![]() | | #41 | ![]() |
![]() Join Date: May 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 417
| Not Ranked : 0 score
__________________ '02 Bmw 330ci Kinda low and really slow. '94 Mazda Protege -SOLD 1.8 BPT Vf10 263whp 258wtq 13.1 @ 107 mph '05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come |
| The Following 2 Users Say Thank You to Ace Protege For This Useful Post: | Code Monkey (05-25-2013), Miltron (06-26-2013) |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score to be honest, the trunk is somewhat light to begin with. heavy, yes, but iirc SUMark said a CF trunk wasn't much lighter than the stocker.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
| The Following User Says Thank You to jroc For This Useful Post: | Code Monkey (05-26-2013) |
![]() | | #43 | ![]() |
![]() Join Date: Dec 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 966
Groans: 127
Groaned at 24 Times in 17 Posts
__________________ 2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna FreekTuned ![]() | |
| The Following User Says Thank You to blackmicamps6 For This Useful Post: | Code Monkey (05-26-2013) |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am keeping the crash bars. It was just speculation on my part how light the MS6 could possibly get if you went all the way.
![]() | | #45 | ![]() |
Groans: 127
| Not Ranked : 0 score gotcha... maybe a lighter weight crash bar setup is possible while still retaining safety?
![]() | | #46 | ![]() |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
![]() | | #47 | ![]() |
![]() Join Date: Nov 2010 Location: Benbrook, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
Groaned at 18 Times in 14 Posts
| Not Ranked : 0 score And you need those coilovers!
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch |
| The Following User Says Thank You to aggierandy For This Useful Post: | Code Monkey (05-26-2013) |
![]() | | #48 | ![]() |
| The Following User Says Thank You to Code Monkey For This Useful Post: | SLOWHATCH (06-06-2013) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score Made a little bit of progress today. We measured the seating position and finalized the rear doors. Turns out there is a neat way to keep the rear windows shut without welding any brackets or using turnbuckles and it is still trivial to remove the window in case it gets shattered. ![]() The yellow circle shows where the window connects to the power window regulator. Take the regulator and motor out, hike the glass all the way up and drill a hole in the door such that you can hold the glass in place with one long screw and a few washers. The blue circle show another screw we put in just in case the first screw fails for some reason and the glass comes down. The blue screw will stop the window right there rather than the window slamming all the way down. ![]() Finally, cut off the piece from the inner trim ("rear door unit carrier" in the shop manual) so that you can still open the door from the inside. I think the final look is pretty clean. ![]() The total weight reduction is 11 lbs per door: 5.5 outer trim 1.8 motor & regulator 1.8 speaker 1.9 inner trim
| The Following 5 Users Say Thank You to Code Monkey For This Useful Post: | ABQ Speed6 (12-21-2013), aggierandy (06-04-2013), blackmicamps6 (05-26-2013), Fonsi (09-27-2015), SLOWHATCH (06-06-2013) |
![]() | | #50 | ![]() |
Groans: 127
| Not Ranked : 0 score loving each update.
![]() | | #51 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score Going to have to gather all these weights and put them on my weight reduction thread if you don't mind me doing so.... Good work i am already at 3370 with all my interior in an and without i am down to 3250.... So with some of this weight reduction along with what little i have done i should be close to the low 3100s!!!
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | Code Monkey (05-28-2013) |
![]() | | #52 | ![]() |
(Thread Starter) | Neutral : -1 score
| The Following User Says Thank You to Code Monkey For This Useful Post: | qtrmile beast (05-30-2013) |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Seat brackets are done! Here's what a mounted driver's seat looks like! We also got the main hoop bent into a proper shape. To be continued tomorrow....
| The Following 5 Users Say Thank You to Code Monkey For This Useful Post: | El_Diablo (06-01-2013), FistPump20fo7 (08-03-2013), jroc (06-01-2013), qtrmile beast (06-04-2013), SLOWHATCH (06-06-2013) |
![]() | | #54 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score Make sure the seat brackets are tied into the main hoop. In multiple locations if possible. How are you dong the door bars, NASCAR style or uninterrupted X with intrusion hoops?
