  • 1 Post By m4tic
  • 1 Post By Tabasco69
 Old 12-08-2011, 05:27 AM   #1
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Default Car will not start
I was driving from Baltimore to NY last night and the car was running great, had to take a pit stop so I pulled over into a rest-stop in NJ, when I came back out to my car 5 minutes later the car would not start. It made absolutely no attempt to start, no cranking, no clicking, no anything. The lights all turned on but there was absolutely no activity coming from the engine bay. I tried multiple times to start it again over the course of 2 hours, finally 2 hours later it just magically starts like nothing ever happened.
This has happened twice before over the last 8ish months, but on those occasions it only gave me 5 minutes of aggravation.
So what do you think the deal is? Thanks for the help
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 12-08-2011, 08:38 AM   #2
TRex's Avatar
Posts: 3,139   (View Stats)
wet maf?
 Old 12-08-2011, 08:50 AM   #3
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
My shit does this too. So you can turn the key all the way and the power goes on, but there's no activity of the engine even trying to start. I usually put the key in, wait abit, then crank it and it works fine. Sometimes it takes a few tries
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
The Following User Says Thank You to Scribbles For This Useful Post:
kunfu (12-08-2011)
 Old 12-08-2011, 09:31 AM   #4
dadderllama's Avatar
Posts: 123   (View Stats)
dadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond repute
I think it is just NJ.... did u get gas too? Im in NJ for work and my work truck runs like shit on nj gas (from multiple stations)... never wants to start, runs like shit and stalls out (its an automatic). BUT ON THE PLUS SIDE IM FLYING HOME TODAY AND GET TO DRIVE MY BABY ONCE AGAIN!!!!!
CS LED kit, Aux input, Sure TIP, Sure SRI v2, Sure RMM, Turbosmart BPV, IVT22's, Prosport Boost gauge, JBarone SSP v2 and counterweight, H&R Drop Springs, Bilstein Shocks, Cobb AP, Sure M6, Sure Juggernaught, Sure Dreadnaught, Whiteline RSB, DSS axle, AT internals, Sure Charge Tubes. Currently getting DIZZY tuned!
dadderllama is offline   Reply With Quote
 Old 12-08-2011, 09:50 AM   #5
m4tic's Avatar
Posts: 4,928   (View Stats)
crappy/dirty battery terminals... take a wire brush to the cables and battery posts.. electric grease them too
Atlanta likes this.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 12-08-2011, 12:35 PM   #6
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Had this happen before, turned out to be a glitchy "immobilizer" bullshit mazda incorporated as anti theft device, if it doesn't even try to turn over, you do not hear any selenoid clicking and the little red key symbol goes nuts in the gauge cluster....it is the "IMOBILIZER".....glently tap the wire socket going to the ecm....other then that prepare to get raped by the stealership.
tymoto21 likes this.
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
kunfu (12-08-2011)
 Old 12-08-2011, 01:59 PM   #7
kunfu's Avatar
Groans: 56
So far this sounds like the most likely. Crappy gas and wet maff seem unlikely since it makes no attempt at all at turning over, and teh solenoid does not click.
Speed 3 2007:
 Old 12-08-2011, 04:31 PM   #8
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
check battery terminals and also, your power clip on the starter might not be getting a connection. wiggle it
The Following User Says Thank You to TWOptSL0W For This Useful Post:
themytb (12-15-2011)
 Old 12-08-2011, 05:11 PM   #9
ms6_ward's Avatar
Posts: 41   (View Stats)
ms6_ward is a name known to allms6_ward is a name known to allms6_ward is a name known to allms6_ward is a name known to allms6_ward is a name known to allms6_ward is a name known to all
werd. Used to happen to me and Id get pissed thinking the car had major issues. Nope just clean the terminals and make sure everything is tight and snug.
ms6_ward is offline   Reply With Quote
 Old 12-08-2011, 07:55 PM   #10
kunfu's Avatar
Groans: 56
If this was the case why do the lights still turn on and all of the other electrical systems?
