 Old 08-10-2017, 04:25 PM   #1
aackthpt's Avatar
Posts: 1,450   (View Stats)
The fix for the CEL is way easier than the fix for the timing chain noise. There might be some cleaning stuff you can do to alleviate the problem but most people replace the chain, tensioner, and lots of other things. Your question about the CEL, though, leads me to believe you haven't done much mechanicking and if that is the case you need to pay someone to fix that. When you get quotes don't let someone tell you that you only need to replace one part or some shit, make sure they are going to switch all these parts in this kit: Mazda OEM VVT Replacement Kit Mazdaspeed 3 / Mazdaspeed 6
If you car is eligible for the PCV fix you should have gotten that done which probably includes the new valve cover that helps/fixes this issue. I'm not sure if you can still get it done...
2013 'speed3, silver
Stage Bro
Last edited by aackthpt; 08-10-2017 at 04:25 PM. Reason: MSF Database - Automerged Doublepost
p0126 Thermostat and revs at idle jonathan732 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 04-01-2016 06:25 PM
P0126 fixes dubunderpar MazdaSpeed 3 - Engine, Transmission & Driveline 17 11-12-2015 01:16 AM
P0126 keeps popping up furinax MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 11-08-2015 08:32 PM
Code P0126 without symptoms? What's this? DARK_SIDE Mazdaspeed3/6 General Discussion 1 11-23-2013 07:56 PM
a/c probs with dtc p0126 and p0128 leejustin80 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-16-2012 01:45 AM
Page generated in 0.22962 seconds with 21 queries
