Like Tree3Likes
  • 1 Post By JSmith
  • 2 Post By Fstrnyou
 Old 09-05-2017, 03:28 PM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Coolant issues
Car regularly​ hits 243 according to the AP, which I'm assuming is the max for the sensor since I've never seen higher? The gauge maxes out sometimes. It always seems to happen once on startup after 5 mins then it's normal. Runs around 200-220 on the highway. Ideas? Thermostat? Could it possibly still be an air bubble since I had the turbo replaced? Or not enough coolant? I'm going to add some when I get out of class tonight but wanted ideas.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 09-05-2017, 06:20 PM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
When was the last time you burped the coolant?
tom10122 likes this.
 Old 09-05-2017, 06:42 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm having mixed emotions responding to your post. I strongly considered ignoring. Maybe I should have.
You "regularly" drive a vehicle that is more or less overheating. Strike One
Your next few questions are legit...then you ask if there's not enough coolant, SMH. Strike Two
Then, why would you add coolant if you don't even know if it needs any (see strike two)? Strike Two and a Half
You're not in high school anymore, apparently. You learn some of these simple things on your first car in high school. Maybe I was one of those many underprivileged kids that had a crap car my first go and had to fix it myself with my own money. Some kids/not kids these days hardly turned a wrench their whole life or even know where the oil goes.
Rant over.
Your coolant bottle has a HOT and COLD line for coolant level.
I've been around this forum for a little while. It was my turn to be a dick. I'm good now
tom10122 and Truguy86 like this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-05-2017, 07:13 PM   #4
tom10122's Avatar
Rant over.
You can be a dick it's fine, doesn't bother me, I wrote this after sitting in city traffic and was nervous.. you do not want to breakdown in Newark NJ. I had a truck that would short and the Temperature gauge would regularly pin itself so I hoped it could be something like that.(also FOMOCO) . If steam wasn't pouring out I kept driving. Never got that far. Right now I'm guessing my mechanic didn't spend much time burping it when the turbo was done as it needed quite a bit of coolant.
And my first car was a 1988 Pontiac.......lots of things needed fixing on that.
 Old 09-05-2017, 07:56 PM   #5
Fstrnyou's Avatar
85 camaro, right there with ya.
When I did my turbo swap, there was air trapped somewhere. Repeatedly squeezed the upper coolant hose while it was running to try and CPR the air pocket out of it.
Youve been driving around at elevated temps but not boiling over, so I think you have flow. You just need to top off the radiator when it's cold and make sure the bottle has plenty in it.
Other rides:
History:
 Old 09-05-2017, 10:24 PM   #6
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
I would get any suspected air out of the system before I drove it again, and then I would change my avatar.
94 M
MS6
IS350
 Old 09-06-2017, 05:38 PM   #7
tom10122's Avatar
Added half a gallon and tried to burp it some, huge improvement. No longer returning to that mechanic.
Coolant temp issues dubunderpar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 01-26-2016 07:55 PM
P0126 / coolant, over cooling issues jcraig21 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 04-13-2015 09:16 AM
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
Coolant Flush issues usafvmi08 MazdaSpeed 6 - Engine, Transmission & Driveline 2 02-17-2014 07:57 PM
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 02:39 PM
Page generated in 0.28819 seconds with 23 queries