__________________ www.MOTOIQ.com Beater Titan |
| The Following User Says Thank You to Todd98SE For This Useful Post: | Code Monkey (06-01-2013) |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score No idea yet but I am pretty sure my cage welder knows what he is doing.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Todd98SE (06-01-2013) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cage is finally starting to resemble cage... No idea why it is attaching upside down. Edit: Fixed the upside down pictures. The driver's seat bracket has three holes so the seat will be "adjustable" -- that is, you unbolt it, move a notch, bolt it down.... The passenger's seat bracket has only one hole so the seating position will be fixed.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 06-03-2013 at 07:27 PM. |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Sturdy cage didn't even dent the roof when you flipped t over to button up!
| The Following 5 Users Say Thank You to Easter Bunny For This Useful Post: | aggierandy (06-03-2013), ArmanRus (06-03-2013), Code Monkey (06-03-2013), CorkSport (06-04-2013), El_Diablo (06-03-2013) |
![]() | | #58 | ![]() |
![]() Join Date: Nov 2012 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15,426
| Not Ranked : 0 score Mindblown
__________________ 2006 Velocity Red MazdaSpeed 6. JBR 80 duro RMM. SURE Aeros SRI. EBC dimpled and slotted rotors. EBC Redstuff brake pads. Leaking Oil Cooler. Broken Rear Diff Casing. Iffy Starter. Banged Up Intake Filter. More performance parts to come once my stock parts quit breaking. [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to edmsmallcash For This Useful Post: | Code Monkey (06-03-2013) |
![]() | | #59 | ![]() |
![]() Join Date: Oct 2011 Location: Syracuse, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
| Not Ranked : 0 score You sir have doomed my ms6's interior. sent from the tapagods
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to dubunderpar For This Useful Post: | Code Monkey (06-04-2013) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score When your done please weigh the car so those that are going to do some of these weight reductions can see where they might end up.. Good job and keep up the good work..
| The Following 3 Users Say Thank You to qtrmile beast For This Useful Post: |
![]() | | #61 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score If you are adding a cage you could go the extra mile and weld in a single cross brace in the trunk and remove those braces and maybe some material if you haven't already Sent from my SAMSUNG-SGH-I727
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
| The Following User Says Thank You to chuckms6 For This Useful Post: | Code Monkey (06-04-2013) |
![]() | | #62 | ![]() |
![]() Yeah, I was thinking about something like this, my welder said it was possible.
![]() | | #63 | ![]() |
Something kinda like this:
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch | |
| The Following 4 Users Say Thank You to aggierandy For This Useful Post: | Code Monkey (06-04-2013), Downmented (06-13-2013), Easter Bunny (06-04-2013), SLOWHATCH (06-06-2013) |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score Jesus, that thing looks heavy.
![]() | | #65 | ![]() |
| Not Ranked : 0 score Its aluminum. Even if I overestimate it at 1.5 mm x 0.5 meters^2 its less than 5 lbs! I'd use like 1.2mm aluminum plate. You can cut it with electric shears typically and maybe even reuse the factory bolts. Because all the load will be in tension, it doesn't need to be very thick. Grab one of these and you can even put your own bead in it: Benchtop Sheet Metal Fabrication Kit Heck, you may even talk to someone like Jamie over at JBR about selling one of these. He could make money on them and they should be cheap once you have the template. Plus, as the MS6 ages, there will be more of them retired to the track.
| The Following 3 Users Say Thank You to aggierandy For This Useful Post: |
![]() | | #66 | ![]() |
| Not Ranked : 0 score That plate would block his down tubes from the top of the main hoop to the rear strut towers. Like this:
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | Code Monkey (06-04-2013), Johnybeas (12-21-2016) |
![]() | | #67 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score A simple sheet like that works great without adding much weight at all. Even if you drill holes for the down tubes the function is still there. You can also use it as a firewall if the rule book mandates one between the trunk and passenger compartment. When you look at that sheet think about those DIY shelves that you nail the thin piece of cardboard to. its that Cardboard that holds the shelves up, otherwise they would parrellegram with the slightest side force.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following 3 Users Say Thank You to El_Diablo For This Useful Post: |
![]() | | #68 | ![]() |
| The Following User Says Thank You to aggierandy For This Useful Post: | Code Monkey (06-04-2013) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score BTW that cage is WAY more intricate than what he is getting. His down tubes don't cross (I don't believe they do at least). And he doesn't have the 6 way cross behind his seat either.
