![]() Join Date: Dec 2018 Location: (Near)Toronto, ON
(Thread Starter) | Not Ranked : 0 score Hey all, Was wondering if I can get some experienced member help on what these cars could do to cause such a valve failure: This valve holds 20PSI in this cylinder (3) And only 1 of the valves is damaged like this. Cylinder and pistons are undamaged. It was misfiring in this cylinder, but I attributed that to low compression. Any advice is appreciated. Thanks, Phil. Last edited by The_big_dill; 12-30-2018 at 09:14 AM. |
![]() Join Date: Nov 2014 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Looks like a burned exhaust valve. Usually caused by the valve not properly sealing. My gen 2 with 220k had a burned exhaust valve on cylinder 3.
__________________ 2008 Metro Gray Mica Speed 3-SOLD Corksport SRI Corksport TIP JBR 80 duro RMM Cobb AP v3 Autotech internals CX Racing FMIC SPC rear camber arms Hawk HPS pads front and rear FREEKTUNE OTS+ 1998 Civic - SOLD2011 Speed3 200k+ miles Stock -Daily |
I am going to see if this head is salvageable, but what failing components do you think would cause this problem? I am a little concerned because this car is stock. | |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score what sort of symptoms got you to dig into it?
__________________ 94 M MS6 IS350 |
| Not Ranked : 0 score Dead miss. Compression check showed about 10psi on cylinder 3, using a scope and pressure transducer showed pulses in both exhaust and intake during compression stroke on cylinder 3. I bought it with a misfire, but it was cheap, very cheap.
| The Following User Says Thank You to 08mzr For This Useful Post: | Pu Manchu (12-31-2018) |
| Not Ranked : 0 score I am not the most knowledgeable on this. But from my understanding when an exhaust valve burns it's due to it failing to seal as I've previously stated. They can fail to seal due to carbon, tighter clearances, possibly running lean. I'm sure there could be some other reasons, but I'm not familiar enough with these issues to know them. Since you've owned the car have you cleaned the valves at all? Usually the head can be saved. I'd recommend all new exhaust valves to be safe, and also have a good machine shop do the work otherwise you'll be doing it twice. You should also send the injectors out for cleaning and flow testing.
Thanks for the advice, I will get the injectors cleaned and tested as well. | |
| Not Ranked : 0 score Kind of the same story with mine from the previous owner. He told me he was driving on the expressway when it started misfiring. As for injector cleaning look through the forums to see who can do them. Most places that clean/test injectors cannot do them at the high pressures Direct Injectors operate at. They may seem ok at the lower pressure and not be OK at high pressures.
![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score was just reading about a post in the other forums injectorRX and cleveland injectors they both clean GDI injectors and they have the shipping option i heard the cleveland changes the filter inside too planning of going to send mine soon |
| Not Ranked : 0 score I used injector RX. I don't have any evidence to show they replaced the filter, so they probably didn't. I've heard of some injector places shipping back the old filters in a bag so you can see how cruddy they were, lol.
Groans: 111
| Not Ranked : 0 score With that much carbon all over that cylinder it's hard to determine what happened. That valve looks burnt butit's possible it shattered after a big chunk of carbon flew off of an intake valve and was caught between that valve and the valve seat. Once chipped it will just continue to go.
| Not Ranked : 0 score The stock exhaust valves are pretty awesome, and in the 10 years I've been screwing with this platform I've maybe seen 3 instances of them failing. You have a lot of gunk buildup in that head, so a flake may have wedged itself in and it leaked over time and burnt. I'd expect other signs of failure on the other valve if the injector was screwed up. I'd probably just pick up a used head from a junkyard and rebuild it/milled flat.
| What mount has caused you the most NVH. | KamloopsDan | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 06-15-2017 09:11 AM |
| valve guides? valve seal? valve stem? WHAT IS BLOWN?!?!?! | eroler1 | Gen2 MS3 General Discussion | 32 | 12-29-2016 03:29 AM |
| Intake Valve Cleaning using valve overlap and DI injection window shift | Vansquish | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 05-06-2014 07:00 PM |
| Can this be caused by dirty bpv? | Zdraveca | 2010 MS3 - Troubleshoot/Diagnostics | 40 | 03-22-2013 06:44 PM |
| What Caused This | Stealth01 | Mazdaspeed3/6 General Discussion | 20 | 07-21-2011 07:34 PM |
