 Old 05-25-2018, 08:02 AM   #1
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
Groaned at 7 Times in 4 Posts
Sounds like another flux capacitor replacement. Just say "no thanks". The only thing you'd ever should have to do at the 100k mile service is a fluid change in PTO. Anything else is case seal or axle seal related and completely up to you if you want to have it done. If your undertray or PTO case has fluid on it, its likely the PTO case seal. To reseal properly you need to pull from the car. The $860 quote from Vanquish sounds about right for the job.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MPS6 Transfer Case "loud clunk" in reverse after new clutch stavros99 MazdaSpeed 6 - Engine, Transmission & Driveline 5 01-15-2018 06:41 PM
VIDEO: Chrysler's Nardelli makes case for "Why Fiat Works" Haltech Automotive News 0 03-20-2009 06:50 AM
Page generated in 0.22785 seconds with 21 queries
