Like Tree12Likes
 Old 12-03-2012, 09:11 AM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default Corksport / ETS / CP-E TMIC before/after logs - got 'em, post 'em
There seems to be a void here. At large, all I can find for a before/after on these intercoolers is 'my car spools faster now' or 'the car pulls harder at 4k now' and other gratuitous data. I can't find any good datalog references to quantify, analyze and compare these TMICs. Given enough datapoints, we should be able to reasonably compare these intercoolers. As it stands, they are all hunks of metal, pretty much similar in size and function and maybe they are all one in the same performance wise.
The before/after datalog history is pretty thin for these TMICs given all of the cars that I see with them installed in peoples' sigs. I am hoping to compile a resource of before/after datalogs from a TMIC swap. I am hoping with enough data that we can find some trends and see what the differences are (pros, cons) between these top mounts. I am sure a bunch of you ran before/after logs to capture the gains.
I am personally leaning towards the Corksport because I really want to reuse my stock shroud, but I won't sacrifice performance for aesthetics. There just isn't enough hard data to convince me to support one over the other right now.
The more data we get, the more compelling analysis we can do.
The Following 12 Users Say Thank You to dale_gribble For This Useful Post:
Chicagospeed6 (12-03-2012), Dimenus (12-19-2012), Dr. Speed (12-31-2012), El_Diablo (12-20-2012), J.Dy (12-05-2012), jack_hammer (03-18-2013), Keko (12-19-2012), mituc (07-19-2015), MS3G35 (12-19-2012), Pointless (12-03-2012), rolanblack (12-26-2012), spals (06-26-2014)
 Old 12-19-2012, 03:28 PM   #2
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Bumpity. Still running the stock TMIC so I can't contribute, but I'm interested.
2012 Velocity Red Mica
 Old 12-19-2012, 03:32 PM   #3
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Installed ETS TMIC, but I did it at the same time as Test Pipe, Internals, and Stage2 OTS.
FWIW, I can't tell a difference in BATs, but I also didn't monitor them with an Interceptor when I had stock TMIC. I'm sure it flows better, but I wasn't able to get a before/after to check actual results.
2012 MS3
Stratified 91
 Old 12-20-2012, 02:58 PM   #4
sidekick's Avatar
Posts: 3,093   (View Stats)
I'll look for my logs when I get home, but the only difference I really noticed was lower BATs and I had to decrease my WGDC by about 10-15% across the board. I think it mainly allows the turbo work less to produce the same boost, because there is less pressure drop.
Fail_6 (07-04-2013), Pointless (12-21-2012)
 Old 12-20-2012, 05:14 PM   #5
Ok, here is my official Street Unit TMIC v. STOCK TMIC results. The Street Unit TMIC did provide solid gains for my car. The gains are pretty clear and quantified.
For similar intake air temps (shown in the table below), the SU TMIC keeps BATs at bay down much better to redline, by 10-15 degrees from 4500RPMs on. These cooler temps are a little more dense and allow the car to hold a little more timing which gives a nice performance boost from 4500RPMs on. I observed +12 HP from 4700RPM to redline with the Street Unit TMIC over the stock TMIC.
This also provides a good understanding of what an aftermarket TMIC does and what it doesn't. As you can see, the SU TMIC doesn't impact low end torque really at all and it shouldn't be expected to. Nor does the SU TMIC necessarily reduce BATs when cruising on the highway or partially hitting the throttle to pass a car. The SU TMIC (like all other aftermarket TMICs) is meant to better cool the air when a large volume of air is passing through the unit. Otherwise, at lower air volumes, the TMIC doesn't cool any better then stock. As a matter of fact, you can see that the Stock TMIC ran cooler BATs up to about 4k RPMs. The stock TMIC is more efficient at a lower air volume. Interesting, right?
So, to summarize, what an aftermarket, and in this case SU TMIC does:
Reduces BATs under WOT from 4k to redline
Holds higher boost
Looks cool
Cooler air gives power gains and allows for more timing above ~4500
What an aftermarket, i.e. SU TMIC does NOT do:
Cooler BATs at idle
Cooler BATs at partial throttle
Cooler BATs below 4k RPMs
Prevent heat soak at idle
These are things that I learned screwing with intercoolers over the last 8 months or so. I hope this information is helpful. I will soon be posting a SU TMIC v. my CX Racing FMIC comparo soon too. That one is kind of a mind fuck. Hint: they work the same.
