 Old 11-26-2018, 11:38 AM   #1
Coffeespeed's Avatar
Posts: 17   (View Stats)
Coffeespeed has a spectacular aura aboutCoffeespeed has a spectacular aura about
Default Catch can Catch 22
Just finished the BNR S4 install and E-tuning as we speak. I have read a lot about catch cans for our platform. I would rather not have one if I can help it. If I have to, I will get a MD or JBR and mount it to the transmission to keep it as warm as possible during super cold days.
Are there any big turbo guys currently running without any catch cans? I just don't want to deal with the frozen hoses and frozen can problem during winter months.
Coffeespeed is offline   Reply With Quote
 Old 11-26-2018, 01:23 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Hoses freeze and clog due to improper hose routing.
Freezing in the can is a non-issue unless the can is full.
If your can is full, you're lazy AF. I set the bar for laziness and I can manage to drain my can occasionally.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-26-2018, 04:00 PM   #3
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
A larger turbo creates more crankcase pressure which is too much for the oem pcv system. You need an upgraded pcv system.
read these by @damondmotorsports
https://damondmotorsports.com/blogs/...under-pressure
https://damondmotorsports.com/blogs/...ye-bye-blow-by
breakfasteatre is offline   Reply With Quote
 Old 11-26-2018, 09:04 PM   #4
Mezdee's Avatar
Posts: 7   (View Stats)
Mezdee is on a distinguished road
will check that out
Mezdee is offline   Reply With Quote
 Old 12-08-2018, 08:57 AM   #5
Thanks for the info guys. Damond catch can on the way when he gets back from his vaca. I can always build on to it if I need more.
 Old 12-08-2018, 04:54 PM   #6
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
Although I dont drive my MS6 in the winter, I put a trouble light beside the can when its parked in the garage with a 25W bulb. I get -22s F/-30s C a few times over the winter months. i dont need a frozen can if I need to pull the car out of the shop. Thats a cheap option, but you would need to remove it before driving.
I would look into a low wattage heating pad...
https://www.amazon.com/dp/B079GBWVDX...ding=UTF8&th=1
like a block heater, this might keep the can warm enough to stop freezing solid. This would be a more permanent solution and could be plugged in like a block heater. Most cars here have block heaters, I have the one in my winter car on a timer. It turns on 2 hours before I leave for work. I also have a space heater mounted under the dash connected to the same connection as the block heater cuz Im a cold weather pussy
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 12-12-2018, 04:20 AM   #7
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
What are the symptoms of the can/line being frozen? I have a DM stage 1 can routed by the horns, my car is my daily driver and it gets cold as hell here in Massachusetts, my car has been running fine. unless I'm not paying that close attention..
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
Dual catch can vs catch can and breather cap MSP611 MazdaSpeed 3/6 - Turbo Induction 30 07-05-2015 01:40 AM
Oil Catch Can dannyboy1234 MazdaSpeed 3 - Engine, Transmission & Driveline 9 06-23-2013 11:55 AM
catch can... and nothing etant333 MazdaSpeed 3 - Engine, Transmission & Driveline 28 09-02-2012 02:12 AM
Page generated in 0.28487 seconds with 25 queries
