 Old 01-07-2019, 12:48 PM   #1
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The stock exhaust valves are pretty awesome, and in the 10 years I've been screwing with this platform I've maybe seen 3 instances of them failing. You have a lot of gunk buildup in that head, so a flake may have wedged itself in and it leaked over time and burnt. I'd expect other signs of failure on the other valve if the injector was screwed up.
I'd probably just pick up a used head from a junkyard and rebuild it/milled flat.
-06 MS6
-Corn fed 07 MS3 - Sold
What mount has caused you the most NVH. KamloopsDan MazdaSpeed 3 - Engine, Transmission & Driveline 9 06-15-2017 09:11 AM
valve guides? valve seal? valve stem? WHAT IS BLOWN?!?!?! eroler1 Gen2 MS3 General Discussion 32 12-29-2016 03:29 AM
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
Can this be caused by dirty bpv? Zdraveca 2010 MS3 - Troubleshoot/Diagnostics 40 03-22-2013 06:44 PM
What Caused This Stealth01 Mazdaspeed3/6 General Discussion 20 07-21-2011 07:34 PM
Page generated in 0.23173 seconds with 22 queries