08.5MS3 and Prodigalson like this.
MINI H1 6.0 - CAR LED TAILS
The Following 18 Users Say Thank You to dale_gribble For This Useful Post:
08.5MS3 (12-20-2012), Amped (12-27-2012), AZSPEED3 (01-14-2013), chomorro (06-17-2013), Dimenus (12-20-2012), Dr. Speed (12-31-2012), El_Diablo (12-20-2012), Fail_6 (07-04-2013), Gitcherex (05-09-2016), ItsNox (07-03-2013), J.Dy (12-20-2012), nycMS3 (12-22-2012), Pointless (12-20-2012), spals (06-26-2014), white'swhiteMPS (06-16-2014), Whitebullet (12-31-2018), yourname2221 (05-19-2014), []V[]addog (08-07-2013)
 Old 12-20-2012, 05:57 PM   #6
If you fegs have before/after TMIC logs, I can nerd em up in excel to share them here.
 Old 12-21-2012, 01:46 PM   #7
Here is the CX Racing FMIC v. my SU TMIC results. For their part, they pretty much performed the same. The CX Racing FMIC showed slightly lower BATs at redline by 5 degrees or so, but the IATs were also about 5 degrees lower, so I think that is about a wash.
The SU TMIC held a little higher boost and timing was equivalent. VD logs showed similar power between the two intercoolers. If you consider that amount of work and hacking that it takes to install a FMIC and some of the headaches, which in my case is difficulty accessing the headlight door, loss of a little throttle response, higher coolant temps, constantly checking like 10 hose clamps and other small nits, the TMIC is a hands down win for me.
The only thing the FMIC did much better than my TMIC which is indisputable to me, is do a much better job at minimizing heat soak.
08.5MS3 likes this.
The Following 13 Users Say Thank You to dale_gribble For This Useful Post:
08.5MS3 (12-21-2012), AZSPEED3 (01-14-2013), chomorro (06-17-2013), Dimenus (12-21-2012), Dr. Speed (12-31-2012), Fail_6 (07-04-2013), Gitcherex (05-09-2016), MS3G35 (12-21-2012), nycMS3 (12-22-2012), Pointless (12-21-2012), r3d (12-29-2013), rolanblack (12-22-2012), Twofer (12-31-2012)
 Old 12-22-2012, 12:40 AM   #8
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
I'm with you, for my needs, a quality TMIC is hands down a winner for me over a FMIC. Constantly checking clamps, having to relocate the washer reservoir, and all the excess clutter all killed it for me and I haven't missed my FMIC for a second since I replaced it with my ETS.
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
The Following User Says Thank You to razorscs For This Useful Post:
mzr0818 (12-22-2012)
 Old 12-25-2012, 10:50 PM   #9
sidekick's Avatar
So here are two different Virtual Dynos showing the Stock TMIC vs Corksport TMIC. I attached the logs at the bottom. I can't say how much of a difference it really made in HP/TQ, due to them being virtual dynos, but you can see I picked up about 1-2PSI of boost.
The Following 3 Users Say Thank You to sidekick For This Useful Post:
chomorro (06-17-2013), dale_gribble (12-26-2012), Twofer (03-17-2013)
 Old 12-26-2012, 05:50 PM   #10
One thing missing from your logs is intake air temps. Do you log those? Those come in handy when baselining datalogs from different runs.
 Old 12-26-2012, 06:00 PM   #11
FWIW, IM & TB TIGs, EGR delete, and TB coolant reroute dropped my BATs by 20 degrees on average, something you may want to look into in addition to an upgraded TMIC.
 Old 12-26-2012, 06:16 PM   #12
@boost_addict
I stacked up some data from your logs. There is one thing I am seeing here; Either you ran logs in higher outside temperatures when the Corksport TMIC was on vs. the stock TMIC or the Corksport doesn't cool BATs any better then stock... No reduction in BATs = no cooler air = no increase in timing = basically no power gains. Were your logs run in the same conditions, same outside temps?
 Old 12-26-2012, 08:43 PM   #13
sidekick's Avatar
@boost_addict
One night was 60 degrees and the other was 61. It was on the same stretch of road as well. I noticed that too though. I'm not sure why they didn't drop. It may have been more heat soaked to begin with or something, unfortunately I didn't log IATs.
 Old 12-26-2012, 09:20 PM   #14
Here's a "comparison" between stock TMIC and 3.5" ETS TMIC.
