  • 1 Post By SpeedSixxx
 Old 08-20-2011, 11:44 AM   #1
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
Neutral  +1 score
Arrow Carbon build-up on Speed 6/3 & CX-7. A big issue!!!
As some of you already know that carbon build-up in any direct injection engine(DFI, GDI, DI) will be an issue. There is no gasoline fuel to wash clean the intake manifold and the intake valves.
Compared to port injection/carburated engines that have fuel going through the intake mani and then to the intake valves. Our engines have a Positive Crankcase Ventilation (PCV) system. Basically, this connects the engine block to the intake manifold. In the event that there is boost blowing by the piston rings, it relieves the pressure in the oil sump. Problem is that there is also misc. crap that comes along from the oil sump (oil, fuel, etc.).
An OCC is used to prevent crankcase blow by waste from being sucked into your intake manifold, by design this is supposed to happen (very minimal amounts to be burned off) but a forced induced engines put out a lot more crankcase pressure and manifold vacuum/positive pressure then an n/a engine, sometimes/a lot of time large amounts of unspent fuel, condensate and oil vapor go through the venting system usually under boost and plume of burn off come out of the exhaust tail pipe, attributes to possibly fouling the plugs, fouling O2's and other sensors etc also some of this can be sucked into intake piping and intercooler reducing cooling effectiveness and making a god damn mess of things.
I'm gathering info to help anyone with this inherent future problem....great for noobies or for people who want to prevent this problem.
And this is what is caught in the OCC...
And this is what happens when all that crap from above gets fried onto the intake valves, ewww...
Here are few solutions to fix this problem are:
1. Delete the EGR valve: ported intake-PCV catch can-EGR delete=DONE - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
2. Install an oil catch can(OCC): whoosh&#39s oil catch can teaser - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
and this: Oil Catch Can ... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
3. Set up an water/meth injection kit: How to: Water/Meth injection install - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
4. Use SeaFoam through the brake booster hose: Seafoam - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
5. Have the intake cleaned by a professional: BG Findashop - Search for an authorized BG service center near you!
6. How to remove the Intake Manifold on a Speed6: HOW-TO: Intake Manifold Removal - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
and from SuperSkaterxes:How-to remove intake mani + install OCC - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Torque specs for the throttle body bolts are 71-101 in/lbs.
Torque specs for the intake manifold bolts are only 13-16 ft lbs !!
The bolts are very small, they screw into aluminum, and there are a total of 8 bolts securing the relatively light manifold. 1/4" torque wrench is best for this. 170 in/lbs = 14 ft/lbs
7. How-to professionally decarbonizing your engine on the Speed 6: How-to professionally decarbonizing your engine on the Speed 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
8. Why you need an OCC for the MazdaSpeed 6: Why you need an Oil Catch Can, FYI - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Important note--->Running fuel injector cleaner through the gas tank "WON'T" clean anything on the intake side.....I wish it could.
Here is some info from Porsche owners having the same problem: Carbon buildup on DFI engines. -
Audi engine's too. Great info here: Audi FSI Engine Carbon Build-up Megathread
GM's 3.6L V6 DI engine carbon build-up issues: Direct Injection causes power loss overtime? - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
GM's Top Engine Cleaner: GM Top Engine Cleaner Replaced - GM Techlink
Here's info on where to buy stuff to fix/stop/prevent carbon build-up:
Water/Meth kits: AEM Water/Methanol Injection Kits - Water-Meth Injection Systems for Turbo/Super - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
and from...