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score The down tubes can be either crossed or parallel, we chose parallel. We are still undecided on whether we will run diagonal bars there. The main hoop will have a crossbar and at least one diagonal bar going from the driver's side down to the passenger's side, but I will probably have both diagonal bars making it a 6-way cross.
![]() | | #71 | ![]() |
| Not Ranked : 0 score If you are gonna go with a single sheet, it something you probably need to consider immediately. If you have already welded in the down tubes, you're gonna have to use multiple sheets and that isn't ideal for bracing. RapaTapTap
![]() | | #72 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
-Derrick | |
| The Following User Says Thank You to CorkSport For This Useful Post: | Code Monkey (06-04-2013) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score I don't want to derail Code Monkey's thread but it is my old Sentra SE-R. SE-R Photos by todd98se | Photobucket It was a fairly overbuilt NASA/SCCA spec cage, maybe Code can get some ideas from the pics. @Code Monkey; what city are you in? Near Austin?
| The Following 4 Users Say Thank You to Todd98SE For This Useful Post: | aggierandy (06-04-2013), Code Monkey (06-04-2013), Easter Bunny (06-04-2013), Johnybeas (12-21-2016) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Demolition Derby Car? :LOL:
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch Last edited by aggierandy; 06-04-2013 at 01:16 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to aggierandy For This Useful Post: | Code Monkey (06-04-2013), Todd98SE (06-04-2013) |
![]() | | #75 | ![]() |
"Definitely single diagonal brace and harness bar within the main hoop (to make it NASA legal). The X in the main hoop makes the harness bar more complex, but it can be done. You don't need any more bracing to be legal but I was going to do an X on the same plane as the ground from the main hoop to the rear supports. The door bar will hit the hoop at the same point which adds strength to both. If you want a diagonal or X in the rear supports, I can do that in place if the horizontal support. It will cut down on rear visibility and add a little weight, those are the only downsides. I will also be adding 1.5" tubing gussets in 4 spots."
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | ||
| The Following User Says Thank You to Code Monkey For This Useful Post: | Todd98SE (06-04-2013) |
![]() | | #76 | ![]() |
| Not Ranked : 0 score I think the single bar should be sturdy if done right. We ran the bar for the harnesses in to make the X. |
| The Following 5 Users Say Thank You to CorkSport For This Useful Post: | aggierandy (06-04-2013), Code Monkey (06-04-2013), Easter Bunny (06-04-2013), Johnybeas (12-21-2016), Todd98SE (06-04-2013) |
![]() | | #77 | ![]() |
RapaTapTap
![]() | | #78 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
__________________ |
| The Following 7 Users Say Thank You to helmetface For This Useful Post: | aggierandy (06-04-2013), Code Monkey (06-04-2013), Downmented (06-13-2013), Easter Bunny (06-04-2013), El_Diablo (06-04-2013), qtrmile beast (06-04-2013), Roddiy (06-11-2013) |
![]() | | #79 | ![]() |
| The Following 6 Users Say Thank You to Code Monkey For This Useful Post: | aggierandy (06-04-2013), CorkSport (06-04-2013), Easter Bunny (06-04-2013), El_Diablo (06-04-2013), FistPump20fo7 (08-03-2013), helmetface (06-04-2013) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Looking svelte! Its all those reacharounds.
| The Following 2 Users Say Thank You to aggierandy For This Useful Post: | Code Monkey (06-04-2013), TJSpeed6 (06-04-2013) |
| AP went full retard | TriO | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 05-13-2012 07:39 PM |
| Report: 2012 Toyota Prius PHEV to feature selectable EV mode, full regen | Haltech | Automotive News | 0 | 06-15-2011 05:10 PM |
| Ferrari to use full name of racecar after Ford sues over F150 name | Haltech | Automotive News | 0 | 02-10-2011 10:10 PM |