The OEM TMIC logs were taken 19jun2012 while I was in the middle of the freektune. Then my clutch failed and the ETS logs were taken 18aug2012, still in the middle of the freektune.
On average, the temperatures were similar across the two logs but the variation in temps was lower with the ETS IC.
OEM summary:
Code:
. su IAT BAT if APP > 99
    Variable |       Obs        Mean    Std. Dev.       Min        Max
         IAT |        60      135.74    6.519259      127.4      145.4
         BAT |        60    149.8055     4.00124     145.62     160.25
ETS summary:
Code:
         IAT |        62    132.7129    4.279822      127.4        140
         BAT |        62    149.5627    2.629695     146.75     154.62
The common theme is that most of the time the BATs follow a U curve - they drop as you start moving, flat line for a wee bit, then shoot up as you pass 5000 rpms. The ETS IC is a bit more efficient than stock at reducing the BATs on the initial move, extends the flat line to about 5500 rpms, and prevents the BATs from climbing as high as the stock IC. This behavior is consistent over many, many logs I have taken.
Do not take the attached logs as gospel, each was an unfinished tune.
dale_gribble (12-27-2012), MS3G35 (12-27-2012), Pointless (12-26-2012), r3d (12-29-2013), rolanblack (12-27-2012)
 Old 12-27-2012, 10:01 AM   #15
rolanblack's Avatar
Posts: 2,110   (View Stats)
At one point i thought fmic was the way to go. Reading and seeing that tmic is actually better for the k04. Ever considered sealing the intercooler duct better then taking some logs to see the amount of air we all in general lose with the tmic and see it gives better readings with stock vs aftermarket
 Old 12-27-2012, 10:25 AM   #16
Based on some experiments I have run with my old CP-E TMIC and this SU TMIC, I haven't seen a single gain from playing with the duct to intercooler sealing.
 Old 12-27-2012, 05:22 PM   #17
rolanblack's Avatar
Bummer dude. I thought that would play a part. I pushed on the seal and noticed the outer leftover seal overlaps creating maybe 3-6mm gap.
 Old 12-28-2012, 10:56 AM   #18
ryceboi's Avatar
Posts: 17   (View Stats)
ryceboi will become famous soon enough
here's mine from 2006 logging with AutoEnginuity (pre-AP, which is why there are so few data points)
stock TMIC w/ AEM cai (91 octane):
IAT = 68F constant
rpm boost AFR BAT
2500 2.32 14.5
2900 9.27 -----
3000 ---- 13.14 96.1
3300 16.24 12.45
3600 ---- 10.61
4000 16.52 10.26 92.6
4300 ----- 10.26
4700 16.09 -----
5000 ----- ----- 90.5
5100 ----- 10.03
5350 15.08 -----
5400 ----- 9.8
5860 10.15 -----
6000 5.51 ----- 89.4
ETS 3.5" TMIC w/ AEM CAI (91 octane)
IAT = 69F constant
rpm boost AFR BAT
3000 2.61 13.95 111.9
4000 16.68 11.64 89.4
4900 ----- 10.72
5000 15.37 ----- 89.4
5300 ----- 10.5
5700 ----- 10.5
6000 14.79 -----
I probably need to log again with the AP, but now I have different mods so it won't exactly be apples to apples, nor do I want to unbolt everything.
My takeaway from the ETS is that the pressure differential across the core was much less than the stock TMIC, probably due to the bar/plate vs. tube/fin design. Thus, the volume pre-throttle remains at a higher pressure/boost during high flow/rpm.
The other benefit of the ETS is the heat transfer efficiency. With the stock TMIC, it takes longer for the BAT to lower to 89.4F while the ETS shot down quickly even with heat soak. The bar/plate and core size come into play here. More surface area means greater heat transfer rate. The same works for brake rotors.
Funny thing is I did not see the parabolic curve for BAT you all did even with the stock TMIC. I'll log again on my current setup with the AP just to see if that still is the case.
Last edited by ryceboi; 12-28-2012 at 11:06 AM. Reason: oops, formatting didn't quite work
ryceboi is offline   Reply With Quote
 Old 12-28-2012, 07:41 PM   #19
Yatta's Avatar
Posts: 1,862   (View Stats)
It's just a thought, but wouldn't reducing restriction reduce low speed thermal transfer? I believe all of these cores flow better than stock, this should reduce the load on the turbo for a given pressure level, increase low speed bats and decrease high load bats. , assuming the new cores have more thermal mass. Has anyone weighed them?
