 Old 05-20-2014, 04:34 PM   #1
Crizomatic's Avatar
Posts: 80   (View Stats)
Crizomatic is a name known to allCrizomatic is a name known to allCrizomatic is a name known to allCrizomatic is a name known to allCrizomatic is a name known to allCrizomatic is a name known to all
Default Drive / serpentine belt replacement part #
I searched but couldn't find anything other than the OEM part L3K915909A9U. Lots of conflicting info. I have a 2007 MS3, so Dayco 5060910? I believe it should be the 91" but one guy here and another on Amazon state it didn't fit.
edit: Just posting this part for my own reference too goodyear gatorback 6pk2310
Crizomatic is offline   Reply With Quote
 Old 05-20-2014, 07:07 PM   #2
speed3 britz's Avatar
Posts: 1,155   (View Stats)
@HawkeyeGeoff; whatchu know about this!
Giving it a little "tappy-tap-tap-taparoo" via HTC
 Old 05-21-2014, 07:12 AM   #3
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Do yourself a favor and get this one:
Gates: K060900
I tried the ACDelco belt, didn't fit. This one fits perfect and isn't that expensive.
Silver 2007 Speed3 GT
The Following 4 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Bexar (11-22-2017), Crizomatic (05-21-2014), ItsNox (05-21-2014), volcomcinematic (06-12-2015)
 Old 04-20-2015, 11:40 PM   #4
Yukon Mudder's Avatar
Posts: 4   (View Stats)
Yukon Mudder is an unknown quantity at this point
Gates: K060900
Having taken that advice and tried to install it, I can categorically say that the K060900 DOES NOT fit the MS6. Fortunately, the old belt was in good shape and I was just replacing it with the VVT work. Old one went back on and will stay there until it starts showing cracks.
This was what I ordered. About 1" shorter than the belt that was on there and not even close with the tensioner cranked all the way.
Amazon.com: Gates K060900 Multi V-Groove Belt: AutomotiveAmazon.com: Gates K060900 Multi V-Groove Belt: Automotive
Yukon Mudder is offline   Reply With Quote
 Old 04-21-2015, 08:27 AM   #5
I was also on a 2nd gen MS3; difference in power steering pump vs just a tensioner there for the gen2.
 Old 06-12-2015, 09:25 AM   #6
aviator79's Avatar
Posts: 3,934   (View Stats)
Im going to pick up the gates kit and hope it fits
Gates 38408K
EDIT nope this kit will not fit, only the tensioner is correct.
This is for MS6
I order from rock auto (total 97.12 shipped)
belt $20.79
https://www.rockauto.com/catalog/mor...nid=408&jpid=7
tensioner $30.79
https://www.rockauto.com/catalog/mor...nid=410&jpid=0
idler $35.79
https://www.rockauto.com/catalog/mor...nid=409&jpid=3
Amazon cheaper if no tax (99.58 shipped with 6.375% CT tax)
tensioner $30.57
GATES Part # 38408
Amazon.com: Gates 38408 Tensioner: AutomotiveAmazon.com: Gates 38408 Tensioner: Automotive
idler $37.25
GATES Part # 36263
Amazon.com: Gates 36263 Idler Pulley: AutomotiveAmazon.com: Gates 36263 Idler Pulley: Automotive
belt
GATES Part # K060911A
91.75in
Amazon.com: Gates K060911A Serpentine Belt: AutomotiveAmazon.com: Gates K060911A Serpentine Belt: Automotive
or you could get from napa and then easy to return what you don't need, but the idler and tensioner are more expensive.
belt
http://www.napaonline.com/Catalog/Ca...910_0329768889
tensioner
http://www.napaonline.com/Catalog/Ca...408_0269312749
idler
http://www.napaonline.com/Catalog/Ca...263_0258191532
ESA (06-14-2015)
 Old 06-12-2015, 09:37 AM   #7
volcomcinematic's Avatar
Posts: 274   (View Stats)
Gates # 25-060910 I use on my 09 3.
Also replaced my idler pulley with a steel one from gates # 36326.
Hope this helps.
Pd tuned.
09' true red GT
 Old 06-12-2015, 10:05 AM   #8
shamie's Avatar
Posts: 952   (View Stats)
I don't care what brand or number the belt is, if it isn't at least 91" you're going to have a bad day.
 Old 06-12-2015, 10:12 AM   #9
The # I provided is 91.68 outside circumfrence, sir.
Pd tuned.
09' true red GT
 Old 06-12-2015, 10:20 AM   #10
shamie's Avatar
Then it will fit.
My post wasn't directed at anyone just a general FYI - get a belt at least 91".
The Following User Says Thank You to shamie For This Useful Post:
 Old 05-24-2016, 12:05 PM   #11
GroceryGtr's Avatar
Posts: 472   (View Stats)
reviving a dead thread for info. if its a dayco/goodyear you need the 915 length, the 910 listed is too short. 915k6 is the size.
 Old 05-26-2016, 09:46 PM   #12
MSMS3's Avatar
Posts: 2,826   (View Stats)
Gates part number for gen 1 MS3 serpentine belt. Perfect fit.
Shwaykid (05-26-2016)
 Old 05-26-2016, 11:32 PM   #13
Shwaykid's Avatar
Posts: 646   (View Stats)
Master Pro I got at O'Relly with the same part number, assuming just a rebranded Gates, also fits Juans.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
 Old 11-22-2017, 08:44 AM   #14
JThor36's Avatar
Posts: 1   (View Stats)
JThor36 is an unknown quantity at this point
Default Serpentine Belt
Hello my M3 members. I own a 2010 MS3, grey metallic...beautiful. Unfortunately my serpentine belt popped due to wear/tear/mileage (over 100K). I ordered the Dayco 5060900 & Duralast 900k6. Trying to locate replacement but having difficult time. Any suggestions? Thanks
JThor36 is offline   Reply With Quote
 Old 11-22-2017, 09:02 AM   #15
Shwaykid's Avatar
Since Photobucket screwed everybody over and my pic is gone...
Master Pro K060910
2008 Mazdaspeed3 GT
Serpentine Belt Zeya MazdaSpeed 3 - Engine, Transmission & Driveline 8 05-24-2016 12:09 PM
serpentine belt Project_dog CX-7 > Engine, Transmission & Driveline 3 04-24-2014 09:37 AM
Serpentine belt 07Speed3007 MazdaSpeed 3 - How-To's 19 02-12-2011 08:01 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Page generated in 0.42315 seconds with 31 queries
