Like Tree3Likes
  • 3 Post By Bertospeed3
 Old 05-30-2019, 09:12 AM   #1
Dc5eli's Avatar
Posts: 5   (View Stats)
Dc5eli has a little shameless behaviour in the past
Default Car shut off at 140
My car seems to shut off after a long wot pull. I was racing my friend hit 140 and it shut off when I let off the gas and coasted In neutral. I was looking at my ap and the fuel pressure was around 1670 psi the whole time during the pull. Air fuels were good and the temp was good. When I started my car up it was at 228 on the temp which I think was caused by being hot and nothing to cool it off while sitting on the side of the highway. I used the search method but no one had the problem where it will start up fine after it shuts off.
Dc5eli is offline   Reply With Quote
The Following User Says NO Thank You to Dc5eli For This Un-useful Post:
Vansquish (05-30-2019)
 Old 05-30-2019, 09:22 AM   #2
Police - Grammarhead
Vansquish's Avatar
Well, there's your problem!
 Old 05-30-2019, 10:22 AM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Lol
Stockish
 Old 05-30-2019, 12:59 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Cool story bro. Keep going 140 until it doesn't happen anymore.
It usually stops when:
1:ZZB
2:You're in jail
3:You're wrapped around a tree.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Db09ms3 (05-30-2019)
 Old 05-30-2019, 01:04 PM   #5
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
When I started my car up it was at 228 on the temp...
You sure it read "228" and not "ZZB"?
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 05-30-2019, 01:43 PM   #6
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
1:ZZB
2:You're in jail
Maybe it was 140km/h....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-30-2019, 03:38 PM   #7
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
This guy's whole post history is a shit show... RIP another MS6
94 M
MS6
IS350
 Old 05-30-2019, 03:58 PM   #8
MSMS3's Avatar
Posts: 2,825   (View Stats)
The Speed 6 has a 149 mph speed limiter setting in the stock ECU. Of course, that can be raised in aftermarket tunes. Also, there can be speedometer error if tire size is changed and diameter is different. Taller tires, for instance, will make the speedometer read low. So a car going an indicated 140 may be going 150.
But OP is an idiot. Irrespective of the serious danger he created for others on a public highway, his now 14 year old car may simply have a weak engine and not able to produce enough horsepower to exceed a true 140.
I seem to recall in another thread that he had a smoking turbo and also has problems with the rear differential. Yet, he's taking that car out on a public highway making top speed runs where other people's girlfriends, wives and children are exposed to his stupidity.
I admit that I used to do stupid things like that, but fortunately outgrew that shit and was lucky to avoid killing anyone.
FWIW: It takes about 1100 feet, almost four football fields, to stop from 140 mph, if the brakes don't fade and go up in flames. Something to think about.
They make tracks for top speed tests, and an aging MS6 deserves better treatment.
 Old 05-30-2019, 05:02 PM   #9
Db09ms3's Avatar
You need to read up on how to modify this car correctly and quit that subie shit I told you about (re: trying to do donuts). Secondly, do a full tune up and change/check all the fluids throughout the drivetrain. Get to know the car and realize that with high miles on any motor with boost won't last very long if you 'race' it.
Stockish
How to win the Indy 500? ‘Shut up and drive’ Haltech Automotive News 0 05-25-2018 07:01 AM
Car randomly shut off schmidtyphotos MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 08-14-2016 01:45 PM
car wont shut off speed3_kcco 2010 MS3 - Troubleshoot/Diagnostics 11 06-05-2014 01:23 AM
My MS3 Just Shut Off While Driving GreyGhost Gen2 MS3 General Discussion 25 03-25-2013 09:38 PM
Car shut off 6-Speed-6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 02-28-2009 11:04 PM
Page generated in 0.31700 seconds with 27 queries