Speed 3 2007:
 Old 12-08-2011, 08:18 PM   #11
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
Could be the switch in the clutch pedal that prevents engine from starting when clutch is out.
Might be worth checking out.
cesaros is offline   Reply With Quote
The Following User Says Thank You to cesaros For This Useful Post:
kunfu (12-22-2011)
 Old 12-08-2011, 08:33 PM   #12
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
I had this exact issue that plagued me for a few months. Stealership said it was common to have corrosion on the cable that runs up to the starter, but mine was fine. I cleaned the hell out of my terminals and put grease on them, but it didn't help either. I found that if I jiggled the cable that runs from the battery to the fuse box that I could duplicate it, so I replaced it with a length of battery cable from Advance Auto. It's a pretty big cable and didn't really look messed up when I took it out... but my car has been perfect ever since.
Btw, if you try to buy this cable from the dealership it is like $130, and a 2ft length of it from Advanced was about $7.
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
The Following User Says Thank You to kabobulate For This Useful Post:
kunfu (12-09-2011)
 Old 12-09-2011, 08:46 AM   #13
vincent1010's Avatar
Posts: 76   (View Stats)
vincent1010 is a glorious beacon of lightvincent1010 is a glorious beacon of lightvincent1010 is a glorious beacon of lightvincent1010 is a glorious beacon of lightvincent1010 is a glorious beacon of lightvincent1010 is a glorious beacon of light
I love how evey single person on this forum thinks they know everything and anything about mods and tuning... People sit here and talk all this nonsense but when a member cant even start his car, only 11 people comment and chime in!! See something wrong there , i do
vincent1010 is offline   Reply With Quote
The Following 10 Users Say NO Thank You to vincent1010 For This Un-useful Post:
ABSpeed3 (12-14-2011), Black Metal (12-16-2011), BobbleHead (12-10-2011), Boost Addict (12-09-2011), Don06speed6 (12-15-2011), Easter Bunny (12-14-2011), JmkC (12-15-2011), kabobulate (12-09-2011), Raider (12-14-2011), themytb (12-15-2011)
 Old 12-09-2011, 08:52 AM   #14
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
And your worthless post isnt helping either. People have been suggesting plenty of good ideas for a fix for this. You can only take so much advice at once, too much and you'll be overwhelmed, and have no idea where to start.
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
 Old 12-09-2011, 09:12 AM   #15
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
I wouldn't overlook the starter itself if you've tried everything else these guys mentioned. Some times the solenoids go bad. I know they've gone a long way since the 70s but still. Sometimes they can get stuck.
AtTheDriveIn is offline   Reply With Quote
 Old 12-09-2011, 11:35 AM   #16
m4tic's Avatar
this happened to me so many times... go to the gas station, stop the engine, get gas, try to start the engine, nothing happens and all my electrical turns off and my cluster needles start wigging out. then my lights slowly come on and stay dim.
all i did was clean the terminals and it just stopped. actually i replaced the neg cable with a $6 cable from oreileys
Originally Posted by Wiki
Corrosion at the battery terminals can prevent a car from starting due to electrical resistance. The white powder sometimes found around the battery terminals is usually lead sulfate which is toxic by inhalation, ingestion and skin contact. The corrosion is caused by an imperfect seal between the plastic battery case and lead battery post allowing sulfuric acid to react with the lead battery posts. The corrosion process is also expedited by over charging. Corrosion can also be caused by factors such as salt water, dirt, heat, humidity, cracks in the battery casing or loose battery terminals. Inspection, cleaning and protection with a light coating of dielectric grease are measures used to prevent corrosion of battery terminals.
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 12-09-2011, 11:41 AM   #17
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i burnt my one of my ign fuses, same problem
 Old 12-09-2011, 12:06 PM   #18
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
So - this same exact thing used to happen to me all the time. There is a spade connector that goes to where the starter is right below the intake mani/in front of the oil cooler (the "Terminal S Connector" in this screenshot).
