 Old 09-17-2018, 01:16 AM   #1
slowspeed6's Avatar
Posts: 13   (View Stats)
slowspeed6 is an unknown quantity at this point
Default Couple questions
I'm not sure if this is the correct place to post this or not but I've done a ton of searching and can't find any answers. I have a Mazdaspeed 6 and am planning on installing a bnr s4 soon.
I wanted to do a compression test before spending any more money on the car. I rented a tester from autozone that looked like it had never been used before. All cylinders read 180 but each one took at least 15 cranks before the needle stopped moving. Each cylinder seemed to take about the same amount of time to reach 180. I've read it should take 3-4 cranks and I'm wondering if this is normal?
Also has any one heat wrapped the stock exhaust manifold? Would it be worth it to do? Thanks in advance for any advice!
slowspeed6 is offline   Reply With Quote
 Old 09-17-2018, 05:15 AM   #2
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
The engine should be hot when carrying out a compression or leak down test to ensure the engines internal components have expanded to size and are sealing up. Other wise readings may be skewed. It's also a good idea to test each cylinder quickly before the engine cools down.
It took mine about 8 to 10 cranks to hit 180 psi, but every tester is different. As long as you are hitting good peak cylinder pressure in every cylinder it should be fine. A leak down test should be the next thing to do as it will tell you a lot more
Couple of questions Bucket head 2010 MS3 - Engine, Transmission & Driveline 10 02-28-2012 08:53 PM
couple BT questions ryein7 MazdaSpeed 3/6 - Turbo Induction 12 09-16-2011 09:53 AM
Couple of questions vladny1 Mazdaspeed3/6 General Discussion 9 12-17-2010 04:04 AM
Page generated in 0.23441 seconds with 21 queries
