 Old 04-24-2009, 02:25 PM   #1
kevin@gripgarage.com's Avatar
Posts: 45   (View Stats)
kevin@gripgarage.com will become famous soon enoughkevin@gripgarage.com will become famous soon enough
Default CP-E Motor Mounts for the Mazdaspeed 3 in stock !
Hello everyone,
We just got our shipment of CP-E Engine Mounts for the Mazdaspeed 3 (60-durometer), and their ready to ship out =) ! Please go to our website at --== Grip Garage ==-- Your Source for Mazda Aftermarket Parts ! to purchase or PM for paypal payment details. Thanks!
"Custom Performance Engineering is very proud to release the first aftermarket EPDM (ethylene propylene diene monomer) rubber engine mount for the MazdaSPEED3! CNC machined from a single piece of billet 6061-series aluminum; this mount is not only totally indestructible, but it also transmits far less NVH (noise, vibration and harshness) into the cabin than comparable mounts.
Our mount is unique compared to our competitors mounts both in form and in function. We use rubber for the bushing as opposed to urethane simply because it is better suited for this application. Rubber withstands engine heat much better then urethane, and it will not deform or crack over time the way urethane can. We were also able to incorporate a unique method of holding the mount in the vehicle. Instead of placing all of the force on the center bushing pin, the load is distributed throughout the bushing. This increases the effective stiffness of the bushing under engine loads, and the 60-durometer bushing absorbs annoying vibrations. Now you can combine the stiffness of a race mount with the comfort of a stock unit!"
-Kevin
kevin@gripgarage.com is offline   Reply With Quote
cpe motor mounts marcusdigi MazdaSpeed 3 - Engine, Transmission & Driveline 9 04-24-2009 08:57 AM
Who Has Rear Motor Mounts in stock? Arrowpoint Mazdaspeed3/6 General Discussion 2 12-29-2008 08:01 PM
Motor Mounts in stock? TheDoc Mazdaspeed3/6 General Discussion 1 07-09-2008 12:50 PM
Page generated in 0.23866 seconds with 20 queries
