  • 1 Post By rfinkle2
 Old 04-15-2011, 10:12 PM   #1
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
Default Corks Sport Turbo Inlet pipes
I am looking to get a Inlet pipes and noticed Corksports in only $99 on their website. It comes with a silicone valve sleeve and you can have it Pc'ed black. But if you look at the other brands. SURE $179. CP-E $199, COBB $169 but they all have a silicone covering the entire pipe which, Corksport does not. Has anyone had any problems with the Corksport or should i just spend the extra on SURE? Not that it makes a difference but i do have a SURE SRI.
Thanks for the any input and Sorry I suck with the search. For some reason it just pulls a bunch of threads im not looking for. And I know its on my end! Sorry but still could use some good advice!
Thanks
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
 Old 04-15-2011, 10:27 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i don't even know where to start...
ummm...
pipe*
 Old 04-15-2011, 10:31 PM   #3
Mikey's Avatar
Groans: 104
lol sorry typing one handed with kid on my lap... Didn't have time to re-read before posting but you know what i mean!
2007 Cosmic Blue
 Old 04-15-2011, 10:36 PM   #4
phillyb's Avatar
Groans: 1,940
metal - more sound
silicone - flexible - sometimes fits better
 Old 04-15-2011, 10:38 PM   #5
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Go with CorkSport.
rfinkle2 (04-16-2011)
 Old 04-15-2011, 10:39 PM   #6
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
If you don't already have an intake, just get the whole SRI from Corksport, comes with the TIP, and is a good package deal.
The Following 2 Users Say Thank You to wolly6973 For This Useful Post:
BigjohnB20 (04-16-2011), rfinkle2 (04-16-2011)
 Old 04-15-2011, 10:43 PM   #7
08.5MS3's Avatar
Groans: 89
He has the SURE intake.
 Old 04-15-2011, 11:13 PM   #8
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
I have the CS intake. The only thing I wonder about is the size of the pipe. It's pretty narrow, something like 2 inch diameter. Not sure if it makes that much of a difference, but I'm pretty sure the other brand's TIPs are larger diameter.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
Mikey (04-16-2011)
 Old 04-16-2011, 12:14 AM   #9
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
They are all large enough for the stock K04. Have you SEEN the size of the inlet on the stock turbo?
EDIT: BTW, I'm running a CS TIP.
Mikey (04-16-2011)
 Old 04-16-2011, 02:06 PM   #10
Mouse's Avatar
Posts: 24   (View Stats)
Mouse will become famous soon enoughMouse will become famous soon enough
I have the CS tip and I like the fact that it is made of metal with the metal vacuum nipples. The t-bolt clamps were the worst part of the install. You may also want to clean out the pipe before the install(mine had some little metal specks all over inside). It sounds great and seems to make the car run smoother.
Mouse is offline   Reply With Quote
The Following User Says Thank You to Mouse For This Useful Post:
Mikey (04-16-2011)
 Old 04-16-2011, 02:24 PM   #11
Here is the skinny on TIP's.
The Corksport is available in 2 configurations, one with the valve cover vent located on the TIP and one without (like other manufacturers) and has a stock mounting point.
Sure and Cobb are silicone, but lack the factory mounting point.
CP-E is a true 3" silicone inlet with a factory mounting point.
(you will want to choose the smaller of the 2 intake options if you do not have a CP-E intake (Sure in your case)). It will then come with a 3" to 2.5" adapter.
08.5MS3 (04-16-2011), Mikey (04-16-2011)
 Old 04-16-2011, 02:28 PM   #12
08.5MS3's Avatar
Groans: 89
Get the configuration with the valve cover vent. The new TSB for smoking turbo's has the TIP with this. Just a preventative measure.
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
Mikey (04-16-2011), rfinkle2 (04-16-2011)
 Old 04-16-2011, 02:32 PM   #13
This^
08.5MS3 likes this.
 Old 04-16-2011, 07:37 PM   #14
Mikey's Avatar
Groans: 104
Yea that is the one i want for $99. Just wanted to make sure since the price was so different that it was a good product! Thanks everyone for your inputs!
2007 Cosmic Blue
 Old 04-19-2011, 08:16 PM   #15
efispeed's Avatar
Posts: 79   (View Stats)
efispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant futureefispeed has a brilliant future
i haz cp tip, its great quality and price. cant go wrong. make sure you get the right version. if your intake has a recirculation hoes you need to get the tip without one.
2006 mazdaspeed 6 grand touring
turbo
efispeed is offline   Reply With Quote
Heffner Twin-Turbo Audi R8 V10 pipes up Haltech Automotive News 2 04-09-2011 09:43 PM
Smoking Turbo + Oil in FMIC pipes xcoldricex MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-19-2010 10:22 AM
COBB Turbo Inlet vs CP-E Turbo Inlet Turok MazdaSpeed 3/6 - Turbo Induction 13 04-22-2010 09:07 AM
Page generated in 0.35144 seconds with 28 queries
