necessarily fuel cut. although, in theory, i guess you could hook a clamp up to the MAF, but IDK...and definitely don't let me do it. |
![]() | | #37 | ![]() |
Groans: 175
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous Last edited by Darksun280; 09-30-2008 at 02:37 PM. | |
| The Following User Says Thank You to Darksun280 For This Useful Post: | phillyb (09-30-2008) |
![]() | | #38 | ![]() |
Groans: 175
| Not Ranked : 0 score i'll spin you out if you start to pull away from me......
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous Last edited by Darksun280; 09-30-2008 at 02:39 PM. |
![]() | | #39 | ![]() |
Groans: 1,940
| Not Ranked : 0 score hahaha, i know...i'm so sorry, but i'm not on the east coast anymore, i feel like i can't get down with all the shit you and chris are talking. i don't even like calling him chris, or you phil...cause i don't know you muther fuckers... i'm just trying to learn about fuel pumps and fuel cut. hahahaha...carry on though |
![]() | | #40 | ![]() |
Groans: 175
| CDFP internals upgrade | CraigHJr | MazdaSpeed 3 - How-To's | 144 | 06-06-2014 01:59 PM |
| New CDFP TSB | dadasracecar | MazdaSpeed 3 - Engine, Transmission & Driveline | 200 | 12-09-2008 02:09 AM |