I've been planning on replacing the stock tmic solely to gain the head room that the decrease in pressure drop that will occur and the ability to go above the boost levels that Mazda intended for the stock core.. Will be following this thread, thanks!
But it isn't respectable. It's mildly terrifying. And that actually makes it quite appealing. - Mazda 3 MPS review, Matthew Jones, Top Gear.
 Old 12-28-2012, 09:04 PM   #20
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
I wish I could find the thread, but someone posted this up today:
Spearco - All About Intercooling
Sub'ing for great info, thanks!
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
The Following User Says Thank You to Hush For This Useful Post:
dale_gribble (12-28-2012)
 Old 12-31-2012, 09:30 AM   #21
ryceboi's Avatar
You're both right and wrong here. The reason for the high BATs at low RPM are due to heat soak. Efficiency works both ways - cools down faster, heats up faster. Obviously, vehicle speed means more flow across the cooling fins and less heat soak.
The internal core restriction, however, does not necessarily contribute. This would only be a factor if all intercoolers are made equal and the only difference would be pressure differential. Higher pressure differential means higher temperature differential. Higher temperature diff, higher heat transfer rate. But the intercoolers are different so efficiency comes into play and internal restriction has little effect on the equation.
Someone had weighed the cores once, but that thread is buried somewhere. My arm scale says aftermarket cores are at least 2x heavier than OEM.
 Old 12-31-2012, 09:57 AM   #22
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I fully agree, the corksport TMIC and the CP-E TMIC weigh more than the OEM by a couple of pounds.
I will have to dig through my log files tonight to find good clean runs but I do have logs of OEM vs Corksport vs CP-E that were taken within a two week period with temps being +/- 7* outside. The only main thing I noticed is that the idle/cruising temps were about the same but at WOT the BATs dropped a lot quicker along with better heat soak recovery from idling.....of course this is all to be expected given that is the whole point of an aftermarket TMIC.
My uneducated opinion is anyone with a K04 should be happy with a TMIC but if you are BT or plan on going BT in the near future you should save your clams for a FMIC. It's all about your future plans and putting the money in the right areas. K04 people could put that extra $200 or more towards meth, better tune, beer, etc.
rolanblack (01-02-2013)
 Old 01-14-2013, 06:54 PM   #23
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
If you're looking to compare cooling efficiency wouldn't you want to plot Delta T (BAT - IAT) over the entire rpm range in the same gear? HP is irrelevant because everyone's tune is different, but the smallest temp rise should be best, assuming all aftermarket TMICs let the K04 breathe as best as it can.
Oni is offline   Reply With Quote
The Following 2 Users Say Thank You to Oni For This Useful Post:
Keko (01-14-2013), texasboy21 (04-10-2015)
 Old 01-14-2013, 09:24 PM   #24
Yatta's Avatar
Hp isn't that important..... But...
Pressure drop inlet to outlet at an airflow rate, with a delta in temps...
Watching HP sometimes will infer airflow
You also need to know the temp of the cooling air going through the IC and how much...
 Old 01-15-2013, 09:36 AM   #25
Oni
Oni's Avatar
It's a simple engineering mass balance, only problem is you'll never have enough variables known, so you have to assume some things. (we're vehemently agreeing I think)
Yatta likes this.
 Old 03-13-2013, 01:34 PM   #26
Here's an interesting data piece.
I ran the SU TMIC for a few months (pre SU drama) and due to some fitment issues of that TMIC on my car, I sent the SU TMIC back to SU for analysis/repair. I decided to go ahead and pick up a CS TMIC in the meantime. I figured I would get test data, and depending on which TMIC performed better, I would sell the other when the repaired SU TMIC comes back. Aftermarket TMICs are not hard to sell and don't devalue much (of course that was pre-SU/SURE drama).
I will say that the CS TMIC is aesthetically much more pleasing when the stock shroud is on. The fit is also very good; I didn't have any of the mechanical fitment issues I had with the SU TMIC. The SU TMIC is a little uglier and in my case, the fitment wasn't very good which I am expecting to get remedied by SU. In the end, it comes down to how does the TMIC perform, and I was in a rare position to do an apples to apples performance comparison that I wanted to share.