This didn't get corroded, but it got coated with oil/grease just from its location. I tried cleaning it out with sandpaper, but that didn't turn out to be a reliable fix. The simple solution was to just cut off the connector and replaced it with another generic insulated spade connector.
My spade connector doesn't "click" in like the stock one, but it is pressure fit on there well enough that its more reliable than the stock one. If this is your prob too, it's easy to get to from under the car with just taking the belly pan off.
vbt101 is offline   Reply With Quote
The Following 3 Users Say Thank You to vbt101 For This Useful Post:
Jh8909 (12-15-2011), kunfu (12-14-2011), themytb (12-15-2011)
 Old 12-09-2011, 12:18 PM   #19
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
i had the corroded starter solenoid wire (power to everything but it wouldn't start with no starter relay click) and the stealership was nice enough to clean it for $100.
the paper clip trick in the clutch switch worked for awhile as it eliminated enough resistance to start her.
The Following 2 Users Say Thank You to karl-hungus For This Useful Post:
kunfu (12-14-2011), vbt101 (12-09-2011)
 Old 12-14-2011, 07:17 AM   #20
kunfu's Avatar
Groans: 56
lots of good info here. I guess I will start working through all of these, starting with the easiest.
Speed 3 2007:
 Old 12-14-2011, 08:37 AM   #21
I had a battery with a bad cell refuse to start, try try try start. Then be fine for weeks. POS Optima. Tested, failed, swapped, all was well.
 Old 12-14-2011, 10:11 AM   #22
kunfu's Avatar
Groans: 56
Thanks for the concern but 11 people on this forum is probably enough to solve any problem. Oh and fuck off.
90% sure this/was the problem. It makes sense, it would describe the symptoms my car had. Although I see how some of the other solutions could also be it.
Speed 3 2007:
 Old 12-15-2011, 09:57 PM   #23
ms6_ward's Avatar
Hows the car man did you get it fixed?
 Old 12-15-2011, 10:22 PM   #24
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
I know I'm late to the party, but +1 for the signal/trigger/small wire to the starter, happened to me, wire brushed the terminal and put some dielectric grease on it, hasn't happened again.
25%E85FREEKPERMED
Last edited by themytb; 12-15-2011 at 10:22 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to themytb For This Useful Post:
kunfu (12-22-2011)
 Old 12-15-2011, 10:25 PM   #25
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
@kunfu Did it get going yet???
Nator is what it does.
kunfu (12-16-2011)
 Old 12-16-2011, 04:42 PM   #26
kunfu's Avatar
Groans: 56
I know it was a long post............
"finally 2 hours later it just magically starts like nothing ever happened."
Thanks for asking though. Yeah its running fine....have i corrected the problem to make sure it will never happen again? Nope not yet.
Speed 3 2007:
 Old 12-16-2011, 07:00 PM   #27
POWERED BY POLSKA
themytb's Avatar
Groans: 38
Some crazy hot chick is going to want your sausage right now-- and then it wont start.
25%E85FREEKPERMED
kunfu (12-22-2011)
 Old 12-17-2011, 12:46 AM   #28
ms6_ward's Avatar
hahaha ^^^^^ how fucked up would that be lol
Which map should i start with Krylos225 MazdaSpeed 3/6 - ECU Computer Tuning 13 03-09-2012 07:38 PM
Car will not start Mikey MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 09-08-2011 04:54 AM
KTM X-Bow will start at $88,500 in the U.S. Haltech Automotive News 0 03-04-2011 09:10 AM
If you could start over Whiteboy Mazdaspeed3/6 General Discussion 28 02-14-2011 06:29 PM
Where to start on the MS3 Guati91 Mazdaspeed3/6 General Discussion 8 02-09-2011 06:51 PM
Page generated in 0.47631 seconds with 38 queries
