 Old 12-16-2019, 03:44 PM   #1
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
i expect you would need to be 2 of course or try to inspect it from the floor by using your hands to press it as best as you can.....
i never experiences it myself but i did saw some pictures of broken pedal mechanism in this forum after installing harder pressure plate on speed6...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
Clutch Masters Twin Disc Clutch Kit now Available at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 67 03-17-2015 03:39 PM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 05:07 AM
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 05:53 PM
Page generated in 0.22438 seconds with 21 queries