Both TMICs flowed the same as measured by airflow readings and equally held boost. Both TMICs are superior to the stock TMIC in this capacity. Both TMICs did a pretty equal job of shedding heat soak although I think the SU TMIC shed heat soak a little faster.
The key takeaway here is in the IAT v. BAT between intercoolers. I had a suspicion that the SU TMIC ran cooler and was better at shedding temps in around town driving. I finally got a chance to stack logs and my suspicion was confirmed. The SU TMIC pulled BATs lower and held them lower by 5-7 degrees F through the entire pull, when IATs were the same (within 2 degrees).
I can say with some level of confidence, that based on this quantified data point and my empirical experience that the SU TMIC does a better job at cooling than the CS TMIC.
What does the lower BATs mean exactly for performance? I don't exactly know what 5-7F in lower BATs mean for our cars. It could be in the noise as far as I know. I'll let the experts discuss that.
Dimenus (03-13-2013), Dr. Speed (03-13-2013), El_Diablo (03-13-2013), J.Dy (03-13-2013), jseams (03-13-2013), rymanmazda (11-12-2013), scubasteve711 (03-13-2013), Skyman88 (05-19-2013)
 Old 03-13-2013, 05:57 PM   #27
So, we still need some recent before/after data for the CPE and ETS TMICs. Someone has to have recent AP data for these comparisons to round this thread out.
 Old 03-18-2013, 05:20 PM   #28
sidekick's Avatar
The 4th gear logs I took last night show about 10WHP higher with 10° cooler ambient temps/BATs, so lower BATs make a pretty substantial difference.
dale_gribble (03-18-2013)
 Old 07-03-2013, 03:04 PM   #29
chomorro's Avatar
Posts: 667   (View Stats)
chomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the world
I have all bolt ons running a oem tmic and just recieved an ets tmic in the mail. I would like to contribute to this thread. What logs would you like me to take tomorrow with the the stock and then the ets?? I mean what ap log parameters?
Its going to be hot as heck out tomorrow during the day and i will be running strictly cobb ots map stage 2. I was planning on running the same map stage 2 91 octane for upgraded internals and just resetting the ecu after the tmic install to see a more direct comparison instead of changing the map to stage 2 91 octane hpfp intercooler.
Cheers hope this helps someone out. I wanted a cobb/tr8l fmic but im saving a few more dollars and if this tmic works out great no reason to change.
2009 Subaru WRX STI Hatchback
2007 GTI - Package 2 w/ Nav - Dieselgeek Short Shifter / TWM Weighted Etched Shift Knob / AWE 2.5" Turbo Back Exhaust w/Metal Cat / APR Stage 2+ Tune / APR Flapper Delete / APR HPFP / Vogtland 2" Springs / R8 Coils / NGK Iridium / P3Cars Digital Vent Gauge / 18" OEM Detroit Rims (SOLD)
2007 Speed 3 - Stratified Tuned with bolts ons (SOLD)
chomorro is offline   Reply With Quote
The Following 3 Users Say Thank You to chomorro For This Useful Post:
Code Monkey (07-03-2013), cshunter (07-03-2013), jtt (07-04-2013)
 Old 07-03-2013, 03:37 PM   #30
sidekick's Avatar
Boost, IAT, BAT and RPM are the only ones that really matter for this testing, so just make sure those are included.
 Old 07-03-2013, 04:21 PM   #31
chomorro's Avatar
ok will do. I only have a mac so no virtual dyno. What parameters do you need for that so someone can input that as well with my logs.
 Old 07-04-2013, 11:40 AM   #32
Just log everything and we'll pull out what we don't need.
Thanks for doing this.
 Old 07-04-2013, 03:22 PM   #33
chomorro's Avatar
I really underestimated the 4th of july traffic i tried many times in different spots to get a clean 4th gear pull but couldnt pull it off . I could only get to about 5000 5500 rpm before something was in front of me. Here is what I got, sorry guys.
Amb 86-89 logs are two 4th gear pulls but not all the way until redline. One log just freeway cruising, and one log idling for 5 minutes and letting it heat soak then pulling off to 35mph for a bit.
Now im going to install the ETS, and attempt the same stretch of roads and log it.
 Old 07-05-2013, 04:04 AM   #34
chomorro's Avatar
Amb was much cooler on these logs 77-83.
Next up partial 4th gear pull same road didnt get to redline. One log freeway cruising, and one log idle 5 min then go to about 35mph.