DevilsOwn Water/Meth: DevilsOwn Injection
Oil Catch Can Kit(OCC): Home - Performance Automotive Development LLC
Seafoam: Sea Foam | Motor Treatment
Seafoam Spray: Sea Foam | Sea Foam Spray
MOC Cleaning Products: MOC Products - Preview Information
MOC Optimizer Foaming Spray: MOC Products - Preview Information
EGR Block Off Plate only from StreetUnit: StreetUnit EGR Block Off Plate: MAZDASPEED 6, MAZDASPEED 3, CX-7
EGR Block Off Plate & Plug from JBR: EGR Block Off Kit MS6 [EGRBO] - $20.00 : James Barone Racing, Custom Fabrication
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
The Following 20 Users Say Thank You to daztdMS6 For This Useful Post:
AZSPEED3 (08-20-2011), breakfstincluded (08-21-2011), Code Monkey (08-22-2012), Easter Bunny (08-22-2012), Hectik1 (08-26-2011), J'sSpeed3 (08-22-2012), JNR5005 (08-21-2011), JS + MS3 (08-20-2011), kgb (08-21-2011), manelscout4life (08-20-2011), NCZ13 (08-20-2011), PunjabiPlaya (08-20-2011), Realgib3 (08-25-2011), SKiZ0TT (12-01-2011), speedms6 (08-22-2012), tddvrrn (09-03-2012), TexasSpeed3 (08-20-2011), TriO (04-01-2012), v8killer (08-23-2012), xtasy (08-20-2011)
The Following User Says NO Thank You to daztdMS6 For This Un-useful Post:
SpeedSixxx (08-20-2011)
 Old 08-20-2011, 11:51 AM   #2
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
most of that stuff has been posted on here too, but thanks for collecting it all
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following User Says Thank You to PunjabiPlaya For This Useful Post:
daztdMS6 (08-20-2011)
 Old 08-20-2011, 11:54 AM   #3
daztdMS6's Avatar
Thanks, I did this on the other forum I belong to and i just wanted to pass the info to MSF family.
MazdaSpeed 6
The Following 3 Users Say Thank You to daztdMS6 For This Useful Post:
AZSPEED3 (08-20-2011), Raider (08-25-2011), rfinkle2 (08-20-2011)
 Old 08-20-2011, 12:01 PM   #4
NCZ13's Avatar
Posts: 1,268   (View Stats)
Im using this new product we got at work today from MOC.
Its intended for DI cars as the product foams up in the head and loosens the carbon deposits. One of the techs used it on a new turbo sonata with 15k and said he could definitely feel the difference after he used it.
Its definitely a product that you have to change the oil after. So this stuff definitely makes its way through the engine.
Ill report back with results. I am at 57k and have never used any sort of treatment.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
The Following 3 Users Say Thank You to NCZ13 For This Useful Post:
daztdMS6 (08-21-2011), rfinkle2 (08-21-2011), TexasSpeed3 (08-20-2011)
 Old 08-20-2011, 12:11 PM   #5
Karmat's Avatar
Posts: 1,179   (View Stats)
Great collection and reminder.
This is a stupid problem but it is a problem nevertheless.
2002 Corvette Z06 (Black)
The Following User Says Thank You to Karmat For This Useful Post:
 Old 08-20-2011, 12:30 PM   #6
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
try doing research before you post info that is ALL OVER MSF....
it's called sea foam and it will fix most carbon build up problems...
 Old 08-20-2011, 12:54 PM   #7
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
seafoam doesn't do shit for our intake mani/valves... or any DI platform for that matter.
I would be interested in this MOC stuff so I don't have to do this..... how to: clean your valves vol 2
The Following User Says NO Thank You to Fatguy729 For This Un-useful Post:
SpeedSixxx (08-21-2011)
 Old 08-20-2011, 01:10 PM   #8
Speed6killah is a Mazda tech, and recommends Mazdas own "zoom" juice, or whatever it is called.
They use it to clean the apex seals on the rotary motors, and he has had quite a few intake manifolds off also.
 Old 08-20-2011, 01:13 PM   #9
SpeedSixxx's Avatar
Groans: 778
really?
sea foam doesnt do anything for DI cars?...
are your retarded... oh wait you are...
The Following User Says Thank You to SpeedSixxx For This Useful Post:
sleepyspeed6 (09-04-2012)
 Old 08-20-2011, 01:15 PM   #10
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
I would disagree with that, I dont think anyone on this forum has seen seafoam clean valves.
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 08-20-2011, 01:32 PM   #11
Fatguy729's Avatar
Groans: 82
really?
ok interwebz hardass... I'm retarded... and seafoam still will not clean your intake manifold or valves
 Old 08-20-2011, 01:44 PM   #12
NCZ13's Avatar
I just got done with it.
Engine definitely feels a bit smoother and feels a bit more peppy, and I shot out a good bit of black and gray smoke out the tail pipe. Made the bays smell nice. Also got to rev the shit out of my car at work
Will do an oil change at the end of the day as well.
