 Old 09-27-2019, 02:10 PM   #1
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
Also check to see that the firewall or clutch pedal bracket haven't cracked.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
The Following User Says Thank You to SyntheticAtmosphere For This Useful Post:
meicalnissyen (12-14-2019)
 Old 09-30-2019, 07:46 AM   #2
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
That is a good point, some had the problems with aftermarket PP and a speed6....
even if he confirmed the fork travel it may miss few mills because of that....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 12-14-2019, 01:05 PM   #3
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
dig abit
the mechanisim is held to the firewall with some spot welds.
it is overkill, but you will save chasing your tail if you have someone looking at the slave/master/and pedal mechanism WHILE you press the pedal.
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
Clutch Masters Twin Disc Clutch Kit now Available at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 67 03-17-2015 03:39 PM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 05:07 AM
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 05:53 PM
Page generated in 0.24951 seconds with 23 queries