One thing i noticed with heat soak is sitting in the drive thru with oem bats would go as high as 171 i noticed and when idling almost the same amount i got to about 151 with the ets but it took longer it seemed, hard to tell since the amb was 10 degrees cooler.
 Old 07-09-2013, 04:29 PM   #35
ilias's Avatar
Posts: 335   (View Stats)
ilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the world
Groaned at 9 Times in 2 Posts
Any updates>? Thinking to get CS TMIC
Cobb AP V3 // CPE HPFP // CS Downpipe // CS Coilovers // CS Rear Camber Arms // CS SRI and TIP // CS Oil Catch Can // CS RMM & TMInsert //
JBR RSB, Short Shift and bushing // Turbosmart BOV // NGK one step colder // ETS TMIC // STRATIFIED //
ilias is offline   Reply With Quote
 Old 06-13-2014, 06:24 PM   #36
Good news bitches. Just got an ETS TMIC. I'm going to say, the thing is visually impressive. What I noticed first is how dense this thing is, both in terms of bars and fin density. It's much more dense than the SU or CS. For example, on a SU, I can see my hand through the cooling fins. On this guy, the fins are so dense and staggered that I can't see the other side. This has 19 flow channels and 19 rows of fins. The Corksport has 15 flow channels and 17 rows of fins, the SU 16/18.
Here's the CS and SU TMICs (CS left, SU right).
Here's the ETS. You can see how instead of the fins bent in a z pattern, the fins are squared and much tighter.
Now it's tough to say how it translates; but the fin/bar density is a very notable difference compared to the other 2. It's also a .25" taller core. My gut says it will cool better than the other two under boost and probably have a little more trouble shedding heat soak. Flow will probably be about the same, maybe a bit better, who knows.
Expect SU vs. ETS data in the next couple of days.
ItsNox likes this.
5LOWMS6 (06-13-2014), allo80 (06-13-2014), ItsNox (06-15-2014)
 Old 06-13-2014, 06:31 PM   #37
Here's the ETS inlet and outlet; small details like chamferred and stuff. This thing shows a great attention to detail from an assembly perspective.
 Old 06-13-2014, 07:27 PM   #38
shadesofgray19's Avatar
Posts: 794   (View Stats)
I don't know that a more dense fin arrangement is better. Seems like that would restrict air flow through the core, especially on a thicker core. This would result in not as effecient cooling on the bootom side of the core, which is the side more prone to heat soak. There needs to be a balance between density and thikness for propper air flow and cooling.
 Old 06-13-2014, 08:19 PM   #39
jtt
jtt's Avatar
Posts: 270   (View Stats)
jtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the worldjtt is the leader of the world
Nice! When I had a ets, I could do auto-x runs and the tmic would be cool to the touch.
New Ghey - 2004 Ti Grey Mazdaspeed Mx-5
Elise Seat | Stock as fuck
SOLD - 2011 Black Mazdaspeed 3 w/ tech package
jtt is offline   Reply With Quote
 Old 06-13-2014, 11:36 PM   #40
I am an engineer with exposure to heat exchangers and thermal transfer and I still don't know what is going to happen; not even enough to hypothesize. There are too many variables - boost air temperature, outside air temperature, ambient temperature, core density, airflow, airflow evenness through the core, core pressure drop, radiant heat from turbo, hot spots, conductive heat transfer, airflow through the fins, heat distribution, internal core friction, turbulence, intercooler hood seal, etc.
Sent from my SCH-I545 using Tapatalk
cshunter likes this.
ESA (06-14-2014), ItsNox (06-15-2014)
« P0113 | New Member »
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/corksport-ets-cp-e-top-mount-intercooler-131840/
ETS TMIC opinions : mazda This thread Refback 03-18-2015 11:49 AM
gen 2 best tmic - Mazda 3 Quebec This thread Refback 07-29-2013 09:57 AM
My new stg2 93 logs with CP-e TMIC bertrand_CX_7 2010 MS3 - ECU Computer Tuning 9 12-06-2011 02:32 PM
new logs after downpipe and ets tmic dr_banano 2010 MS3 - ECU Computer Tuning 17 11-21-2011 08:52 PM
ETS TMIC before and after logs posty MazdaSpeed 3/6 - ECU Computer Tuning 9 01-01-2011 07:24 PM
Page generated in 0.62732 seconds with 36 queries