1986 Mazda RX7
Last edited by NCZ13; 08-20-2011 at 01:44 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to NCZ13 For This Useful Post:
 Old 08-20-2011, 01:49 PM   #13
SpeedSixxx's Avatar
Groans: 778
where do you think sea foam goes when it's sucking through your vacuum lines...
it's pointless to argue with you guys.
intake valves...sea foam won't do much but it sure does loosen up some of the build up on valves..
as for the IM, again..
where does the sea foam go when you let you brake booster vac line suck it all up?..
oh shit... it goes through the entire system and it sure does clean IM's..
not to mention there shouldnt be any build up of carbon in your intake manifold.. if there is you have some serious issues.
there will be some oil residue in the IM but no carbon build up except for the EGR port.
I have 80000 miles on my speed 6 and I use sea foam every few oil changes.
my IM is SPOTLESS.
The Following 3 Users Say Thank You to SpeedSixxx For This Useful Post:
daztdMS6 (08-21-2011), kmac (08-21-2011), sleepyspeed6 (09-04-2012)
 Old 08-20-2011, 01:54 PM   #14
SpeedSixxx's Avatar
Groans: 778
can I ask how do you use the MOC multi purpose engline cleaner?
do you suck it through your vac line as you would with sea foam or is there another method to use it.?
also what is it made out of?
alcohol based?... like sea foam..?
 Old 08-20-2011, 02:03 PM   #15
kunfu's Avatar
Groans: 56
my IM is SPOTLESS.
Notice Im not arguing with you about where it ends up. I simply said it doesn't clean the valves. I duno maybe it helps slow buildup on the valves....but it seems without fail that anytime someone takes a look at there valves they are covered in shit, seafoam or not.
How much does it generally cost to have your vales cleaned?
And yes im far to lazy to spend a whole day doing it myself.
Speed 3 2007:
Last edited by kunfu; 08-20-2011 at 02:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-20-2011, 02:05 PM   #16
NCZ13's Avatar
I used the brake booster line. It comes with a trigger and hose tool to inject it into the line.
On the can it says it contains
xylene
propane/isobutane
solvent naptha
ethylbenzene
petroleum distillates
alkyphenol ethoxylate
morpholine
1986 Mazda RX7
 Old 08-20-2011, 04:21 PM   #17
bnoon's Avatar
Posts: 1,770   (View Stats)
Seafoam does clean the intake and valves. Not sure where you guys got the info that it's not. Running a can of seafoam through the intake is just what the doctor ordered for direct injection when you suck it through a vacuum hose.
The only way it wouldn't clean the intake or valves is if you only used it as a fuel system cleaner, but seafoam is so much more than just that.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following 3 Users Say Thank You to bnoon For This Useful Post:
kmac (08-21-2011), SKiZ0TT (12-01-2011), SpeedSixxx (08-21-2011)
 Old 08-21-2011, 08:55 AM   #18
daztdMS6's Avatar
I have 80000 miles on my speed 6 and I use sea foam every few oil changes. My IM is SPOTLESS.
At how many miles did you start using the Seafoam to clean the IM? I started doing the intake valve/IM cleaning last fall at every oil change.
Are you going to remove the IM soon to see the results of the MOC?
MazdaSpeed 6
Last edited by daztdMS6; 08-21-2011 at 08:55 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-21-2011, 09:32 AM   #19
SpeedSixxx's Avatar
Groans: 778
xylene
propane/isobutane
solvent naptha
ethylbenzene
morpholine
I'm not talking about all of you but the guys calling me an internet tuff guy and basically saying I dunno what I'm talking about.
please shut your mouth.
as the dude that I quoted up top stated, the MOC cleaner is EXACTLY the same as sea foam and works the same and used the same.
maybe you guys don't know or trust me but read what bnoon said..
sea foam works and works well, I came in here to try and correct what you guys said and maybe I came off a little rude but in the end I'M RIGHT and always new it.
kmac (08-21-2011)
 Old 08-21-2011, 09:46 AM   #20
SpeedSixxx's Avatar
Groans: 778
I started using sea foam at about 38000 miles every other oil change or so.
I'm not sure if it's "ok" to use sea foam or any other MOC type of product at every oil change but like I said I use it every other change and for a while now..
yes when it's all done you get a SHIT TON of smoke and everyone but you thinks your car is on fire.
the car def feels a bit "peppier" everytime I use sea foam...
no need to take your IM off when using any product, using it as directed works great if you take the right steps.
I know you can clean the exhaust valves with a shot gun cleaning kit ...
the intake valves as well...
