 Old 08-30-2018, 08:58 PM   #1
jtimms6's Avatar
Posts: 22   (View Stats)
jtimms6 is on a distinguished road
Update: so I went and put in 4 new plugs looked like they haven’t been changed in a long while cylinder 1 looked the worst gapped them to .30 iridium plugs also cleaned the MAF sensor when I did the intake drive about 60 miles today and never had that problem come back even after the car sat for a couple hours and was cold which is when I was noticing it the most so hopefully that’s another problem solved thanks for the help!
A follow up question however noticed two things first thing was I noticed that the most boost I get is around 14.5-15 but the tune says target is 16.5 is that normal for stage 1+ tune with a cai or should I be looking for something like a small boost leak? Also realized there was some oil on the cold side of the inter cooler not tons of oil but there was enough that I could see it inside the coupling to the throttle body...once again is that normal from an older car or should I be saving to get the turbo rebuilt? Thanks any advice would be appreciated!
jtimms6 is offline   Reply With Quote
The Following User Says Thank You to jtimms6 For This Useful Post:
Db09ms3 (08-31-2018)
A weird end to a weird F1 season | 2016 Abu Dhabi Grand Prix recap Haltech Automotive News 0 11-28-2016 07:30 AM
Bucking off-throttle Speed2006 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-30-2015 07:17 PM
Car is bucking JAGspeed6 MazdaSpeed 3/6 - ECU Computer Tuning 11 11-17-2013 03:58 PM
car bucking after 5000rpm Rich990 2010 MS3 - ECU Computer Tuning 16 11-07-2012 10:42 AM
Car bucking/jerking with ECT less than 140* bmylez MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 03-13-2012 10:14 AM
Page generated in 0.22534 seconds with 21 queries