I assume if you were to take your IM off to use sea foam directly on the vlaves it would work a lot better but be careful not to hydro lock....
and you can add sea foam to your oil and gas as well...
do all the steps and you will have a cleaner happier motor...
use at least half the bottle in the vac line, if not 3/4ths...
use the other half of the bottle in your oil and your gas and then take your 15 min drive to clear the system of the sea foam or whatever...
then do your oil change and your car will wanna suck you off.
Prodoco likes this.
The Following 2 Users Say Thank You to SpeedSixxx For This Useful Post:
 Old 08-21-2011, 09:51 AM   #21
SpeedSixxx's Avatar
Groans: 778
^^^ really? have you been here long enough and read enough to really make the assumption that "no one on this forum has seen sea foam clean valves..."
it's been tested, been proven and is a FACT..
please hold back on replying because your opinions are no longer valid.
and i'm done.
kmac (08-21-2011), KusteLokal (09-04-2012)
The Following 2 Users Say NO Thank You to SpeedSixxx For This Un-useful Post:
Fatguy729 (08-21-2011), laxplayermjd (08-21-2011)
 Old 08-21-2011, 09:55 AM   #22
daztdMS6's Avatar
Arrow
I assume if you were to take your IM off to use sea foam directly on the valves it would work a lot better but be careful not to hydro lock..
I know you don't have to take the IM off to use SF silly, I'm just wondering what the results are from using MOC . If some one has a borescope to peak inside the engine, the IM removal to see the valves is not needed.
MazdaSpeed 6
The Following 2 Users Say Thank You to daztdMS6 For This Useful Post:
kmac (08-21-2011), SpeedSixxx (08-21-2011)
 Old 08-21-2011, 09:59 AM   #23
SpeedSixxx's Avatar
Groans: 778
taking off the IM is not so hard...
I agree, looking at the Intake valves before using MOC or sea foam and then looking at them again after ... you would see a diff.
if you have over 50000 miles on your DI car and just started using sea foam, use it every oil change as you def need it.
if you have been using it on a constant like myself you should have a cleaner motor then most.
only prob I have it 80k miles on the motor and original PCV.. I must change that soon.
kmac (08-21-2011)
 Old 08-21-2011, 10:05 AM   #24
daztdMS6's Avatar
Yeah, I would change that PCV soon.
MazdaSpeed 6
kmac (08-21-2011), SpeedSixxx (08-25-2011)
 Old 08-25-2011, 03:55 PM   #25
SpeedSixxx's Avatar
Groans: 778
fatguy729 and kunfu.....
where are your witty remarks now?
 Old 08-25-2011, 09:36 PM   #26
Fatguy729's Avatar
Groans: 82
I'm waiting for when you pull your intake manifold off and shit yourself cuz your valves look exactly like every other persons' on this forum.
The Following User Says Thank You to Fatguy729 For This Useful Post:
BigjohnB20 (08-25-2011)
SpeedSixxx (08-26-2011)
 Old 11-30-2011, 06:21 PM   #27
drewj's Avatar
Posts: 3   (View Stats)
drewj is an unknown quantity at this point
After cleaning the IM/valves, installing an OCC and EGR block off plates, and performing Sea Foam treatment, what "other" factors will contribute to carbon build up? I know in the perfect theoretical world, we'd all have the solution to stop carbon build-up completely. However, this is not true. Thanks in advance for any insight.
drewj is offline   Reply With Quote
 Old 12-01-2011, 07:39 PM   #28
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
there is no way to stop buildup. even on port injected cars with all their fancy additives in fuel, carbon still builds up, its a fact of life. only regular cleanings can remedy the situation. all of those other things only slow the process, but we cant stop it
 Old 08-22-2012, 06:35 PM   #29
Oldturbonoob's Avatar
Posts: 26   (View Stats)
Oldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to all
Groaned at 4 Times in 1 Post
Default BG Induction service??
I recently purchased a used 2009 MS3. The service records indicate that a BG Induction service was performed at 29304 miles and it currently has 38889 miles. Does the BG induction service clean the valves very well? I've been doing some reading on this forum prior to registering and have seen alot about self service valve cleaning from Sea Foam to chemtool and walnut blasting.
I guess bottom line if install a OCC and delete EGR and have another BG Induction job done, will my carbon build up worries be completely over?
I should read more completely....it would seem the answer is right above me.
Last edited by Oldturbonoob; 08-22-2012 at 06:37 PM. Reason: possibly a stupid question that was already answered
Oldturbonoob is offline   Reply With Quote
 Old 08-22-2012, 07:09 PM   #30
daztdMS6's Avatar
BG induction service does very little at cleaning the valves......I've done it several times. Like Twotpslow said, installing a occ and deleting the egr will slow the carbon build-up. The only true way to clean the valves is to either soak and scrub or soak and blast with walnuts. Since I just walnut blasted my valves after 128,000 miles, I will do the BG induction service at every oil change. I own a BG apparatus so for me to do it is very cheap and easy.
Here's an update thread on carbon build-up: Carbon build-up on Speed 6, 3 & CX-7. A big issue
MazdaSpeed 6
 Old 08-22-2012, 08:34 PM   #31
manila's Avatar
Posts: 1,767   (View Stats)
@NCZ13 Did you ever take off the IM and examine the valves after using the MOC?
I've only got 10k on the pu and haven't installed the EGR delete and an OCC yet.
'12 MS3 Black Mica w/ Tech
 Old 09-03-2012, 07:49 PM   #32
So I cleaned my valves with a combination of a pistol cleaning rod and 32 cal bore brush and walnut media. Presoaked with B12 for an hour on each port. My valves were horrible. I'm talking mountains of carbon. Sorry no pictures. Took me two days to do (most of that was cleaning and resoaking and cleaning again). Either way it needed doing (cleaned the intake manifold and EGR pipe while I was at it.
I idle is more even now and the car barely vibrates at all with the AC on which is a vast improvement. I haven't gone WOT with it yet but around the block impression seemed to rev up faster and pull just a tad harder.
It was a pain in the
The Following User Says Thank You to Oldturbonoob For This Useful Post:
daztdMS6 (09-03-2012)
 Old 09-03-2012, 08:15 PM   #33
daztdMS6's Avatar
Yes, pain in the butt to do. However, well worth it.
MazdaSpeed 6
 Old 09-04-2012, 12:43 AM   #34
I did notice that my intercooler was relatively clean on the inside and the turbo inlet tube is stout and direct. I was thinking about an intake and turbo inlet, but now that I have had a good look, I just don't see the benefit of the inlet, round or oval it is all about the space for flow and the stock has plenty. The air box on the other hand...sucks. I am a noob to turbo but not to engines. I do think an intercooler with a tad more thickness and a less sharp inlet angle would be of benefit but I don't know if FMIC is the answer. Seems like a long tube distance...that would greatly increase lag, just like in an NA engine...people make the mistake of tubing the crap out of the intake...cold air at the end of a long reach...isn't going to help that much...but the ability to breath easily in an instant, that is what can make snappy throttle. I could be wrong...haven't dealt with forced induction before this.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/carbon-build-up-speed-6-3-cx-89363/
Carbon buildup issues and their long term prevention - 2015+ S550 Mustang Forum (GT, GT350, GT500, I4, V6) - Mustang6G.com This thread Refback 03-17-2015 08:56 AM
WRX hatch still a chance ... - Page 47 - NASIOC This thread Refback 07-29-2014 11:06 PM
Carbon buildup issues and their long term prevention - 2015+ S550 Mustang Forum (6th Generation Platform) - Mustang6G.com This thread Refback 07-12-2014 11:16 PM
Mi MS3 se jalonea a partir de la 3ra This thread Refback 06-15-2014 10:08 PM
Carbon buildup on DFI engines. - This thread Refback 06-25-2013 09:10 PM
Who can do a MS3 Intake Valve cleaning in LA/OC? This thread Refback 03-19-2013 12:15 PM
? View topic - Carbon build up on DISI motor This thread Refback 12-19-2012 11:29 AM
• View topic - Carbon build up on DISI motor This thread Refback 08-23-2012 03:18 AM
DI Carbon build up removal question ztnedman1 Gen2 MS3 General Discussion 8 05-31-2011 04:12 AM
Dallara to build its own carbon fiber sports car? Haltech Automotive News 0 02-19-2011 02:10 PM
Intake Removal....Carbon build-up? LoresonDE MazdaSpeed 6 - Engine, Transmission & Driveline 11 11-15-2010 03:18 PM
Page generated in 0.56791 seconds with 32 queries
